Old Mar 27, 2012, 07:03 PM
Show 871 is offline
Find More Posts by Show 871
Show 871's Avatar
Joined Mar 2009
BEC & aux power can it safely be done?
I have a B25 I am using a 2-60a eflite esc....with BEC. I am using a seperate battery for rx power. Can I also activate the bec to provide power to the rx through the T channel, giving me two power sources to rx providing redundancy in the case of one power source failing?
Thanks!
Show 871 is offline Find More Posts by Show 871
Old Mar 27, 2012, 10:59 PM
C_Watkins is offline
Find More Posts by C_Watkins
This is NOT a TOY?
C_Watkins's Avatar
United States, GA, Atlanta
Joined Jul 2011
Thanks!
Not safely/reliably, without designing a circuit to allow you to do that.
If you're really wanting the redundancy, just add another battery if the extra weight isn't an issue.
C_Watkins is offline Find More Posts by C_Watkins
Old Mar 28, 2012, 04:41 AM
eflightray is online now
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
It is possible to do all sorts of configurations regarding power supplies, but they need some serious thought.
Basically servos can be supplied with power, +ive and -ive from one source, and the signal link from another, ~signal and -ive. The negatives -ive, needs commoning across the different power supplies.
This can be handy if using say retracts that may one day hang up/jam and keep the servo stalled trying to move them.
I prefer my retract servo(s), to have their own supply, just in case. It could be done with any servo, or group of servos, but will need some additional wiring.
eflightray is online now Find More Posts by eflightray
Old Mar 29, 2012, 09:26 AM
Show 871 is offline
Show 871's Avatar
Joined Mar 2009
I just look at it the bec is 6v to the rx. the battery is 6v. people plug 2 6v batteries into a rx all the time including myself for redundant power, why would the bec be different than a 6v battery providing power through the T channel?
Thanks!
Old Mar 29, 2012, 10:12 AM
This is NOT a TOY?
C_Watkins's Avatar
Joined Jul 2011
Odds are that a lot of the time it wouldn't be a problem. Depends on the circuitry design and component specs of the BEC.
Can't say for sure, in any case, without a lot more work than is feasible... or by simply making your plane the guinea pig
Sure, two batteries work great.
Paralleling in a BEC is not like just adding another battery, though.
Depending on the design, you could potentially damage the BEC.
If that happens, and it happens to fail 'shorted' rather than 'open' then you've had a bad day.
Old Mar 29, 2012, 03:11 PM
abenn is online now
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
Thanks!
When you plug two 6v (or any volts) batteries in parallel, they instantaneously pass a current between each other to get themselves to exactly the same voltage. Provided they're both at approximately the same state of charge, the amount of current is not enough to cause any problems.
But with a battery and BEC supply, the BEC is probably regulated quite well to give a constant 6v, but the battery voltage may be well over 6v initially, and could go well below 6v during use. So, in practice you might damage the BEC when you apply battery voltage to it's output (depending on what electronic protection it has built-in) and, more importantly, as your flight progresses you'll possibly get to the point where the BEC is actually doing all the work because the battery voltage has gone down to 6v.
There are electronic devices that can instantly switch from one power source to another if the first one fails, but they're generally used only for large models.
abenn is online now Find More Posts by abenn
Discussion Can a RX battery be used in combination with a BEC? twinster2 Power Systems 8 Mar 23, 2012 04:52 PM
Discussion This can be done with RC Belive me Kr1st1an Aerial Photography 5 Mar 09, 2012 09:54 AM
Discussion Can LDS be done on a DLG or is top drive as close as we can get? Fly2High Hand Launch 11 Feb 03, 2012 02:42 PM
Discussion Impossible sailing ship -- can it be done? Jpop Andrew Scale Sailboats 4 Oct 22, 2011 09:47 PM
Suggestion Is there anything that can be done about the heli sections? Zeta30 Site Suggestions / Complaints 2 Sep 23, 2011 09:50 AM
