Old Dec 19, 2012, 05:32 AM
flitelab is offline
Find More Posts by flitelab
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Perhaps try some expo on the rudder channel.
flitelab is offline Find More Posts by flitelab
Site Sponsor
Old Dec 19, 2012, 06:34 AM
Alwayscrash is offline
Find More Posts by Alwayscrash
"you'll play to live "
Alwayscrash's Avatar
Canada, QC, Montreal
Joined Sep 2009
rcmano, it's not VT or Y6 that make the difference, propulsion config will be the subject, instead.
I'm using this VTAIL QUAD configuration:
/* set rear motors angle */
#define VTAIL4ANGLE 40
/* this will compensate yaw/nick/roll in motor mixer to have perfect YAW/NICK/ROLL rotation on one axis at a time.
/* If you have different motor/props configuration DO NOT activate any of the compensation below
/* It's not possible to calculate the perfect motor mixer in this case because of too many motor/props combination*/
#define VTAIL4YAWCOMP
#define VTAIL4NICKCOMP
#define VTAIL4ROLLCOMP
Also, there're some changes on output.ino also.
You can try the patch here: http://xmltv.free.fr/multiwii/vtail4patch.diff
AC
Alwayscrash is offline Find More Posts by Alwayscrash
Old Dec 19, 2012, 09:57 AM
DoctorAudio is offline
Find More Posts by DoctorAudio
Some call me the other guy!
DoctorAudio's Avatar
Milwaukie , Oregon
Joined Feb 2003
You had to change the address of the Baro?
DoctorAudio is offline Find More Posts by DoctorAudio
Old Dec 19, 2012, 10:04 AM
Joined Sep 2009
Yes,DOC. I'm testing headfree...
AC
Old Dec 19, 2012, 10:07 AM
Milwaukie , Oregon
Joined Feb 2003
Awesome:
It is not as hard as you thought this multi-wii stuff?
And good job getting it done.
Holla!
Old Dec 19, 2012, 10:08 AM
elliott000 is offline
Find More Posts by elliott000
Canada, BC, Vancouver
Joined Feb 2012
So whats the correct prop rotation or does it matter, motors came today.... Time to setup cc3d
Thanks guys
elliott000 is offline Find More Posts by elliott000
Old Dec 19, 2012, 11:11 AM
rcmano is offline
Find More Posts by rcmano
New to Multi rotors
Joined Dec 2012
AC
scary stuff, that probably reads real easy for a code monkey.
i have some learning to do.
cheers again pal
rcmano is offline Find More Posts by rcmano
Old Dec 19, 2012, 11:14 AM
rcmano is offline
New to Multi rotors
Joined Dec 2012
hey Flitelab
did you mean from the transmitter?
if so i have tried already, got closer to where i wanted it tweaking dual rates but then i could not arm and disarm my quadrino so had to undo it all.
i will try the method AC has given , thanks tho
Old Dec 19, 2012, 11:16 AM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Originally Posted by rcmano View Post
hey Flitelab
Expo is better for me than dualrate.
Give you the same full travel but calm it over the center
Dialfonzo is offline Find More Posts by Dialfonzo
Old Dec 19, 2012, 11:19 AM
tech69x is offline
Find More Posts by tech69x
Custom quad builder
tech69x's Avatar
United States, CO, Boulder
Joined Apr 2012
Thanks guys
If you are going to use a cc3d there is a guy over in the openpilot forums who has the settings
tech69x is offline Find More Posts by tech69x
Old Dec 19, 2012, 11:37 AM
rcmano is offline
New to Multi rotors
Joined Dec 2012
funny bit is i tried 100% Expo and still it is so fast.
1mm travel on the yaw stick = about 2 360 rotations per second.
i want to fly slow and smooth, i would like less than a quarter of my current yaw speed.
I am running similar to Bledi i think 880KV rear 1000KV front i assumed that may have had something to do with it.
my pitch and roll are beautifully smooth, and fast if i use all the stick.
My yaw is wooow not seen anything go that fast, not sure what would happen if i push the yaw stick all the way in one direction but i am not even brave enough to try it and see. its insane.
i am gonna follow AC's instructions and see what i get.
cheers oh great creator
Old Dec 19, 2012, 11:46 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Are you sure you have set your expo in the right direction?
Old Dec 19, 2012, 11:51 AM
rcmano is offline
New to Multi rotors
Joined Dec 2012
110% sure i have
use it all the time on my Cars, Boats and Heli's.
i understand why you have to ask tho
Old Dec 19, 2012, 12:18 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
110% sure i have
In the GUI you can decrease the Rate of the Yaw axis
Old Dec 19, 2012, 12:29 PM
Joined Sep 2009
Awesome:
Holla!
As soon as I'm going deeper and using brain, also with lot of help from RCG community, specially from you .
AC
New Product Bledi-DiaLFonZo Copter VTail HUNTER 400 CANOPY + Addons Innerbreed Multirotor Talk 42 Sep 20, 2013 09:41 PM
