Old Feb 01, 2013, 07:10 PM
In-Flight is offline
Find More Posts by In-Flight
United States, TX, Arlington
Joined Jan 2013
The KK2 never appealed to me. So far I like my WiteSpy MultiWii Pro 2.0.
In-Flight is offline Find More Posts by In-Flight
Old Feb 01, 2013, 09:06 PM
Alwayscrash is offline
Find More Posts by Alwayscrash
"you'll play to live "
Alwayscrash's Avatar
Canada, QC, Montreal
Joined Sep 2009
here is a new imu ( Crius AIO Pro , atmega 2560 based ) that can be added to 2.1 in def :
IMU Orientations and Sensor definitions
Code: Select all
#if defined(CRIUS_AIO_PRO_V1)
#define MPU6050
#define HMC5883
#define MS561101BA
#define ACC_ORIENTATION(X, Y, Z) {accADC[ROLL] = -X; accADC[PITCH] = -Y; accADC[YAW] = Z;}
#define GYRO_ORIENTATION(X, Y, Z) {gyroADC[ROLL] = Y; gyroADC[PITCH] = -X; gyroADC[YAW] = -Z;}
#define MAG_ORIENTATION(X, Y, Z) {magADC[ROLL] = X; magADC[PITCH] = Y; magADC[YAW] = -Z;}
#define MPU6050_EN_I2C_BYPASS // MAG connected to the AUX I2C bus of MPU6050
#undef INTERNAL_I2C_PULLUPS
#endif
This is just an experiment, even was tested ok, use it carefully. Credit to: Kipkool.
AC
Alwayscrash is offline Find More Posts by Alwayscrash
Old Feb 01, 2013, 11:04 PM
kad is offline
kad
Find More Posts by kad
kad
Quad Crasher
kad's Avatar
United States, NY, Poughkeepsie
Joined May 2012
Sunnysky motor pics for Flyboy320
Flyboy,
Here's the shots of the Sunnysky 1250kv's mounted to the 400 frame.
-K
kad is offline Find More Posts by kad
Old Feb 02, 2013, 12:00 AM
Joined Jan 2013
I see a naga mouse
Old Feb 02, 2013, 07:02 AM
flyboy320 is offline
Find More Posts by flyboy320
flyboy320's Avatar
Canada, ON, Burlington
Joined Sep 2004
Originally Posted by kad View Post
Flyboy,
-K
Thanks Kad...
Mine are the X2208 1260Kv ones, but as there are a couple of different versions (mainly the length of the shaft and which end of the can it exits from), I'll just have to wait for them to arrive and see how they will mount.
flyboy320 is offline Find More Posts by flyboy320
Old Feb 02, 2013, 08:59 AM
Freakazoid is offline
Find More Posts by Freakazoid
Freakazoid's Avatar
Roosendaal, Netherlands
Joined Dec 2004
1250Kv, 1400kv, im starting to think the motors I picked dont have enough Kv.
Freakazoid is offline Find More Posts by Freakazoid
Old Feb 02, 2013, 09:10 AM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
I don't remember the link.
Which Suppo you got ?
Will that fit the vtail 400.. .HaHa..
Dialfonzo is offline Find More Posts by Dialfonzo
Old Feb 02, 2013, 10:29 AM
Freakazoid's Avatar
Joined Dec 2004
I got the suppo A2208/17 which is "only" 1100Kv.
And are you mad? Id pay to see a 400 go off with four of those sodacan motors.
Old Feb 02, 2013, 11:08 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
I think you will be fine with those motor.
It's just a matter of tuning the copter i think, if they can handle the weight your good.
HaHa.. i was joking
http://www.rctigermotor.com/show.php?contentid=144
Old Feb 02, 2013, 03:02 PM
Freakazoid's Avatar
Joined Dec 2004
Haha, putting 2400w of motor on a hunter 400mm. would give even warthox a run for his money.
Imagine having 8 kilo's of thrust on such a little frame.. On a novelty 800 sized frame however...
And I just hope the headspeed on my new hunter wont be snail paced.
I want people to get a little antsy when I push this thing low across the deck at full speed.
It has atleast 3:1 thrust to weight, so for lift im not concerned.
Old Feb 02, 2013, 03:40 PM
Joined Sep 2009
why so much thrust? don't tell me you gonna made some new record on "lift beer" competition !
As for the length of the tail boom would greatly depend upon the amount of thrust produced by the combination of the two rear motors angled at 40 degrees ,so if you are using all of the same motors and props, this would equal to about 25 % reduction in total trust of the combination and CG would be somewhere 1/3 back from the T intersection. The way I adjust my copters for CG is slowly raise the throttle while watching for which end lift first and adjust battery accordingly.
Again, each V-tail copter will not be the same unless they have the same motors, props and frame. Trust me.
AC
Old Feb 02, 2013, 05:59 PM
Freakazoid's Avatar
Joined Dec 2004
Haha the motors was a joke from Eric, for a beerlift copter id use an octo.
Do you have a set of PID settings to go with your V-tail modded firmware, AC?
Or is that going to be too different wich each motor setup?
Old Feb 02, 2013, 06:03 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Yes... It would destroy the frame..
Old Feb 02, 2013, 06:38 PM
Joined Sep 2009
I'm using stock 2.1 settings as she flies like a Quadx , only adjust Yaw when switching from 3S to 4S lipo (P=7 on 3S & 6.4 on 4S).
when will yours ready to rumble?
AC
Old Feb 02, 2013, 06:40 PM
Joined Sep 2009
Eric, is it possible to made the two V plates on rear with aluminium? stock seems too fragile to handles big motors..
AC
New Product Bledi-DiaLFonZo Copter VTail HUNTER 400 CANOPY + Addons Innerbreed Multirotor Talk 42 Sep 20, 2013 09:41 PM
