nope they are not too fast
The 1450 are not too fast either. You could run 7" props such as the motors that go on the 1450 motos, the 8's I run on them are for over kill! Gemfam has a 7" prop that works perfect on the 1450's |
Latest blog entry: Composite 200 mm micro quad!
On mine I used 9 on the front and 8 on the back with 980 kv motors
Latest blog entry: Win a frame
![]() Warthox use a MultiWii controller. There is many controller availible. He use this board But any board with the same sensors will act just like that and will be able to do the same. To do Aerobatics he is in Gyro only mode no auto-level so any MultiWii controller with only a Gyro like This Eric Nantel (DiaLFonZo) |
I have not took time to play with the frame ... don't even have one for me.. lol I am sure more experienced use will give you better answer.. ![]() Eric |
![]() -K |
Thanks, Mike |
United States, CO, Golden
Joined Aug 2011
Yeah, one of the problems with being a newbie (I am in this boat), is that Warthox makes it look effortless. Search for his stick videos, they are really great. But, you watch the video, then you want to do it. It's easy to get discouraged. For most of us, we're talking tremendous amounts of practice to get anywhere close to what he does!!!
BTW - regarding his controller: you may notice he only has one 3-wire jumper going from the radio to the FC. Super clean setup, I think it's called CPPM, but all the signals go through a single signal wire. In some cases, I think a similar trick is possible using a spectrum satellite. |
| Thread Tools | |
| Discussion DiaLFonZo - QuadMini & TriMini | Dialfonzo | Multirotor Talk | 734 | Apr 15, 2013 09:56 AM |
| Discussion DiaLFonZo-Copter Crazy2Fly Quadcopter 340mm | Dialfonzo | Multirotor Talk | 78 | Mar 12, 2013 08:48 PM |
| Discussion DiaLFonZo-Copter TrinitY Quad V2.0 | Dialfonzo | Multirotor Talk | 316 | Mar 12, 2012 04:46 AM |
| Are Vtail's more effected by crosswind than R/E? | fdisk | Electric Sailplanes | 1 | Jan 19, 2003 01:05 PM |
