Old Feb 01, 2013, 12:50 PM
Alwayscrash is offline
Find More Posts by Alwayscrash
"you'll play to live "
Alwayscrash's Avatar
Canada, QC, Montreal
Joined Sep 2009
Originally Posted by Dialfonzo View Post
It's really time consuming.
I don't what to have to cut standoffs to make kits..
Aluminum is quite easy to cut, it would be easy on a press drill to cut them.
But standard lengh will cause problem there.
It's about 3$ each standoff for the minimum order of 100.
$3 for each will be a steal.How about using round stand-off and add shoulder-shim on bothside of frame plate?
Alwayscrash is offline Find More Posts by Alwayscrash
Old Feb 01, 2013, 12:55 PM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Prices i have are:
100 2.80/ea = $280
250 1.58/ea = $395
500 .89/ea = $445
1000 .50/ea = $500
I don't unserstand what you mean.
I like the shoulder standoff idea, Might dig into other similar way.
Dialfonzo is offline Find More Posts by Dialfonzo
Old Feb 01, 2013, 12:59 PM
Freakazoid is offline
Find More Posts by Freakazoid
Freakazoid's Avatar
Roosendaal, Netherlands
Joined Dec 2004
You can also use long screw tightened with locknut on pivoting side, easy to adjust tightness but this can wear out frameplate as well .Stock stand off now must be changed for a tube spacer.
AC
That's where I was coming from with the long thumbscrews, until you pointed out the spacers are tapped and have a screw on both ends.
Using a washer would take the stress off a bit, but you still have to pull the pin and hope the spacer doesnt fly off without that shoulder I suppose.
Freakazoid is offline Find More Posts by Freakazoid
Old Feb 01, 2013, 01:02 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Oh.. but that way you need to be carefull not to have the tube fall no ?
Joined Sep 2009
Prices i have are:
100 2.80/ea = $280
250 1.58/ea = $395
500 .89/ea = $445
1000 .50/ea = $500
like this: changed locknut for thumbscrew may be better.
Old Feb 01, 2013, 01:07 PM
Joined Sep 2009
this is just for the pivoting side, the other side must have SO-shoulder.
Old Feb 01, 2013, 01:08 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Ah ok..
I am not too worry about the pivot side
Old Feb 01, 2013, 01:25 PM
Joined Sep 2009
how about this? i'm using your stand off with screws from the protector plate.
AC
Old Feb 01, 2013, 01:27 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
AC
But that's the pivot no ?
Old Feb 01, 2013, 01:39 PM
Joined Sep 2009
yes,, just stock stand off with screws on pivot side, the other side you can put some thick shim for simulating shoulder.Choose appropriate shim with same thickness of frameplate and press it into predrilled frameplate hole , this way it can't fall off.All you have to do is buy thick shims and some work on press drill. Pretty simple,no?
AC
Old Feb 01, 2013, 02:56 PM
Freakazoid's Avatar
Joined Dec 2004
If you are going to make this a "factory feature", why not just CNC a pressfit nut shape into the plate?
Im not so sure about the spacer nolonger supporting the structure though, wont that bend a bit when you torque the arm?
Perhaps only routing a nut shape halfway through the plate so the nut spacer is kept in place?
Old Feb 01, 2013, 04:05 PM
Joined Sep 2009
I can follow your idea but don't know if cost would be reliable.I think foldable arm would be an option only for thick frame.
AC
Old Feb 01, 2013, 04:20 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
I will look what can be done. Maybe cnc something..
Old Feb 01, 2013, 04:30 PM
Simon Templar is offline
Find More Posts by Simon Templar
Infinite Rider On Da Big Dogma
Simon Templar's Avatar
United States, NC, Kernersville
Joined Jan 2013
Still trying to decide which FC board to go with for mine. Of those whom I've spoken with so far, the consensus seems to be a KK2 board. Still looking for other ideas before I make a decision.
Has anyone tried any of the HoverFly boards?
....sT
Simon Templar is offline Find More Posts by Simon Templar
Old Feb 01, 2013, 04:46 PM
Joined Sep 2009
You have to choose FC which has Vtail config or Y4.Also, using a full option FC will be better as you'll never know what you'll need to add in the future
AC
New Product Bledi-DiaLFonZo Copter VTail HUNTER 400 CANOPY + Addons Innerbreed Multirotor Talk 42 Sep 20, 2013 09:41 PM
