Old Mar 27, 2012, 12:38 AM
jacojet is offline
Find More Posts by jacojet
jacojet's Avatar
South Africa, Free State, Sasolburg
Joined May 2010
Avonds Rafale
I have a Phillip Avonds rafale, and I need some suggestions for a fan set-up that will produce the thrust AND speed to suit this plane. Was thinking Ramtec, but now I am wondering about the new 110 stumax? Anyone out there with experience with this aircraft?
jacojet is offline Find More Posts by jacojet
Old Mar 27, 2012, 06:32 AM
Robert Belluomini is offline
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
I'm sure the new 120 would work great. I've always wanted to do one of these as a twin. Two of the 80 mm on 8S would be very sweet!
Robert Belluomini is offline Find More Posts by Robert Belluomini
Old Mar 27, 2012, 07:17 AM
hoser is offline
Find More Posts by hoser
shut up & fly
hoser's Avatar
United States, FL, Miami
Joined May 2001
what's it weigh, i have heard that they are a bit on the heavy side
hoser is offline Find More Posts by hoser
Old Mar 27, 2012, 10:32 AM
jacojet is offline
jacojet's Avatar
Joined May 2010
It should be about 8kg all-up. bare air frame is 3.5kg, retracts 850g, batt about 1.8kg, servos x6 300g, motor and fan about 900g and then all other accessories. Should be close to 8kg.
Old Mar 27, 2012, 10:47 AM
Mikael is offline
Find More Posts by Mikael
Mikael's Avatar
Sollentuna,Sweden
Joined Sep 2000
I flymine with XPS/dynamax 14s6600 XPS 45c, it's very heavy ca: 9,3kg
I've made alot of repairs on mine after a crasch, so it's heavier because of that.
It flies great but it's a bit hot on landing.
Mikael
Mikael is offline Find More Posts by Mikael
Old Mar 27, 2012, 12:55 PM
jacojet is offline
jacojet's Avatar
Joined May 2010
Looks very good! Now I have to finish mine! You don't have plans for it? I need to replace the 3 formers in the engine bay on mine. Would make it easy if I can get the shape printed and then cut the wood.
Thanks for posting!
Old Mar 27, 2012, 02:35 PM
Mikael is offline
Mikael's Avatar
Sollentuna,Sweden
Joined Sep 2000
Sorry, no plans
Old Mar 27, 2012, 06:29 PM
hoser is offline
shut up & fly
hoser's Avatar
Joined May 2001
9.3 thats heavy
Old Mar 28, 2012, 12:26 AM
jacojet is offline
jacojet's Avatar
Joined May 2010
I have a friend who has a fly-eagle rafale witch is slightly smaller and weighs 8.8kg. Flies good on 12s. I contacted Phillip Avons, he said 9kg will be fine.
Old Mar 31, 2012, 03:02 PM
Mikael is offline
Mikael's Avatar
Sollentuna,Sweden
Joined Sep 2000
jacojet
Here are some pictures of the geardoors, let me know if you need more.
I'm in the process of renovating the doors and paint so they don't look so nice right now. Hopefully in a month it will look much better.
Old Apr 04, 2012, 04:12 PM
jacojet is offline
jacojet's Avatar
Joined May 2010
Thanks, that will help!
Old Apr 04, 2012, 06:05 PM
mungrelv8ute is offline
Find More Posts by mungrelv8ute
mungrelv8ute's Avatar
Belgium, Flemish Region, Sint-Katelijne-Waver
Joined Apr 2003
I have a friend in my club flying the model on 12S with a Turbofan 4000, nice flyer, good take-off performance of grass but the sound is kuk.
I would recommend Tam's TJ120 on 12S. I am really impressed with this fan, I have one in a Skymaster ViperJet with around 40 fights. Great performance and even better sound.
Buy the plug and play version, that way you know everything works and is backed by Tam.
With this combination you will be under 8kg.
Gregg
mungrelv8ute is offline Find More Posts by mungrelv8ute
Old Apr 12, 2012, 03:20 PM
jacojet is offline
jacojet's Avatar
Joined May 2010
Thanks for the advice. I have a ramtec in it for now, if it flies good, I will upgrade it to something like the tam fan. I will maiden her this weekend with a ready to fly weight of 7.5kg. I am also trying the e-flight 60-120 electric retracts on her, we will see how they hold. can you post the data of the tam fan in the viper? mah, amps and flight time?
Old Apr 12, 2012, 05:48 PM
Joined Apr 2003
Tam 120 draws around 130A on a 12S 6500mAh pack. With throttle management I'm getting 6:30 flights and I am using the battery telemetry from iisi-rc which is very good. Lets you know when your packs are nearly empty. You can set an alarm for remaining capacity, like 25%
http://www.iisi-rc.com/IISI-RC/Home.html
What motor do you have with your Ramtec?
Old Apr 13, 2012, 12:27 AM
jacojet is offline
jacojet's Avatar
Joined May 2010
Its the scorpion 4035 630kv, 101amps, 4500 watts. I am battling to get it to run very smooth, tried all the usual methods of balancing, still not happy. It would seem that the shaft adapter is the culprit.
Discussion HK ProEDF Rafale twin 70mm CG? RobNHood Electric Ducted Fan Jet Talk 4 Aug 25, 2012 12:13 PM
For Sale 1/9 Scale F15 Jet moulds for sale (Like Avonds) rapidrabbit Aircraft - Fuel - Jets (FS/W) 2 Feb 07, 2012 05:19 AM
For Sale Avonds F-14 Planset (Hobby Barn) WINDSHEAR II Aircraft - Fuel - Jets (FS/W) 1 Sep 09, 2011 02:13 PM
Discussion Avond's F-14 bdeath30 Power Systems 1 May 29, 2009 01:57 PM
Discussion Fly Eagle Jets/ EDF Rafal Ron101 Electric Ducted Fan Jet Talk 4 Apr 06, 2008 02:10 PM
