Old Feb 22, 2013, 08:58 AM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Originally Posted by Alwayscrash View Post
That's the right picture for props orientation.
You can test roll-pitch-yaw direction by holding in hand overhead.If they sense wrong then just reverse motor.Better to test one motor at a time to avoid confusing.Rear props must have label face up ie: 8X4.5 must be visible wnen looking at it.Don't forget to do FC calibration more than one time.
AC
------------------------------NO-------------------------------!!!!
I think he cut enough of his fingers...!!!!
Dialfonzo is offline Find More Posts by Dialfonzo
Old Feb 22, 2013, 08:59 AM
Orphee is offline
Find More Posts by Orphee
Joined Jan 2011
Originally Posted by Freakazoid View Post
Yup, I have matched this picture..
..with the numbers on your diagram.
Ive checked realtime data and all stick inputs match with the labels in multiwiiconf.
So either the sensor is wrong, or the motors are plugged in wrong.
I have the USB connector facing forward and topside, this is how the flip is supposed to go I think?
I have AC's modified firmware (RC 2.1 r976), VTAIL4 is defined, as well as FLYDUINO_MPU.
The following picture is good for the prop rotation :
But the motor number are good only for Y4 configuration WITHOUT set YAW=-1
With this Y4 configuration, you can choose this motor configuration
OR you can set YAW=-1 in multiwii code, and leave motors as a VTAIL4 conf.
If you choose VTAIL4, the props rotation is the same, but at rear, 9 is at right, and 11 at left (always without YAW=-1)
You always have to look your multicopter from top for the rotation, even if rear motors face down.
Orphee is offline Find More Posts by Orphee
Old Feb 22, 2013, 09:05 AM
Alwayscrash is offline
Find More Posts by Alwayscrash
"you'll play to live "
Alwayscrash's Avatar
Canada, QC, Montreal
Joined Sep 2009
MWC flip has MPU6050. Try using the define MPU6050 first, if that does not work, you may have to change the orientation.
Code: Select all
/* individual sensor orientation */
//#define ACC_ORIENTATION(X, Y, Z) {accADC[ROLL] = Y; accADC[PITCH] = -X; accADC[YAW] = Z;}
//#define GYRO_ORIENTATION(X, Y, Z) {gyroADC[ROLL] = -Y; gyroADC[PITCH] = X; gyroADC[YAW] = Z;}
//#define MAG_ORIENTATION(X, Y, Z) {magADC[ROLL] = X; magADC[PITCH] = Y; magADC[YAW] = Z;}
AC
Alwayscrash is offline Find More Posts by Alwayscrash
Old Feb 22, 2013, 09:09 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Code: Select all
AC
If you follow what i said here, orientation should be USB facing front.
Old Feb 22, 2013, 09:10 AM
Orphee is offline
Joined Jan 2011
Don't forget to calibrate your ESCs if they can be calibrated.
Old Feb 22, 2013, 09:22 AM
Freakazoid is offline
Find More Posts by Freakazoid
Freakazoid's Avatar
Roosendaal, Netherlands
Joined Dec 2004
Eh.. I already count... 4 cuts on my fingers. These puppies bite!
I need me a pair of these.
Found the problem though, those damn motor pin assignment pictures are wrong.
The tail motor numbers are backwards, like orphee says, 11 should be the LEFT motor, and vise versa.
So atleast I got this meatgrinder going in the right direction now. Next up is dealing with derped simonK ESCs.
Im a little hesitant to try anything with this quad, with those ESCs boiling up so badly..
All I have connected to them is battery on one end, motor on the other end, and JUST the signal wire going to the flipboard.
I dont know what im doing wrong, it has grounded BOTH my beautiful new quads, and it is absolutely maddening!
Freakazoid is offline Find More Posts by Freakazoid
Old Feb 22, 2013, 09:25 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
[]http://img.diytrade.com/cdimg/209241/3480741/0/1196406464/chain_mail_protective_glove.jpg[/img]
I will work out something to post on the Setup post.
The problem is that in different config, you get different motor and prop rotation...
Does the thing heat on the ground without any motor movement ?
Old Feb 22, 2013, 09:26 AM
BadBert is offline
Find More Posts by BadBert
BadBert's Avatar
Nederland, Noord-Brabant, Hoogerheide
Joined Mar 2007
Freak, dont forget the fact that you have like no power at all...?
or is the power on the mini hunter OK?
BadBert is offline Find More Posts by BadBert
Old Feb 22, 2013, 09:27 AM
Orphee is offline
Joined Jan 2011
You probably need to calibrate your ESCs...
What is your transmitter ? what is your Throttle Channel on your receiver ?
Old Feb 22, 2013, 09:32 AM
Joined Sep 2009
Exactly. Also in config.h: #define FLYDUINO_MPU //
that's for flip mwc version.
AC
Old Feb 22, 2013, 09:35 AM
Freakazoid's Avatar
Joined Dec 2004
The power on the mini hunter is quite alright, infact I had to hold on to it for dear life when the gyro started to arm wrestle me.
The escs are simonK, so technically they shouldn't need any calibration, but I did it through the firmware so that should be alright.
It all seems to function now, though still feeling quite far off from the PID settings ill eventually need (simonK needs them slashed in half I believe).
Its just the escs getting a bit toasty.. I just set it on my desk powered and armed,
gonna see if it heats up from just sitting there in about 3 minutes.
Hope it doesn't catch fire (knocks on wood)....
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
I have updated the drawing (Thanks to Orphee who edited them and send them to me) in the second post
HERE
Old Feb 22, 2013, 09:42 AM
Freakazoid's Avatar
Joined Dec 2004
Heheh its getting a little difficult to figure these things out.
Welp, on the ESC heating thing, it seems perfectly pleased with just sitting there,
its not heating up with doing nothing, so I guess the BECs are in the clear?
I really hope they just heated up because the controller was really yanking those motor throttles while I was debugging the backwards tail...
I guess ill just button this mini hunter up and start PID testing with it a bit and see if it still cooks up from just hovering.
Old Feb 22, 2013, 09:43 AM
Orphee is offline
Joined Jan 2011
WRONG !!!
You must calibrate each ESC with your THROTTLE chan each time you change the receiver...
The calibration needs to be done with props removed :
- ESC plugged directly the the THROTTLE chan on your receiver (not on the board)
- ESC powered off
- Transmitter with THROTTLE at full power
- Plug ESC, some beep should be done
- push THROTTLE down to min GAZ another beep is heard.
Do the calibration for each ESC.
I had issues with Multiwii firmware (#define ESC_CALIB_CANNOT_FLY) option... but maybe it works for other guys here...
Old Feb 22, 2013, 09:49 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Originally Posted by Orphee View Post
WRONG !!!
- ESC powered off
I still like the - Do them one by one - thing..
i have made a little adaptor to calibrate many at once.
New Product Bledi-DiaLFonZo Copter VTail HUNTER 400 CANOPY + Addons Innerbreed Multirotor Talk 42 Sep 20, 2013 09:41 PM
