Old Dec 15, 2012, 01:12 PM
rcmano is offline
Find More Posts by rcmano
New to Multi rotors
Joined Dec 2012
she's built yay, hovered for about 15 seconds in living room, all flighty and responsive bit of a handfull no sensors on.
acc ON : hovered about 45 secs real smooth and stable on the spot take off and landing too apart from wagging its tail like an over ecxited puppy (it looked likt the 2 rear mototrs were alternating in power).
i used my Transmitter trims to balance the motors output as they were no where near even -when i increased throttle, is there another way to acheive the same result ? (trimming the motor outputs to be level on throttle)
is it now time for me to learn about PID settings folks, can you confirm for me wether i am headed in the right direction ?
for now i will try re-calibrating the sensors
rcmano is offline Find More Posts by rcmano
Old Dec 15, 2012, 04:36 PM
Alwayscrash is offline
Find More Posts by Alwayscrash
"you'll play to live "
Alwayscrash's Avatar
Canada, QC, Montreal
Joined Sep 2009
Balance props & motors.Diminish Yaw P. Use subtrim, not trim on TX.
AC
Alwayscrash is offline Find More Posts by Alwayscrash
Old Dec 15, 2012, 06:01 PM
rcmano is offline
New to Multi rotors
Joined Dec 2012
AC
ahh subtrim of course cheers, i changed the gyro LPF down to 20 much better now crazy wobble all gone. i aint got a prop balancer yet - in a few weeks i hope.
seems to hover really well only tried it indoors in a pretty small space auto level ON no effort.
yaw is crazy fast, have tamed it a bit had to put the P below 3 to make it less brutal (it was so fast i was to scared to use it)
not gonna play with baro or mag till i get it dialed mag is just causing her to spin slowly but i can live without it for now, seems to hold head almost perfectly without mag on anyways
done about 4 batteries of hovering indoors totally impressed.
Guys you have done a great job with this thing well worth the bucks - but you already know that
Old Dec 15, 2012, 06:32 PM
DoctorAudio is offline
Find More Posts by DoctorAudio
Some call me the other guy!
DoctorAudio's Avatar
Milwaukie , Oregon
Joined Feb 2003
Sure would like to see a screenshot of your GUI!
DoctorAudio is offline Find More Posts by DoctorAudio
Old Dec 15, 2012, 06:40 PM
rcmano is offline
New to Multi rotors
Joined Dec 2012
here u go doc
Old Dec 17, 2012, 07:43 AM
rcmano is offline
New to Multi rotors
Joined Dec 2012
Originally Posted by rcmano View Post
here u go doc
hey there doc, any feedback for me did you see anything a miss in my screenshot
seems as tho i need to work on removing some of the vibrations from this thing as i have had to lower the PID quite alot.
If i have alot of wires bunched up under the quadrino could this cause the Mag to function innacurately ? (do i have to try and keep wires away from the quadrino)
i think my motors are also a bit on the strong side as when taking off the tail is flexing all over the place just before it leaves the floor. ( i think i calculated my motors are providing about 3000 grams of lift at full throttle seems to want to hover around 40-45% throttle
Dialfonzo : i would like to be placing an order with you soon, within the next week i think (as soon as wages hit my account).
- Protective Top Plate (red)
- 2.6mm tail Upper Plate(black)
- 2.6mm tail Lower Plate(red)
- gopro Camera mount for HD Hero 3 (Red if possible)
- Assortment of extra standoffs and bolts (standoffs = 1/4, 1/2,1" 10x each maybe)
if you could give me an idea on the price for this that would be cool (i hope delivery to the UK is not a problem - feel free to PM me a quote for the above mentioned)
looks like i may possibly end up building another 1 for a friend
Old Dec 17, 2012, 07:45 AM
rcmano is offline
New to Multi rotors
Joined Dec 2012
AC
forgot to ask, what do you mean by balance the motors
Old Dec 17, 2012, 08:42 AM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
I don't have red material and sure not have 2.3mm version.
The supplier do 1.5mm only in red.
Dialfonzo is offline Find More Posts by Dialfonzo
Old Dec 17, 2012, 08:43 AM
tech69x is offline
Find More Posts by tech69x
Custom quad builder
tech69x's Avatar
United States, CO, Boulder
Joined Apr 2012
You balance motors like you would props
tech69x is offline Find More Posts by tech69x
Old Dec 17, 2012, 09:11 AM
rcmano is offline
New to Multi rotors
Joined Dec 2012
please elaborate as i am sure you are not telling me to shave parts off my motor casing that does not sound clever.
Old Dec 17, 2012, 09:14 AM
tech69x is offline
Custom quad builder
tech69x's Avatar
Joined Apr 2012
Look on YouTube There are several different ways
Old Dec 17, 2012, 09:29 AM
rcmano is offline
New to Multi rotors
Joined Dec 2012
ok cheers
Old Dec 17, 2012, 09:32 AM
Joined Sep 2009
Spin motor one at a time without props and see if there's vibration on frame and use tape to balance if necessary. In case you cannot eliminate all vibrations to the Gyro, go to config.h and comment : #define ITG3200_LPF_42HZ . (stock is 98HZ) then....fly. Will be more stable now..
AC
Old Dec 17, 2012, 09:48 AM
rcmano is offline
New to Multi rotors
Joined Dec 2012
so can you do ?
- 2.3mm tail Upper Plate(black)
- 2.3mm tail Lower Plate(black)
- gopro Camera mount for HD Hero 3 (black)
Old Dec 17, 2012, 09:55 AM
rcmano is offline
New to Multi rotors
Joined Dec 2012
AC
thanks for the motor balancing tip, it did not occur to me that the motors could be out of balance.
done the LPF after first hover and made a huge difference
New Product Bledi-DiaLFonZo Copter VTail HUNTER 400 CANOPY + Addons Innerbreed Multirotor Talk 42 Sep 20, 2013 09:41 PM
