Old Dec 14, 2012, 09:45 AM
rcmano is offline
Find More Posts by rcmano
New to Multi rotors
Joined Dec 2012
Hi again guys
Finally recieved the Quadrino but am a little confused despite extensive reading regarding wiring.
i am not sure i am understanding the VBATT and VIN connectors correctly.
So i connected all esc's to main power source (battery)
i have disconnected the red positive pins from the ESC servo leads so the ESC's DONT power the quadrino.
do i need to connect the VIN to one of the receiver's positive pins as i understand this input is voltage regulated to 5 volts.
and do i need to connect the VBATT lead from the quadrino to the main power source or can i leave this disconnected
details on wiring this board are vague
any help would be appreciated
rcmano is offline Find More Posts by rcmano
Old Dec 14, 2012, 09:48 AM
Dialfonzo is online now
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Originally Posted by rcmano View Post
Hi again guys
You need to keep one of the Plus wire from ESC to the Quadrino to power it.
All Plus and Minus pins on the Quadrino are linked together one the PCB.
So if you have on ESC powering the Quadrino, once you put a wire from the Quadrino to the Receiver it whould also power the Receiver.
Dialfonzo is online now Find More Posts by Dialfonzo
Old Dec 14, 2012, 10:00 AM
rcmano is offline
New to Multi rotors
Joined Dec 2012
Hi Dialfonzo
thanks for your response but i am trying to wire it following this logic
ESC powers radio, radio powers Quadrino through radio pin header.
so does that mean i need to use the VBATT and/or VIN
Old Dec 14, 2012, 10:11 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Hi Dialfonzo
No it will do exacly the same thing.
Old Dec 14, 2012, 10:23 AM
Granted is online now
Find More Posts by Granted
serial scratchbuilder
Granted's Avatar
Canada, BC, Mission
Joined Sep 2012
VBATT is for battery voltage monitor and VIN is 6-12v battery connection, you need neither. Like Fonzie sez, leave one positive wire from an ESC intact and eliminate the rest. On one channel of the RX use a 3-wire servo extension/jumper to connect sig./gnd./pwr to the quadrino inputs and everything will be apples. The remaining channels will only need a signal wire from RX to quadrino.
Granted is online now Find More Posts by Granted
Old Dec 14, 2012, 10:31 AM
rcmano is offline
New to Multi rotors
Joined Dec 2012
OK i think i have bitten off more then i can chew with the quadrino it looked like the right choice initially, as it said easy ez connect wiring system, yeah right!
i think i would find it less confusing if i had to solder all the wires myself as i would at least know what it talking to what, and what connectors are positive/neagative or signal
i thought it would be as simple as my heli's but with more motors to connect.
can you recommend an FC i can get that is well documented in terms of wiring diagrams and component info so i can better understand what i am doing.
with the quadrino the wiring diagrams are for older revisions that look nothing like what i have purchased and most of the tutorials seem to be written in a way that confuses the hell out of me.
Old Dec 14, 2012, 10:34 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Take some time to read that website
http://www.flyingeinstein.com/index.php/tutorials
Old Dec 14, 2012, 10:39 AM
Granted's Avatar
Canada, BC, Mission
Joined Sep 2012
Are you using the E-Z connect cables or pin-headers?
Old Dec 14, 2012, 10:43 AM
rcmano is offline
New to Multi rotors
Joined Dec 2012
Hi Granted and thanks but what your telling me to do will give me this.
1
ESC powers Quadrino through motor pin header, Quadrino powers radio.
Flight
If receiver fails, Quadrino continues to fly the copter. Risk of fly-away copter and to nearby people from spinning props.
i dont want that, i want this
Flight
If receiver fails, power fails on the Quadrino thus ESCs cut out. Copter free falls. Prevents fly-away copter loss! Though opinions differ, this is probably the safest failsafe mode to nearby people as there are no spinning props.
i
Old Dec 14, 2012, 10:45 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
1
Flight
Flight
i
Both way will give the same thing.
If Radio Fail the power to the Quadrino will not be shut by the receiver...
Old Dec 14, 2012, 10:56 AM
rcmano is offline
New to Multi rotors
Joined Dec 2012
i was using the EZ connect.
would something like this do the job
http://www.buzzflyer.co.uk/Stabiliza...er/p-168-2168/
Old Dec 14, 2012, 10:59 AM
rcmano is offline
New to Multi rotors
Joined Dec 2012
LOL
i got that info from the quadrino manual. and from what your telling me its Bull.
is it any wonder i am confused.
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
NAZA don't have any config for Vtail or Y4.
Did you look at the tutorial website i have link..??
Old Dec 14, 2012, 11:00 AM
Granted's Avatar
Canada, BC, Mission
Joined Sep 2012
You won't be able to achieve your goal unless you add a relay to cut power to the quadrino in the event of receiver failure, but it still won't be fool-proof and if it does work your copter is gonna drop like a rock. Still not safe. MultiWii firmware can be configured so the 'copter descends upon reciever signal loss, or drops, whatever you configure it to do. I have mine set 100 points above min. throttle and it descends gently if I turn off the transmitter.
Old Dec 14, 2012, 11:02 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
BTW: There is a FailSafe that can be activated inside the MultiWii soft.
New Product Bledi-DiaLFonZo Copter VTail HUNTER 400 CANOPY + Addons Innerbreed Multirotor Talk 42 Sep 20, 2013 09:41 PM
