Old Mar 31, 2012, 06:17 AM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Originally Posted by tc3wins View Post
I may try that.
It doesn't change a lot.. but it give you more protection for the motors.
Maybe less vibration since prop will be closer to the mounting point of the motor ?
Dialfonzo is offline Find More Posts by Dialfonzo
Old Mar 31, 2012, 07:43 AM
tc3wins is offline
Find More Posts by tc3wins
Multirotor Builder!!!!!
South Carolina
Joined Mar 2009
I took the Vtail outside. and I am not happy I am getting wobbles in both acro and stable modes. I switched the rear props back to 8 inch and that helped a small bit. but should I go up or down on the PID's for pitch and roll. auto level I am down to 6.6 and it is not super stable. on higher settings for auto level she is very touchy.
tc3wins is offline Find More Posts by tc3wins
Old Mar 31, 2012, 08:42 AM
Bledi is offline
Find More Posts by Bledi
Bledi's Avatar
Joined Jul 2011
You must have a good accro mode before acc mode. The acc mode on multiwii is not as good as naza one so ne careful.
For thé pitch you need to put more I
Bledi is offline Find More Posts by Bledi
Old Mar 31, 2012, 09:22 AM
tc3wins is offline
South Carolina
Joined Mar 2009
for my roll and pitch I am running P4.0 ,I 45 and D 24 and I am getting wobbles from left to right and slightly fore and aft. any Ideas. I stopped using auto level mode.
Old Mar 31, 2012, 09:31 AM
Bledi is offline
Bledi's Avatar
Joined Jul 2011
On a Vtail pitch and roll pid are différent and your P look to be low, have you try to increase it ?
Old Mar 31, 2012, 09:36 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
(Remember that PID are not the same on each Version of Multiwii)
Old Mar 31, 2012, 09:37 AM
tc3wins is offline
South Carolina
Joined Mar 2009
I went to 5.0 on the P on both and still got a bad wobble when I move the copter to roll and pitch.
Old Mar 31, 2012, 09:39 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
Then reduce them, but if you have to go below 4.0 then you've got problems elsewhere (i.e. mechanical/frame structure/vibrations/flexing/etc).
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Mar 31, 2012, 10:49 AM
tc3wins is offline
South Carolina
Joined Mar 2009
Here is a short video of the wobble. I went back to stock PID's P 4.0, I 30, D23 it is a little better. but you can see it in the video
V-tail copter wobble problem.AVI (1 min 20 sec)
Old Mar 31, 2012, 11:30 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
http://www.youtube.com/watch?v=LXdMS...ature=youtu.be
Yes ... some more PID tunint needed.
I have no experience with the Naze..
Did you balance your prop ?
Old Mar 31, 2012, 11:43 AM
timecop is offline
Joined Dec 2010
nice try, its multiwii 2.0.
tc3, try powering the stuff up in your hands (carefully), throttle up a little bit (enough to start getting corrections from gyro), and try holding the FC firmly against frame, and pitch/roll the model in various directions. does it still wobble around in that case?
Old Mar 31, 2012, 12:05 PM
Bledi is offline
Bledi's Avatar
Joined Jul 2011
I have an idea ! Did you reduce the P of the Yaw !
We thé défaut 8 value it is normal you had woodles on a vtail
Old Mar 31, 2012, 12:09 PM
timecop is offline
Joined Dec 2010
Btw, he's flying on y4 mixer (at least thats what I set).
Maybe try actual vtail?
Old Mar 31, 2012, 12:11 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
The V-Tail setup only mix some pitch
btw: i was not attack you .. just saying i don't know how your controller work..
Old Mar 31, 2012, 12:42 PM
tc3wins is offline
South Carolina
Joined Mar 2009
I will try lowering the yaw P I have not done that yet. I am also in the process of cleaning it up and adding lights and stuff. I know I will get it right sooner or later.
New Product Bledi-DiaLFonZo Copter VTail HUNTER 400 CANOPY + Addons Innerbreed Multirotor Talk 42 Sep 20, 2013 09:41 PM
