Old Dec 04, 2012, 01:04 PM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Originally Posted by MrDusanmandic View Post
I'm using the KK2 controller with the V-Tail motor layout loaded.
I did do the ESC calibration (TX on with full throttle, hold buttons 1 and 4 and then apply power, wait for beeps and tone, move throttle stick down, wait for beep and then power off).
It's the front left and back left motors that spin up consistently. They continue to get faster and faster.
Ok, i know almost nothing about KK boards.
But are you sure the prop are spinning the right dirrection ? It may not be the same with KK and MultiWii.
If someone have a working setup for KK i would gladly post it in the Setup post (second) ... that would help people..
Dialfonzo is offline Find More Posts by Dialfonzo
Old Dec 04, 2012, 02:25 PM
RC911 is offline
Find More Posts by RC911
8 bit is more fun
RC911's Avatar
Norway, Troms, Tromsų
Joined Aug 2012
Some questions and tips for you:
1. Did you get beeps from ALL four ESCs before lowering the throttle?
2. How much throttle must you apply before the remaining motors start?
3. Are your motors connected to the correct motor ports (M1 - M4)?
4. Is your KK2.0 board mounted correctly (with buttons towards the tail)?
5. Are you using Self Level mode? If so, try Normal mode.
6. Are your motors spinning as specified in the first post of this thread?
7. Are your propellers mounted correctly (CW vs. CCW) with text facing upwards?
8. Is your copter's COG (Center of Gravity) good?
9. Use the Receiver Test function to verify that your transmitter endpoints are set correctly (-100 to 100) and reverse your TX channels as needed.
10. Perform 'Sensor Calibration' on a level surface.
11. A good mixer setup for V-Tail has been posted earlier in this thread. http://www.rcgroups.com/forums/showp...postcount=1507
RC911 is offline Find More Posts by RC911
Old Dec 04, 2012, 02:41 PM
MrDusanmandic is offline
Find More Posts by MrDusanmandic
Closed Account
Joined May 2011
I've done all of the above. Which is why I'm stumped and actually just listed it for sale. I used Tech69's settings and recommendations.
Since I will probably need brain surgery within the next 6 months, I'm wanting something slightly easier to deal with / fly. I bought the frame because it looks badass.
MrDusanmandic is offline Find More Posts by MrDusanmandic
Old Dec 04, 2012, 02:44 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Your back prop are not in the right way for sure.
You need to reverse them since like you did they push the tail to the ground
Old Dec 06, 2012, 09:47 AM
rcmano is offline
Find More Posts by rcmano
New to Multi rotors
Joined Dec 2012
Hi all
I have been checking this thread for a few months now trying to resist the urge to buy another piece of RC Kit but am unable to resist such an awsome looking aircraft.
took the plunge a week ago 500 black and red arrived yesterday, built and light kit fitted (had one laying around for a few years so thought finally time to use it).
anyhow Great job by all involved in Design/Production/Testing.
I have FC + motors + ESC's yet to be delivered so will possibly need to come back and pick your brains when they arrive.
for now can anyone confirm for me the size of the thread used on the 500mm
are they 2-56 Thread or 4 -40 Thread, sorry as i am useless with imperial measurements
rcmano is offline Find More Posts by rcmano
Old Dec 06, 2012, 09:50 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Originally Posted by rcmano View Post
Hi all
Good..
Where is the picture.. ??
Old Dec 06, 2012, 10:09 AM
flyhigh300 is offline
Find More Posts by flyhigh300
United States, TX, El Paso
Joined Nov 2010
Screws used are 4-40
Hi all
flyhigh300 is offline Find More Posts by flyhigh300
Old Dec 06, 2012, 10:35 AM
elliott000 is offline
Find More Posts by elliott000
Canada, BC, Vancouver
Joined Feb 2012
Do I need to go grab some screw? if so how many
elliott000 is offline Find More Posts by elliott000
Old Dec 06, 2012, 10:37 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
What do you mean...?
The kit include all screws you need to assemble the kit..
Old Dec 06, 2012, 11:01 AM
Joined Feb 2012
Its gettin dropped off today mail mans got it on his truck so i havent seen it yet. I just saw previous post about 4m 40 screws and started wonderin lol
Old Dec 06, 2012, 01:08 PM
rcmano is offline
New to Multi rotors
Joined Dec 2012
Originally Posted by Dialfonzo View Post
Good..
pics as requested
Old Dec 06, 2012, 01:16 PM
rcmano is offline
New to Multi rotors
Joined Dec 2012
No the kit was complete, even came with an alternative top plate
to Flyinghigh
many thanks
Old Dec 06, 2012, 01:18 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
pics as requested
Nice set of light..
Look different than the led strip.
I see that you mounted the top plate with 0.5" standoffs.
Normaly you should use the 1" standoffs i have provide and they are use with setscrews where the front arm connect to the center plate.
Bottom plate - Bottom arm - 0.5" standoff - Top Arm - Top plate - Setscrew - 1" standoff - Top Protect plate
(sorry it's not from me.. but you should have long standoffs)
Old Dec 06, 2012, 01:36 PM
Joined Feb 2012
pics as requested
Nice where did u get those lighta
S... I like the look more than strips
Old Dec 06, 2012, 01:43 PM
rcmano is offline
New to Multi rotors
Joined Dec 2012
Nice set of light..
I plan to add some LED strips later
yeah i put the top plate on just so i dont loose it for now and to keep all the vtail bits together. ( i have too much RC gear , i like to keep it all seperate)
i origionally planned to have the top plate from you after next paycheck then i got to thinking, cut it here and there to lighten it and give it a new shape and order some 1" standoffs and screws. (thats why i wanted to know the thread size)
i probably wil still buy your top plate in a few weeks though. as i thinks it would look nice in red.
Blades, ESC and motors arrive tomorrow yaay!! Quadrino coming from flielab (canada to UK) i thinks so not sure how long that will take.
I cant wait till its complete
New Product Bledi-DiaLFonZo Copter VTail HUNTER 400 CANOPY + Addons Innerbreed Multirotor Talk 42 Sep 20, 2013 09:41 PM
