Old Jul 27, 2012, 01:14 PM
tc3wins is offline
Find More Posts by tc3wins
Multirotor Builder!!!!!
South Carolina
Joined Mar 2009
Luis, You know I will be wanting one of those mini Vtail frames. I have money put aside for it. it will goo good with its big brother.
tc3wins is offline Find More Posts by tc3wins
Old Jul 27, 2012, 02:41 PM
cmeisteriii is offline
Find More Posts by cmeisteriii
cmeisteriii's Avatar
United States, NV, Carson City
Joined Jun 2012
Luis, I love my 400 so I am with Stuart (tc3wins) I will have to have one of these and I also have funds in reserve for this baby.
cmeisteriii is offline Find More Posts by cmeisteriii
Old Jul 27, 2012, 03:02 PM
Rifraf is offline
Find More Posts by Rifraf
United States, CO, Golden
Joined Aug 2011
I got my 500 together last night and tried a few test hovers in the basement. Couldn't get it stable. At first, the default yaw PID rate on the Naze 32 MultiWii was WAY too much. I turned that down, but it's still really unstable. I'm using the Y4 config. Any tips on tuning would be really appreciated!!! Thanks!
Rifraf is offline Find More Posts by Rifraf
Old Jul 27, 2012, 03:11 PM
tc3wins is offline
South Carolina
Joined Mar 2009
For some reason the Naze 32 dosn't work well with the V-tail. it works great for Quads and hexas I tried the naze32 for my first board on the V-tail what you need to do is first mount the board with vibration dampners. like the mikrokopter ones. second you can change the gyro LPF in the arduino code to 20 htz as it is set to either 42 or 256 or something like that. all that will help...
Old Jul 27, 2012, 03:16 PM
Rifraf is offline
Joined Aug 2011
Thanks. I'm sure I could sell the Naze easily enough. What are people using on the V-Tail with the best results? I don't need all the bells ans whistles (baro, mag, etc). I'm only sport flying with it. Just hard to beat the cost of the Naze compared to others.
Old Jul 27, 2012, 05:58 PM
jihlein is online now
Find More Posts by jihlein
Albuquerque, NM
Joined Aug 2002
tc3twins, Rifraf,
I've got a new code base for the Naze32 that does a better job of processing/filtering sensors. I've not tried it on my vtail yet because I'm still waiting for motor and other hardware. It seems to fly well (within my skills) on my quad frame. It oversamples and averages the sensors, uses custom low pass filters. There are 3 different attitude estimators available, I'm currently flying a Kalman filter that runs at 500 Hz. It also has all the latest vtail mixer functions. There is no configurator program, it is setup via a crude CLI interface. If interested in trying it, PM me, I don't want this thread to go off topic.
jihlein is online now Find More Posts by jihlein
Old Jul 27, 2012, 06:27 PM
tc3wins is offline
South Carolina
Joined Mar 2009
Don't sell the naze 32 you can use on another quad they are great boards. For my V-tail I am using a quadrino with the vtail mixer and it works flawlessly, I have zero issues with it.
But with this new code that jihlein is talking about that might work for ya as well.
Old Jul 27, 2012, 09:42 PM
kad is offline
kad
Find More Posts by kad
kad
Quad Crasher
kad's Avatar
United States, NY, Poughkeepsie
Joined May 2012
My Naze32 has a V-Tail mode as well as the Y4 mode, have you tried that? I just got the Naze and haven't used it yet, although I'm planning on using to on my mini hunter. But the mode is there when I go to the CLI interface. Mine has the baseflight 20120503 firmware.
-K
kad is offline Find More Posts by kad
Old Jul 27, 2012, 09:53 PM
Rifraf is offline
Joined Aug 2011
I think I am running the same base flight. I tried the vtail mode, but it wouldn't arm. I wasn't sure if there was a problem with it. I'll try again. jihlein, I'll give baseflight a chance to see if I get any luck, then I might take you up on getting your code. Honestly, with two kids and planes in the hanger, too, I don't have as much time as I'd like to fiddle with the codes. This is one I'm hoping to just get in the without a lot of fuss... maybe it will just take a while to get it right....
Old Jul 28, 2012, 12:15 AM
flyhigh300 is offline
Find More Posts by flyhigh300
United States, TX, El Paso
Joined Nov 2010
Here is the first one...
few minor Issues to work out..
I made it form 1mm G10 ..
the V tail support is 1.5mm and the gear is 1.5mm ( as the smallest tool I cut with is 1/16)
This allows for a good fit..
one "problem" is.. the 1mm sheets.. do not allow the screws to compress..
using.. 1/4 standoffs.. and 3/16 screws from top and bottom..so the G10 is not thick enough..
So solution is.. go to 1.5mm sheets.. or add a small washer..
hmm but I rather like it as it is.. frame.. weight.. G10 part came in at 2.7oz..
I'll put all the screws in it and see what the weight comes in at..
motors I plan to use..
http://www.hobbyking.com/hobbyking/s...nner_10g_.html
flyhigh300 is offline Find More Posts by flyhigh300
Old Jul 28, 2012, 11:39 AM
kad is offline
kad
kad
Quad Crasher
kad's Avatar
Joined May 2012
Hmm... Converting everything to decimal inches for convenience
.0394 - G10
.2500 - Standoff
.0394 - G10
.3288
.375 - 2 x 3/16 Screw
.0462 - Difference
.0462 is just under 3/64" or 1.19mm. Switching to 1.5mm G10 would only add 1mm, so not enough.
My local Lowes (big box home center) sells nylon washers that are .033 thick. A pair of them or similar should give the needed clearance and an entire package of them weighs less than 2 grams. My scale isn't sensitive enough to weigh a single one.
Can't wait to get mine!
-K
Old Jul 28, 2012, 04:31 PM
kad is offline
kad
kad
Quad Crasher
kad's Avatar
Joined May 2012
What is the hole spacing on the FC mounting holes?
-K
Old Jul 28, 2012, 06:12 PM
speedmasta is offline
Find More Posts by speedmasta
France, IdF, Paris
Joined Mar 2012
Omg i want this puppy!
Can't wait to see it flying!
speedmasta is offline Find More Posts by speedmasta
Old Jul 30, 2012, 12:28 AM
Dialfonzo is online now
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
I did it with 30.5mm mounting hole.
The full size version have 45mm mounting and they are real close to the side of the plates.
45mm holes can't fit that small..
Dialfonzo is online now Find More Posts by Dialfonzo
Old Jul 30, 2012, 07:00 AM
tc3wins is offline
South Carolina
Joined Mar 2009
Well I e-mail Luis about the mini v-tail a few days ago, but never got any responce. I am figuring he is busy...
New Product Bledi-DiaLFonZo Copter VTail HUNTER 400 CANOPY + Addons Innerbreed Multirotor Talk 42 Sep 20, 2013 09:41 PM
