Old Nov 22, 2012, 09:00 PM
tech69x is offline
Find More Posts by tech69x
Custom quad builder
tech69x's Avatar
United States, CO, Boulder
Joined Apr 2012
Originally Posted by elliott000 View Post
Thanks tech. Is there pc software for the kk or are we stuck with lcd only?
LCD but if yours is broke they have a fix for that
tech69x is offline Find More Posts by tech69x
Old Nov 22, 2012, 09:39 PM
tech69x is offline
Custom quad builder
tech69x's Avatar
Joined Apr 2012
What size props can be used with the mini v tail
Old Nov 22, 2012, 09:42 PM
elliott000 is offline
Find More Posts by elliott000
Canada, BC, Vancouver
Joined Feb 2012
I spoke with matt at op and he is gunna help me do a custom mix for it.... Cc3d vtail enroute. Ill put my kk back into my disco. I have some tiger motors in my shop but i think ill go for a size up. Whata a suggest case size im thinkin 600-775 kv for 10"
elliott000 is offline Find More Posts by elliott000
Old Nov 22, 2012, 09:51 PM
kad is offline
kad
Find More Posts by kad
kad
Quad Crasher
kad's Avatar
United States, NY, Poughkeepsie
Joined May 2012
5" for the back. The front can handle 6", as long as your motors can handle them.
-K
kad is offline Find More Posts by kad
Old Nov 22, 2012, 10:35 PM
tech69x is offline
Custom quad builder
tech69x's Avatar
Joined Apr 2012
-K
Sorry for all the ? But what are the biggest motors I can use
Old Nov 23, 2012, 03:42 PM
Joined Feb 2012
Find out the size of the motor mounts... On the 400/500 u can fit up to 30 mm cans max, so like a 2814/ whatever
Old Nov 23, 2012, 05:59 PM
kad is offline
kad
kad
Quad Crasher
kad's Avatar
Joined May 2012
My mini is back with Luis right now having some work done so I can't measure the physical size of the mount hole, but I think those measurements are somewhere in this thread. From a weight standpoint, it's designed for something in the 10-15 gram range. I believe Eric designed the prototype with HobbyKing 10 gram motors. I used iPower 1811-13 (2000kv, 10gram) motors from gothelirc (mainly because I didn't want to wait 3 weeks for a HK order to arrive). I can't recommend them at this time though, as I had serious power (or lack thereof) issues with them. That's the main reason it's back with Luis, he's trying some different motors on it for me.
-K
Old Nov 23, 2012, 06:01 PM
kad is offline
kad
kad
Quad Crasher
kad's Avatar
Joined May 2012
I'd be interested in that mix when you get it figured out. I've got a CC3D sittign here and a V400 frame on the way.
-K
Old Nov 23, 2012, 11:33 PM
Joined Feb 2012
-K
My frames about a couple weeks probably, Ill post a link here to the OP forum thread when Matt helps me make the mix and tune it!
Old Nov 24, 2012, 05:03 PM
kad is offline
kad
kad
Quad Crasher
kad's Avatar
Joined May 2012
-K
Just to clarify that, it's the 2000kv iPower motors I can't recommend. I recommend gothelirc in general very highly.
-K
Old Nov 24, 2012, 05:21 PM
Joined Feb 2012
-K
2000kv eh, was that on the mini?
Old Nov 24, 2012, 10:16 PM
kad is offline
kad
kad
Quad Crasher
kad's Avatar
Joined May 2012
Yes, that was in response to tech69x's question about the mini. I run that one with a MultiWii.
-K
Old Nov 24, 2012, 11:01 PM
Joined Feb 2012
I have never run something on props that size when i saw 2000 kv i was like whaaat lol. Whats the preemo motor of choice on the 500 vtail at this point?
Old Nov 27, 2012, 04:02 PM
AlmostCool is offline
Find More Posts by AlmostCool
Joined Oct 2012
I've since switched to 2830-1290kv motors using the 10x5 props on my 500mm hunter. A lot more power than my 2830-920kv and you get hover at exactly 50% throttle.
AlmostCool is offline Find More Posts by AlmostCool
Old Nov 27, 2012, 04:17 PM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Picture ;-)
Dialfonzo is offline Find More Posts by Dialfonzo
New Product Bledi-DiaLFonZo Copter VTail HUNTER 400 CANOPY + Addons Innerbreed Multirotor Talk 42 Sep 20, 2013 09:41 PM
