Old Feb 12, 2013, 11:09 AM
Freakazoid is offline
Find More Posts by Freakazoid
Freakazoid's Avatar
Roosendaal, Netherlands
Joined Dec 2004
I used the one AC linked. All in did was define motor stop, ppmsum,
and hack the cam trigger function to toggle leds on/off via A2.
Freakazoid is offline Find More Posts by Freakazoid
Old Feb 12, 2013, 11:14 AM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Just want to be sure it's not a mixing table that is wrong.
I guess not.
Dialfonzo is offline Find More Posts by Dialfonzo
Old Feb 12, 2013, 12:45 PM
Freakazoid's Avatar
Joined Dec 2004
It flies, quite Stable and well behaved actually, it's just the one esc going nuts.
Still wondering if using simonk needs something changed in the multiwii firmware though..
I seen this before, my crab quad caught fire because of it..
I really hate that coated motor wire stuff, almost impossible to solder.
Do you know how to get the lacquer off so I can make a good solder weld?
Old Feb 12, 2013, 12:55 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
You need to sand the wire prior to solder it.
Yes.. i don't like them too...
You don't need anything in Multiwii, The simonk is only a faster refresh rate on the ESC.
Old Feb 12, 2013, 12:59 PM
Freakazoid's Avatar
Joined Dec 2004
I scraped it with a box cutter until it turned white copper colored.
I guess that wasn't enough. Hovering at well past half stick sucks though.
Old Feb 12, 2013, 01:03 PM
Alwayscrash is offline
Find More Posts by Alwayscrash
"you'll play to live "
Alwayscrash's Avatar
Canada, QC, Montreal
Joined Sep 2009
That's what I did. Motors do spin at the same time, but the ESC of one gets hotter than the others.
Only one gets hot? why don't you swap it with another to see if it's still hot? this can eliminate esc or motor problem.
AC
Alwayscrash is offline Find More Posts by Alwayscrash
Old Feb 12, 2013, 03:21 PM
tech69x is offline
Find More Posts by tech69x
Custom quad builder
tech69x's Avatar
United States, CO, Boulder
Joined Apr 2012
Well I almost have it the way I want itName: ImageUploadedByTapatalk HD1360704086.004586.jpg
Description:
tech69x is offline Find More Posts by tech69x
Old Feb 12, 2013, 03:42 PM
Pablochopper is offline
Find More Posts by Pablochopper
United States, WA, Olympia
Joined Dec 2012
Originally Posted by tech69x View Post
Well I almost have it the way I want itAttachment 5531724
Very nice, the lights are awesome. What are they where did you get them?
Pablochopper is offline Find More Posts by Pablochopper
Old Feb 12, 2013, 06:30 PM
generem is offline
Find More Posts by generem
generem's Avatar
United States, CA, Rancho Cucamonga
Joined Oct 2011
Hi All
Just wanted to introduce myself. I was the guy fortunate enough to snag the one Rifraf sold in the classified. Using tech69x settings with the kk2 board, I was able to succesfully hover it a bit today. I had an issue using the prop setup it came with but I swapped them all for 9x47s and shes good.. theres a bit of tweaking still but it flew fine. I did flash the board to v1.5 and the only difference was that the motor direction was opposite from the post.. Otherwise. using the given values for the mixes, it worked fine..
I gotta say that this is an awesome looking rig.. I almost dont want to fly it... Almost
generem is offline Find More Posts by generem
Old Feb 12, 2013, 06:34 PM
tech69x is offline
Custom quad builder
tech69x's Avatar
Joined Apr 2012
You can get them from value hobby but you have to cut and solder them
Old Feb 12, 2013, 06:35 PM
tech69x is offline
Custom quad builder
tech69x's Avatar
Joined Apr 2012
Originally Posted by generem View Post
Hi All
Yea you got a great deal! Glad you got it in the air
Old Feb 12, 2013, 06:56 PM
Joined Dec 2012
I've got the normal led's that cut and solder, is it the same concept?
Old Feb 12, 2013, 06:59 PM
tech69x is offline
Custom quad builder
tech69x's Avatar
Joined Apr 2012
Yea I use very very small wire
Old Feb 13, 2013, 01:09 AM
Freakazoid's Avatar
Joined Dec 2004
Can't just use led ribbons from hobbyking?
Old Feb 13, 2013, 01:26 AM
Joined Dec 2012
That's what I use now is just looked like the lights were in a closer grouping, more per strip.
New Product Bledi-DiaLFonZo Copter VTail HUNTER 400 CANOPY + Addons Innerbreed Multirotor Talk 42 Sep 20, 2013 09:41 PM
