Old Mar 27, 2012, 07:32 PM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
New Product
Hunter-Vtail 400&500 by DialFonzo & Bledi
Hi All,
I am proud to introduce the Vtail by DiaLFonZo & Bledi.
This is born by an idea of Bledi that he already fly.
He contact me to make a frame that would integrate that Vtail setup into a complete
already made frame.
"RELATED MANUALS"
After many hour of design the frame was born...!!
It will be in 2 size version
400mm and 500mm motor to motor size.
The one i cut is the 500mm size
I cut the first prototype yesterday (26-03-2012) and.. i LOVE the frame.
500mm vs 400mm
Motor Hole dimension (Asked by a customer) 30mm
Should be availible from:
=============== Canada ================
info@dialfonzo-copter.com
=============== USA================
400mm Version (8" prop)
500mm Version (10" prop)
=============== France ================
=============== WorldWide================
All Versions
----- Pictures section -----
Frame cut and assembled... (23:50h ...)
To the scale... ! (300g all assembled)
500mm in two color Black & Yellow
HD Here
400mm in two color Black & Red
HD Here
Fly by Warthox...!!
mwc quad // hunter vtail 400 (2 min 19 sec)
Very first flight video... Woot Woot ...!
Hunter-Vtail First day flight ever! (2 min 44 sec)
Quadrino Flight
DiaLFonZo V-Tail Frame 500mm (8 min 12 sec)
Here are 2 of the Bledi copter that inspired the design
You can look at his Vtail flight at:
BlediARDRONE's channel
And by the time your on YouTube... look at mine too..
DiaLFonZoCopter
Very nice pictures of the VTail
They are from "danielnc06" and i thanks him a lot
HD Here
HD Here
HD Here
HD Here
HD Here
HD Here
HD Here
HD Here
HD Here
HD Here
HD Here
Dialfonzo is offline Find More Posts by Dialfonzo
Old Mar 27, 2012, 09:04 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Flight Controller setup section
--- 31-01-2014 --- Update ---
BrandXPD had done a lot of tests on VTail platforms and i thanks him a LOT.
Here are his files and Prop rotation Pinouts..
MultiWii_2_2_Flip_2_0_Hunter_400_Test
MultiWii_2_2_Flip_2_0_Mini_Hunter
--- 16-07-2013 --- Update ---
Hi All,
I have a request for me to put the manual that my friend did up here.
So here it is now.
--- 22-02-2013 --- Update ---
Ok it's quite confusing now with all the different configurations you can choose for VTail.
Here is the revised drawing that show different configuration on MultiWii
---- Yaw motor pins reversed ---
tech69x - Advice on KK board
With this mix you can't go wrong with the kk
V tale
Mine is finally up and running with the kk2... just some minor tweaking now...had to change some very random things to get a good mix....
again my setup is a kk2 with 750 kv motors 10x4.7 props, and 3 cell battery on the 400 frame...hovers around 55% throttle...this may save some people some trouble if they have a similar setup..
So initial changes... flip all prop/motors directions to (from looking over head) M1 front left is CCW, M2 front right is CW, M3 rear left is CW, and M4 rear right is CCW.
set the kk2 to VTail.. calibrate your sensors... and start with the mixer settings
CH1:
Throttle: 100
Aileron: -100
Elevator: 100
Rudder: -40
Offset: 0
CH2:
Throttle: 100
Aileron: 100
Elevator: 100
Rudder: 40
Offset: 0
CH3:
Throttle: 95
Aileron: 0
Elevator: -100
Rudder: 100
Offset: 0
CH4:
Throttle: 95
Aileron: 0
Elevator: -100
Rudder: -100
Offset: 0
Now some rough PI values (mainly just a starting point)
Roll:
P gain:55
P limit:90
I gain:30
I limit:20
Pitch:
P gain:30
P limit:90
I gain:30
I limit:20
Yaw:
P gain:40
P limit:20
I gain:20
I limit:20
Hope this can help anyone else out there. Any suggestions or errors seen from any of the experiences users?
Old Mar 27, 2012, 09:10 PM
dutchcommando is offline
Find More Posts by dutchcommando
making crashing a lifestyle!
dutchcommando's Avatar
The Netherlands, UT, Soest
Joined Feb 2012
i saw the video of the "Bledi copter" flying..
it looked great!
now i see this frame....
saweet!!!!
does it need other firmware? and what boards can one use?
dutchcommando is offline Find More Posts by dutchcommando
Old Mar 27, 2012, 09:17 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
it looked great!
saweet!!!!
I didn't fly it myself yet.
Bledi told me that Y4 setup work good.
Also in multiwii 2.0 there is vtail config
Old Mar 27, 2012, 10:44 PM
JohnyGab is offline
Find More Posts by JohnyGab
Joined May 2008
I'm currently the owner of the very first prototype of this frame. I just had a 5 minutes flight with it outside using kda motors, rushduino fc and citrus imu. Wow, that copter is a man !
Its a big boy, with a lot, i mean a big big bunch of yaw authority ! I will work with dialfonzo to give him more details, but, this thing is great !
JohnyGab is offline Find More Posts by JohnyGab
Old Mar 27, 2012, 11:24 PM
tc3wins is offline
Find More Posts by tc3wins
Multirotor Builder!!!!!
South Carolina
Joined Mar 2009
Now I thought your other frames were great this one takes the cake. I think i just found my next build . I would love to get one of these from you as fast as possible. I have a show I am going to next month and would love to show and fly something like this there.
tc3wins is offline Find More Posts by tc3wins
Old Mar 28, 2012, 12:09 AM
Bledi is online now
Find More Posts by Bledi
Bledi's Avatar
Joined Jul 2011
Oh you talk about my baby
Bledi is online now Find More Posts by Bledi
Old Mar 28, 2012, 12:43 AM
SGsoar is offline
Find More Posts by SGsoar
United States, CA, LA
Joined Aug 2007
oo.. how much?
SGsoar is offline Find More Posts by SGsoar
Old Mar 28, 2012, 12:46 AM
tc3wins is offline
South Carolina
Joined Mar 2009
Bledi, yes this is a great frame design.
Old Mar 28, 2012, 02:57 AM
Bledi is online now
Bledi's Avatar
Joined Jul 2011
Old Mar 28, 2012, 03:02 AM
tc3wins is offline
South Carolina
Joined Mar 2009
Was totally thinking that when I saw the frame. Lol...
I thought my vario copter was cool and was going to be one of my last builds for awhile then you guys came out with this frame I am totally stoke about this one.
Old Mar 28, 2012, 06:03 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Very first assembled Picture from JonnyGab
First assembly pic...
Sorry but this was going so fast.. it was cut yesterday night.. was given to JonnyGab and assembled in the evening.. so.. no Ultra clean assembly.. lol
HD Pic
Old Mar 28, 2012, 06:14 AM
Bledi is online now
Bledi's Avatar
Joined Jul 2011
You never sleep in Canada or are you too exciting
Old Mar 28, 2012, 06:20 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
I think he was too exited..
Old Mar 28, 2012, 06:34 AM
tc3wins is offline
South Carolina
Joined Mar 2009
You guys make some of the coolest frames, along with Vic20
New Product Bledi-DiaLFonZo Copter VTail HUNTER 400 CANOPY + Addons Innerbreed Multirotor Talk 42 Sep 20, 2013 09:41 PM
