Old Feb 20, 2013, 09:30 PM
Alwayscrash is offline
Find More Posts by Alwayscrash
"you'll play to live "
Alwayscrash's Avatar
Canada, QC, Montreal
Joined Sep 2009
Just test the MultiWii dev version r1342 ,seems there's a bug on arming/disarming motors. There's no update codes for Vtail .
AC
Alwayscrash is offline Find More Posts by Alwayscrash
Old Feb 21, 2013, 03:02 AM
hugeone22 is offline
Find More Posts by hugeone22
Fixed Pitch addict!
hugeone22's Avatar
Christchurch New Zealand
Joined Feb 2010
hey Freakazoid will a KK2.0 fit in the mini? or can you only fit 35mm FC? I have been watching your build pics with great interest. I am hoping to Buy a Mini and a 400 frame.
hugeone22 is offline Find More Posts by hugeone22
Old Feb 21, 2013, 03:20 AM
Freakazoid is offline
Find More Posts by Freakazoid
Freakazoid's Avatar
Roosendaal, Netherlands
Joined Dec 2004
In the mini, unfortunately not. I think the mini can only handle 35 to 40mm boards.
It should fly pretty good on the cheap 21 dollar flip boards though, which fit pretty tight.
Tonight im gonna finish the mini and see if I can get a nice little hover out of it.
If you're not into "mcguyvering" with the solder iron, I recommend building your controller ontop and not inside though.
But if you really want to, solder the (angled!) motor headers onto the flipboard inverted, so they face inward and under the board.
Or else youll run into trouble with the vertical tail plate like I did.
Freakazoid is offline Find More Posts by Freakazoid
Old Feb 21, 2013, 04:26 AM
Fixed Pitch addict!
hugeone22's Avatar
Joined Feb 2010
Ok I will look to get a flip for the mini! I work in an electronics company in engineering and soldering small items is no problem for me and like you i would want a tidy build with as little wiring showing as possible.
On my tri all the wires are routed inside the Arms even the servo wires and lighting wires. The esc's and power wiring all sit neatly tucked inside the body out of sight.
Keen to see your progress with the mini (more pics of it finished please) also what is happening with your 400?
Old Feb 21, 2013, 04:52 AM
Freakazoid's Avatar
Joined Dec 2004
Ill probably have the mini done by tonight.
The 400 ill probably have to strip and start over.
The ESCs are cooking up and power isnt anywhere near videos with quads using the same motor.
Old Feb 21, 2013, 12:13 PM
FatTony is offline
Find More Posts by FatTony
Joined Jan 2013
VTail 500 Controller
Hey!
Is anyone familiar with the DJI NAZA Multi-Rotor Stabilization Controller??
http://www.dronesvision.com/dji-naza...on-controller/
Or should I simply pick a Multiwii instead...
Thanks in advance!
FT
FatTony is offline Find More Posts by FatTony
Old Feb 21, 2013, 12:24 PM
Joined Sep 2009
Originally Posted by FatTony View Post
Hey!
Thanks in advance!
FT
DJ naza will not work with Vtail, choose multiwii or KK.
AC
Old Feb 21, 2013, 02:05 PM
FatTony is offline
Joined Jan 2013
AC
Thank you for your immediate response!!
I think a KK board is a good choice! (Either is Multiwii, still I can't install both)
What do you think about 4in1 ESC's, could this one work??
I'm pretty new at DIY multicopters, sorry for bothering you guys...
FT
Old Feb 21, 2013, 02:09 PM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
FT
I don't think a 4-1 ESC would do a clean job since the wire will go out pass the center plates.
Which size is that esc ? Normaly they have standar 45mm mounting holes.
Dialfonzo is offline Find More Posts by Dialfonzo
Old Feb 21, 2013, 02:28 PM
Pablochopper is offline
Find More Posts by Pablochopper
United States, WA, Olympia
Joined Dec 2012
I use the kk2.0 and it flies great! I also used tech69's settings.
Pablochopper is offline Find More Posts by Pablochopper
Old Feb 21, 2013, 02:31 PM
FatTony is offline
Joined Jan 2013
It takes 4 x 35A , with 4 x 40 A (15sec) at max. Perfect for the 500. The input voltage is varying between 9,5 to 17,5 V, depending on which LiPo you use (3-4S). The input frequency is 480 Hz, so it should theoretically fit to both KK and Multiwii.
In diameter it's 90mm, with, as you assumed, 45x45mm standard mounting holes.
Here are some pics!
As a drawback you need a BEC.
Don't you think one could install the wiring at the outside, w/o crossing any plates? I think it could be worth a shot, since the compactness is tempting...
Thanks for the feedback!!
FT
Old Feb 21, 2013, 02:42 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Here are some pics!
FT
I had a quick look at it.
But it would not fit the inside of the frame, it will hit the standoffs.
You could mount it on top without the protection plate.
Old Feb 21, 2013, 03:02 PM
FatTony is offline
Joined Jan 2013
Since my 500 came w/o the protection plate, the top-mount would actually be a choice.
But I get your point, the wires do go out at the sides. I need to think about the wiring, maybe there is a clean solution.
Speaking of clean solutions - I came across this 4-1 ESC since I couldn't imagine a clean assembly of 4 separate ESCs...
FT
Old Feb 21, 2013, 03:10 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
FT
Here is one way
http://www.rcgroups.com/forums/showp...&postcount=661
Not the best for cooling.
Could be mount on top as you said without the top protection plate.
(which is optional)
If you can solder all the wire going to the inside of the board rather than go out by the exterior, you could make all of them go strait in the center (reverse the board wire going down.)
Old Feb 21, 2013, 03:21 PM
FatTony is offline
Joined Jan 2013
Now THAT's tight!
Thanks!!
New Product Bledi-DiaLFonZo Copter VTail HUNTER 400 CANOPY + Addons Innerbreed Multirotor Talk 42 Sep 20, 2013 09:41 PM
