Old Jul 12, 2012, 02:08 PM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Originally Posted by jinsing View Post
Wooho!
Order placed to my rc build.
Red and black. Now how do I get a camera plate for the 500?
What kind of camera plate are you looking for ?
Dialfonzo is offline Find More Posts by Dialfonzo
Old Jul 12, 2012, 04:50 PM
jinsing is offline
Find More Posts by jinsing
jinsing's Avatar
United States, TX, Arlington
Joined Jun 2011
A gopro
jinsing is offline Find More Posts by jinsing
Old Jul 12, 2012, 04:58 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
A gopro
Fixed plate ..!?
Old Jul 12, 2012, 05:10 PM
jihlein is offline
Find More Posts by jihlein
Albuquerque, NM
Joined Aug 2002
When I order my frames, there where 2 different camera mounts. One is the simple fixed plate, which is easy to see how it is intended to be attached. The 2nd mount consists of 2 plates, and 4 small disks. Do you have a picture of how you intend this one to be attached? Might be obvious if I had the GoPro on hand now, but it's not here yet.
Thanks!
jihlein is offline Find More Posts by jihlein
Old Jul 12, 2012, 05:14 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Thanks!
Can you post link to what your reffering to ?
There are many "Prototype" idea that have been showed..
Old Jul 12, 2012, 05:38 PM
jihlein is offline
Albuquerque, NM
Joined Aug 2002
Here it is. I'm betting on some kind of anti vibration design.
By the way, your CNC work is top notch, great job!
Old Jul 12, 2012, 05:40 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Thanks but the kit you have was cut by Luis (www.myrcbuild.com)
I will try to get you a 3d file showing how it work but you need some kind of dampers that's why the round washer are for.
Old Jul 12, 2012, 05:55 PM
jihlein is offline
Albuquerque, NM
Joined Aug 2002
That's what I figured, thanks!
Old Jul 12, 2012, 07:43 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
It's a simple solution that Luis came with.
HERE is a FPV plate i was working on with similar design (Red part are damper)
Old Jul 13, 2012, 03:10 AM
Kipkool is offline
Find More Posts by Kipkool
Old Flying Bastard
Kipkool's Avatar
France, IdF, Paris
Joined Jun 2011
Dialfonzo, i want one like this too
Kipkool is offline Find More Posts by Kipkool
Old Jul 13, 2012, 07:36 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Originally Posted by Kipkool View Post
Ok it's done. Was quick.
Here is the patch:
http://xmltv.free.fr/multiwii/vtail4patch.diff
and a prepatched version here:
http://xmltv.free.fr/multiwii/MultiW...ailpatched.zip
There's more propoer ways to write this.. But here is the idea, and this should work well. I'm not really a programmer.
What has been modified:
config.h
Code:
//#define VTAIL4  //WARNING: motor rotation has changed: Front Left & Rear Right: CCW, Front Right & Rear Left: CW )
 /****************************    VTAIL QUAD configuration ****************************/
  /* set rear motors angle */
  #define VTAIL4ANGLE 40
  /* this  will compensate yaw/nick/roll in motor mixer to have perfect YAW/NICK/ROLL rotation on one axis at a time.
  /* If you have different motor/props configuration DO NOT activate any of the compensation below
  /* It's not possible to calculate the perfect motor mixer in this case because of too many motor/props combination*/
  #define VTAIL4YAWCOMP
  #define VTAIL4NICKCOMP
  #define VTAIL4ROLLCOMP
Output.pde:
Code:
  /*************** VTAIL4 Mix table *********************************/
  //calculate correct front motors thrust depending of rear motor angle
  #ifdef VTAIL4
    int vtail4Thrust;
    vtail4Thrust = (int)(sin(VTAIL4ANGLE));
	#if !defined(VTAIL4YAWCOMP) && !defined(VTAIL4NICKCOMP) && !defined(VTAIL4ROLLCOMP)
		motor[0] = PIDMIX(+0,+1, +1); //REAR_R
		motor[1] = PIDMIX(-1, -1, +0); //FRONT_R
		motor[2] = PIDMIX(+0,+1, -1); //REAR_L
		motor[3] = PIDMIX(+1, -1, -0); //FRONT_L
    #endif
	#if defined(VTAIL4YAWCOMP) && !defined(VTAIL4NICKCOMP) && !defined(VTAIL4ROLLCOMP)
		motor[1] = PIDMIX(-1, -1, -vtail4Thrust); //FRONT_R
		motor[3] = PIDMIX(+1, -1, +vtail4Thrust); //FRONT_L
	#endif
	#if defined(VTAIL4YAWCOMP) && !defined(VTAIL4NICKCOMP) && defined(VTAIL4ROLLCOMP)
		motor[1] = PIDMIX(-1, -vtail4Thrust, -vtail4Thrust); //FRONT_R
		motor[3] = PIDMIX(+1, -vtail4Thrust, +vtail4Thrust); //FRONT_L
	#endif
	#if defined(VTAIL4YAWCOMP) && defined(VTAIL4NICKCOMP) && !defined(VTAIL4ROLLCOMP)
		motor[0] = PIDMIX(-1,+1, +1); //REAR_R
		motor[1] = PIDMIX(-vtail4Thrust, -1, -vtail4Thrust); //FRONT_R
		motor[2] = PIDMIX(+1,+1, -1); //REAR_L
		motor[3] = PIDMIX(+vtail4Thrust, -1, +vtail4Thrust); //FRONT_L
	#endif
	#if !defined(VTAIL4YAWCOMP) && defined(VTAIL4NICKCOMP) && defined(VTAIL4ROLLCOMP)
		motor[1] = PIDMIX(-vtail4Thrust, -vtail4Thrust, -0); //FRONT_R
		motor[3] = PIDMIX(+vtail4Thrust, -vtail4Thrust, +0); //FRONT_L
	#endif
	#if defined(VTAIL4YAWCOMP) && defined(VTAIL4NICKCOMP) && defined(VTAIL4ROLLCOMP)
		motor[1] = PIDMIX(-vtail4Thrust, -vtail4Thrust, -vtail4Thrust); //FRONT_R
		motor[3] = PIDMIX(+vtail4Thrust, -vtail4Thrust, +vtail4Thrust); //FRONT_L
	#endif
  #endif
This should be tested , but there's no reason it doesn't work.
Ok i think that would work..
I have took a bit of time to answer since i want to be sure it look good.
Thanks a lot for doing that.
Now we need to put that on the test before request it to be included in Multiwii 2.1
Anyone... ?? (still not have my bird ready...)
Yes we can make you such GoPro mount..
Old Jul 13, 2012, 07:41 AM
Bledi is offline
Find More Posts by Bledi
Bledi's Avatar
Joined Jul 2011
I had test the first case all is ok
Bledi is offline Find More Posts by Bledi
Old Jul 13, 2012, 08:37 AM
Kipkool is offline
Old Flying Bastard
Kipkool's Avatar
France, IdF, Paris
Joined Jun 2011
There was a mistake in my code below. I've edited the post and links with correct patch & files.
I've just tested all different config in the field, everthing works correctly here.
This could be pushed in svn now.
Old Jul 13, 2012, 08:38 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
+1
Thanks for your time and help..
Old Jul 13, 2012, 08:47 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Did you try to fly with a gopro weight load up front on the frame ?
I want to know if it's gonna be ok ?
New Product Bledi-DiaLFonZo Copter VTail HUNTER 400 CANOPY + Addons Innerbreed Multirotor Talk 42 Sep 20, 2013 09:41 PM
