Old Mar 27, 2012, 02:37 AM
Australia, QLD, Booyal
Joined Aug 2011
Attaching the wing to a low winger at the field
Hi guys. I just bought my first glow plane a Phoenix scanner. I was wondering how do you guys attatch the wing without damaging the tail feathers? Do you use a stand or some thing? If so has any one got plans for a cheap one to use to be able to put in the back of the ute to get it to and from the field? Every other plane at the field is practically a boomerang 60 so I will be the first one to fly one there. ( I am also the youngest at 15)any ideas will be appreciated.
scrubmonkey is offline Find More Posts by scrubmonkey
Old Mar 27, 2012, 05:57 AM
United States, OR, The Dalles
Joined Apr 2011
I think most people either use a field box with cradles on top, or one of the foam cradles to support the fuse while attaching wings.
JeffinTD is offline Find More Posts by JeffinTD
Old Mar 27, 2012, 06:05 AM
Joined Aug 2011
Any plans for a field box with a cradle? I need to make a field box any way.
Old Mar 27, 2012, 09:52 AM
Joined Apr 2011
I wouldn't think it would be hard to make one.
I also found a link to the foam stand I have
http://www.robart.com/store/hobby-tools/airplane-stands
Old Mar 27, 2012, 10:14 AM
TigreJohn
United States, CA, Corona
Joined Aug 2008
Hobbico makes both an assembled and a kit version of their Ultra-Tote. Great Planes also makes an assembled Master Caddy. They use to offer it as a kit, but discontinued it. You find one of kicking around. Both are more than just a plane stand and are well suited for nitro use.
jjkupinski is offline Find More Posts by jjkupinski
Old Mar 27, 2012, 10:36 AM
Alex Koehn's Avatar
United States, AL, Emelle
Joined Feb 2012
I have a master caddy and I wouldn't trade it for anything. I set it up with the power panel and a hard wired fuel pump an it's got the cradles on top. VERY handy.
Alex Koehn is offline Find More Posts by Alex Koehn
Old Mar 27, 2012, 11:09 AM
DreamArcher's Avatar
Joined Apr 2008
Depends on the plan I guess. For my Escapade I just gently lay it on the canopy and tail. You don't want to abuse your planes but they're not new-born baby unicorns... they should be strong enough to lay on their back. Heck if you nose over on landing they will take a much harder hit than that.
On the other hand when I'm done with my P-51D it will be about 6 months of work. I will not be laying on it's back.
DreamArcher is offline Find More Posts by DreamArcher
Old Mar 27, 2012, 03:11 PM
Fla.
Joined Apr 2005
As a quickie to use as a sample and temporary stand, just take a cardboard box and cut some "U" shaped holes in each end and set the plane in it. When you get it the way you like it , make one out of something more solid. ENJOY !!! RED
redh is offline Find More Posts by redh
Old Mar 27, 2012, 05:34 PM
United States, SD
Joined Aug 2010
http://www.rcgroups.com/forums/showt...ight=pvc+stand This looks like a goo idea.
Kyler1 is offline Find More Posts by Kyler1
Old Mar 27, 2012, 05:52 PM
Joined Aug 2011
It would be good if it also be used to get it to and from the field in the back of the ute. It is usually my dad and I in the ute. The wing will fit inside the cab but the fuse will have to go in the back
Old Mar 27, 2012, 07:45 PM
Scirocco14's Avatar
Asheville, NC
Joined Mar 2009
I finally broke down and bought an Ernst stand. Someone else had one at the field and I liked it a lot. Cheap and does the job. Even has trays underneath the plane so you don't lose the wing bolts, etc.
Hope this helps,
Mark
Scirocco14 is offline Find More Posts by Scirocco14
Latest blog entry: Changes and updates
Old Mar 27, 2012, 08:21 PM
United States, CO, Arvada
Joined Nov 2010
I just put the nose on my shoe and hold the plane like a cello, holding the wing in front of me and the plane and install the bolts, no problem.
cherokeenut is offline Find More Posts by cherokeenut
Old Mar 27, 2012, 08:22 PM
Alex Koehn's Avatar
Joined Feb 2012
Does it come with some type of padding so it's not just the plastic scratching around on the plane? Doesn't matter jus curious...
Old Mar 27, 2012, 08:36 PM
I bail out, anywhere, anytime
Taurus Flyer's Avatar
The Netherlands, OV, Almelo
Joined Nov 2010
Custom made, foldable, cheap.
Designed to use the fuse inverted too, to mount the wings.
Taurus Flyer is online now Find More Posts by Taurus Flyer
Old Mar 27, 2012, 09:21 PM
United States, SD
Joined Aug 2010
There was a pvc plan somewhere on the forum, but I cannot remember where.
Sold Low wing 60 size sport plane rtf .Pick up at Sac Swap Meet.ONLY $100 sweintraub Aircraft - Fuel - Airplanes (FS/W) 0 Oct 15, 2011 03:30 PM
Discussion How to attach prop OS .46LA (rattle noise at low speed) Diesel 48 Beginner Training Area (Fuel) 5 Jul 16, 2008 01:52 PM
Discussion A better way to attach a High/Low wing? Evan Byrne Slope 11 Apr 15, 2006 02:10 AM
Balancing a low winger leccyflyer Electric Plane Talk 4 Sep 29, 2003 10:31 AM
Glitch spots in the field at low altitude... and sprinkler systems, any relationship? flipnidaho Electric Plane Talk 1 May 23, 2003 07:50 AM
