Old Nov 16, 2012, 05:48 AM
(My english is Bad - Sorry)
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Originally Posted by AlmostCool View Post
I added some lighting to help with orientation recognition and low-light flight. Didn't realize these LEDs were so bright! The white ones especially.....
[]http://i1296.photobucket.com/albums/ag13/dchoi_a/hnter1.jpg[/IMG]
[]http://i1296.photobucket.com/albums/ag13/dchoi_a/hnter2.jpg[/IMG]
Beautiful with the red bottom..
Dialfonzo is offline Find More Posts by Dialfonzo
Old Nov 16, 2012, 10:33 AM
danielnc06's Avatar
United States, NC, Charlotte
Joined May 2010
AlmostCool "I added some lighting to help with orientation recognition and low-light flight. Didn't realize these LEDs were so bright! The white ones especially..."
... i believe you copied mine
I really like your light cutoff with the forward and backward facing leds....but i would have spots in my eyes after flying while staring directly at the leds..lol
danielnc06 is offline Find More Posts by danielnc06
Old Nov 16, 2012, 02:49 PM
Joined Oct 2012
You know, maybe I was subconsciously inspired by your pic...
I purposely cutoff the LEDs in preparation for FPV. Don't want any flaring in the camera view. Happy to know that the LEDs are bright enough to almost act like headlights for night time FPV flights.
AlmostCool is offline Find More Posts by AlmostCool
Old Nov 16, 2012, 06:51 PM
UAS Pilot/Tech Instructor
CryHavoc's Avatar
San Diego, California, United States
Joined Apr 2000
I got my 400 frame today. Lotta neat looking parts. Is there a build pdf ;r something I can download. I haven't waded through all 100+ of this thread so if there's a blow by blow of this build i'll go looking.
CryHavoc is offline Find More Posts by CryHavoc
Old Nov 16, 2012, 07:17 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Not at the time.
What do you need?
Old Nov 17, 2012, 02:06 AM
CryHavoc's Avatar
Joined Apr 2000
Originally Posted by Dialfonzo View Post
Not at the time.
What do you need?
Nevermind, once I got the parts identified and layed out, combined with the pics in the first message of this thread, its obvious how it goes together. I've just got it loosely assembled until I get some ESCs as I want to bury them in the arms.
Old Nov 17, 2012, 02:08 AM
Custom quad builder
tech69x's Avatar
United States, TX, Spring
Joined Apr 2012
Be sure and use blue lock tight
tech69x is offline Find More Posts by tech69x
Latest blog entry: Win a frame
Old Nov 17, 2012, 04:42 PM
Joined Oct 2012
Got a chance today to get her out in the open to see what she's capable of. No flips (sorry).
Hunter 500mm, Crius AIO Pro, 2830-920kv spinning 10x5 props.
Dialfonzo Hunter Vtail 500mm - fast flight (4 min 9 sec)
Old Nov 17, 2012, 04:46 PM
R/C Motorcycle Club-California
Kev71H's Avatar
San Jose, California, United States
Joined Apr 2002
Holy Depth perception Batman!!!!! Darn good thing you installed those lights. Would have been a mess of not it seems.
Kev71H is offline Find More Posts by Kev71H
Old Nov 17, 2012, 04:54 PM
Joined Oct 2012
Lights definitely helped! Although due to the asymmetrical shape, adjusting to orientation is much easier than a normal quad. The sun was starting to set, so the LEDs were pretty much required.
I'll try to take another vid in broader daylight someday. Maybe try a flip or two, but 3D flying is not really my style (yet). Would like to fly like Warthox someday...
Old Nov 18, 2012, 05:40 PM
Joined Dec 2011
Very cool! How did you wire up your lighting? Is is wired through the AIO, or directly to the battery / ESC? I'm looking for tips on how to add lighting to my quad...
xoxota is offline Find More Posts by xoxota
Old Nov 18, 2012, 07:32 PM
Joined Oct 2012
I use a power distribution board that has a couple pins for a JST connector. But essentially, the LEDs are wired in parallel direct to battery.
Old Nov 18, 2012, 07:45 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
On the C2F it's real easy.
LED strip wull fit right on the plate in the center of arm.
I can give you some pictures. Or make you a set...But would need some ordered
Old Nov 19, 2012, 02:07 PM
Joined Dec 2011
Sounds simple enough :-). Did you use an off-the-shelf module, or just wire the LEDs directly? What CL resistance did you use?
Thanks DF. Unfortunately, I had to take off those plates, because my ESCs wouldn't fit between them (just 1mm too wide). I'm going to try to work something out with the fit, so I can get the plates back on. Do you have a thread that explains the electrical portion of the LED setup (like which LEDs to use, what Current-limiting resistance to use, etc). Wouldn't want to fry my lighting, or worse, my battery!
Old Nov 19, 2012, 02:23 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
I use LED strip.
They are made to be wired to 12vdc and can be cut in length of 3 LED.
Each can be powered to 12vdc.
A 3 LED strip fit the side :-)
Discussion DiaLFonZo - QuadMini & TriMini Dialfonzo Multirotor Talk 734 Apr 15, 2013 09:56 AM
Discussion DiaLFonZo-Copter Crazy2Fly Quadcopter 340mm Dialfonzo Multirotor Talk 78 Mar 12, 2013 08:48 PM
Discussion DiaLFonZo-Copter TrinitY Quad V2.0 Dialfonzo Multirotor Talk 316 Mar 12, 2012 04:46 AM
Are Vtail's more effected by crosswind than R/E? fdisk Electric Sailplanes 1 Jan 19, 2003 01:05 PM
