Old Mar 27, 2012, 02:35 PM
rcta15 is offline
Find More Posts by rcta15
rcta15's Avatar
United Kingdom, England, Portsmouth
Joined Jan 2009
Help!
wing rubber band dowel location question
i need some help please, i am looking to install some rubber band wing retention on my new kfm9 glider, but i am having a bit of trouble figuring out if the dowels should go just a bit back from the le and te of the wing or should they go inline but below the le and te.
could someone please point me in the right direction plz.
many thanks RCT
rcta15 is offline Find More Posts by rcta15
Old Mar 27, 2012, 04:17 PM
sleb is offline
Find More Posts by sleb
Quads & Planes, cant beat them
sleb's Avatar
Cleveland, Ohio, United States
Joined Nov 2003
Slightly behind the LE and slightly in front of the TE. That seems to work best to hold wing down. Just Make sure to reinforce the wing with at least some tape and put the dowels thru some plywood on the inside of fuselage so it does not tear thru your foam.
sleb is offline Find More Posts by sleb
Old Mar 27, 2012, 06:11 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Like the picture looks good.
http://www.rcgroups.com/forums/showp...71&postcount=8
hoppy is offline Find More Posts by hoppy
Old Mar 28, 2012, 12:57 PM
rcta15 is offline
rcta15's Avatar
Joined Jan 2009
many thanks to you both.
RCT
Discussion Wing conversion to bolts and dowel Cromer The Builders Workshop 2 May 15, 2006 02:32 PM
GWS J3-F Dowel wing-mount reinforcement Fit Parkflyers 0 Jun 02, 2003 11:08 AM
Replacing Soarstar Wing Dowel wnielsen Foamies (Kits) 3 Jan 22, 2003 05:12 PM
Soarstar/Poppy Wing Dowel Mod? BH Foamies (Kits) 0 Jul 01, 2001 06:49 PM
broken wing dowel, any suggestions cruzomatic Electric Plane Talk 7 May 20, 2001 12:53 AM
