Old Jul 19, 2012, 07:55 AM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Originally Posted by Bledi View Post
STOP drinking I had never use this sh... MULTIWII Power !
You can tell me... I won't judge you...!
BTW: I will not stop drinking. Mouhahaha...!
Dialfonzo is offline Find More Posts by Dialfonzo
Old Jul 19, 2012, 10:39 AM
DoctorAudio is offline
Find More Posts by DoctorAudio
Some call me the other guy!
DoctorAudio's Avatar
Milwaukie , Oregon
Joined Feb 2003
I have used the first two board versions and didn't like the gyros coming off after a crash.
But hell it is like 20 bucks.
But I am going to be videoing, Multi-Wii is all I trust.
Can't say anything about Open-Pilot except. They make 3 every 3 months.
LOLOLOLOLOLOLO
What the helll are they thinking?
Multi-Wii 4 LIFE!
DoctorAudio is offline Find More Posts by DoctorAudio
Old Jul 19, 2012, 11:58 AM
flyhigh300 is offline
Find More Posts by flyhigh300
United States, TX, El Paso
Joined Nov 2010
haha..
everyone has there favorite..
tc3wins .. you used KK no ? Y4 setup ? ..
this new board looks very interesting ..
but have to many Wii based now ..
flyhigh300 is offline Find More Posts by flyhigh300
Old Jul 19, 2012, 12:55 PM
Milwaukie , Oregon
Joined Feb 2003
What he meant was!
Multi-Wii 4 LIFE!
Hahahahah!
Originally Posted by flyhigh300 View Post
haha..
Old Jul 21, 2012, 10:52 AM
Bledi is offline
Find More Posts by Bledi
Bledi's Avatar
Joined Jul 2011
Some looping ....
Looping VTAIL en accro trainer (0 min 59 sec)
Bledi is offline Find More Posts by Bledi
Old Jul 21, 2012, 11:13 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Originally Posted by bledi View Post
some looping ....
http://youtu.be/vvrycidpjpe
Old Jul 21, 2012, 04:48 PM
speedmasta is offline
Find More Posts by speedmasta
France, IdF, Paris
Joined Mar 2012
Originally Posted by DoctorAudio View Post
What he meant was!
Multi-Wii 4 LIFE!
Hahahahah!
It works with LiPo too! Hahahahah
speedmasta is offline Find More Posts by speedmasta
Old Jul 21, 2012, 05:07 PM
Milwaukie , Oregon
Joined Feb 2003
Is there a Multi-Wii lipo too.
Does it come with a self cooling and recharge option?
Wow this code just goes wherever it likes. Maybe just like Java, one day!
Hahahahah!
Old Jul 22, 2012, 01:53 PM
Kipkool is offline
Find More Posts by Kipkool
Old Flying Bastard
Kipkool's Avatar
France, IdF, Paris
Joined Jun 2011
Inside the Vtail 500, with the Black Keys...
Inside the VTail (3 min 10 sec)
Seems to be ready for fpv.
Kipkool is offline Find More Posts by Kipkool
Old Jul 22, 2012, 10:44 PM
Rifraf is offline
Find More Posts by Rifraf
United States, CO, Golden
Joined Aug 2011
Hey there. Luis asked that I post pics and info with my 500 build, so here it goes. My build is going REALLY slow. I only get a few minutes here and there to work on things. My first couple of comments, after getting the box open and motors mounted:
1) Packaging: a bunch of the G-10 was scratched because of the loose parts in the box. It might be worthwhile to wrap them in paper or plastic to keep the screws from scratching the loose G-10.
2) Motor mounts. The motor mounting is tight, mainly because of placement of the 3-wire bundle coming out of the motor (picture attached). It seems the solution would be to have the motor mount slots offset by 22.5 degrees, or placing the post on the inside further from the motor so that that wire has a little more room to flex. As it is, it is probably fine, but I don't like putting as much flex as I did on the wires to get it to fit.
3) I am using 20A ESCs, looks like they wont fit in the frame. With something this size and shape, it'd be nice if they did.
4) Tail: why only a single cross brace, not 2 to match up with the dual vertical braces in the frame? I've read a little about this area, and it seems a little weak. I will probably try to strengthen this a little.
Build is slow, but so far looks great. Once I get it all together I'll have a better feel for the situation as a whole. I'll be using the Naze 32. I'm really looking forward to how this will fly.
I originally had a set 2822 1400 KV motors (for sale, now!), but decided to go with a Power Up 400 Sport (28 x 28, 1050 KV). http://www.headsuprc.com/servlet/the...0-Sport/Detail. I have a stock of 10" and 9" props. I'll start with 10" all around, but might try the 9" in the rear as some have done.
Rifraf is offline Find More Posts by Rifraf
Old Jul 23, 2012, 10:22 AM
Joined Nov 2010
Hey guys..
So I do get a few comments about the scratches.. :-(
on your order screws may have come out of package but normally should not be loose in the box.
but even so...
the Color sheets are easy to scratch.. some of it show's up scratch.. even with efforts from supplier to individually wrap the colors sheets.. about the only color that seem to be scratch resistant is Orange.
Plus..
Frames go thorough a LOT of handling.. before they make it to the box.
Sheets are cut .. then I cut the frame .. then snap the part of of the sheets.
then wash each parts.. then test for fit.. ( sometime they are to tight) ..so have to clean them up.. ect.. I even shop around for some brushes that can effectively clean the part but not scratch .. not to successful
As for motor and ESC mounting.. I think kipkol had used some 30amp not sure if he put them inside. .. I know 18amp fit inside.... but cramped.. Eric has posted some pics of that.. 10amp of course fit easy .. in the boom itself..
The motor wires can be a problem but I've done a few..
I used.. emax with round motor stand so it was easy to twist.. ( not fair not the same)
I did build a few with fix motor mounting plate as you did.. and just cut the heat shrink.. ran one wire on one side of the boom.. and two on the other..
I guess risk is if you pull a wire to hard ect.. after you remove the heat shrink of three wires.. could be a problem..
maybe a small rotation is in order..
one I put the cutting files into production .. take a bit of time to re-modify them.
one I have some time I'll try that see how it work on next build..
But keep us posted see how you do..
Old Jul 23, 2012, 10:38 AM
Kipkool is offline
Old Flying Bastard
Kipkool's Avatar
France, IdF, Paris
Joined Jun 2011
Yes i've put the 30A between the 2 center frame. I don't think that's a good idea, they can't cool up here, no space left for air.
I'll move them back on arms & tail under props airflow.
Old Jul 23, 2012, 10:48 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Where did you buy your kit?
Old Jul 23, 2012, 11:20 AM
Joined Nov 2010
Vtail ? Eric he got this from me..
Old Jul 23, 2012, 12:09 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Ok
Just wondering cause i have send them in a loose bag to www.qcrc.ca and i don't know how he shipped the thing.
New Product Bledi-DiaLFonZo Copter VTail HUNTER 400 CANOPY + Addons Innerbreed Multirotor Talk 42 Sep 20, 2013 09:41 PM
