Old Mar 26, 2012, 08:09 PM
out of stock is offline
Find More Posts by out of stock
Speed only
out of stock's Avatar
United States, FL, Lehigh Acres
Joined Jan 2012
Question
sbach 342 canopy tint advice?
the photos below are self explanatory lol
how can i tint the canopy to that bluish color? if its possible. what material are these canopys made from? plastic? is plastic tintable? i think arf manufacturers should do this.
sensible answers welcomed please. thanks for visiting! and forgive me if im in the wrong section.
out of stock is offline Find More Posts by out of stock
Old Mar 26, 2012, 11:38 PM
eagle777 is offline
Find More Posts by eagle777
Closed Account
Joined Aug 2007
I like the Tamiya translucent smoke . One coat is a light tint, 3 is dark:
http://www.hobbylinc.com/htm/tam/tam86031.htm
I haven't tried this, but it looks like what you are looking for.:
http://www.hobbylinc.com/htm/tam/tam86039.htm
I would be interested to hear what you find out. This is 4 coats of Tamiya Smoke.
Edit, your post caught my attention because I have the same model. I looked at my Slipstream Sbach 342, and it already has yellow tint on the canopy. It would look cool with blue, but I have no idea what it would look like after painting.
eagle777 is offline Find More Posts by eagle777
Old Mar 27, 2012, 12:23 AM
Herman Munster is offline
Find More Posts by Herman Munster
Herman Munster's Avatar
United States, Mt, Libby
Joined Nov 2007
The translucent Blue that eagle 777 linked is what you want. Just use light coats and allow to dry (10-15 minutes) between coats to make sure you aren't getting it too dark and to avoid runs.
Herman Munster is offline Find More Posts by Herman Munster
Old Mar 27, 2012, 12:45 AM
lindart is offline
Find More Posts by lindart
Art Schmitz
United States, TN, Crossville
Joined Jan 2012
Some plastics can be dyed with RIT clothing dye found in most grocery stores. The longer the part is submerged the darker it gets. I've used both blue and black RIT.
lindart is offline Find More Posts by lindart
Old Mar 27, 2012, 01:27 PM
Speed only
Joined Jan 2012
You guys rock! !
Old Mar 27, 2012, 02:52 PM
Speed only
Joined Jan 2012
Hey but wouldn't the tamiya look way to dark? So far its at the top of my list until i find something more assuring. I'm thinking an actual blue tint like for glasses
Old Mar 27, 2012, 04:06 PM
dkrhardy is offline
Find More Posts by dkrhardy
United States, FL, The Villages
Joined Oct 2010
lindart is 100%. Plain old Rit fabric dye is very good on most plastics and gives an even finish. Keep it submerged but take it out every minute or so to check color.
Don
dkrhardy is offline Find More Posts by dkrhardy
Old Mar 28, 2012, 12:52 AM
Speed only
Joined Jan 2012
Don
thanks. ill definitely look into that. does rit have blue available?
Old Mar 28, 2012, 10:02 AM
dkrhardy is offline
Joined Oct 2010
Are you kidding? They have colors you have NEVER heard of, and variations of THOSE colors.
Don
Old Mar 28, 2012, 12:47 PM
Fravits is online now
Find More Posts by Fravits
Joined Nov 2006
I have tinted a few canopies using the Rit dye method. Great results! Using the black gives a really nice smoked effect and, as mentioned earlier, the longer you leave it in the solution, the darker it gets. Think I'll try some of the other colors on future projects.
Fravits is online now Find More Posts by Fravits
Old Mar 28, 2012, 01:30 PM
Speed only
Joined Jan 2012
awesome!! my only fear is that it will come out too dark. so i should let it sit for a bit and check on it every minute yea?
how exactly is this done? hot water? warm? cool? again thanks!
Old Mar 29, 2012, 01:20 PM
tacx is offline
Find More Posts by tacx
tacx's Avatar
United States, MI, Romeo
Joined Apr 2009
What ever method you choose MAKE SURE that you wash the canopy with a little dish soap and rinse it well. There is release agents still on the new canopy that will hinder the adheshion of the dye or the spray.
It makes a huge difference. GET IT CLEAN!!!!
tacx is offline Find More Posts by tacx
Old Mar 29, 2012, 03:15 PM
dkrhardy is offline
Joined Oct 2010
Follow the dye instructions. BUT if they say boil it, go ahead and do that BUT let it cool some before you drop the canopy in it. I'm not sure that canopy plastic can hold it's shape in BOILING water. And, yes, check it every minute or so for amount of color. You need to keep it submerged, not floating and bobbing. Place something on it to keep it under. GOOD LUCK.
Don
Old Mar 29, 2012, 04:08 PM
lindart is offline
Art Schmitz
Joined Jan 2012
I 've used hot tap water and actually stored the dye water for later use.
Thorough washing of the part ,as mentioned, is essential.
By all means, WEAR RUBBER GLOVES !
Check the part frequently for desired tint. Wash off with plain water when satisfied.
There are some cheap plastics that won't take the dye.
Hint: the plastic control horns can also be tinted in most cases.
Old Mar 29, 2012, 07:42 PM
eagle777 is offline
Closed Account
Joined Aug 2007
And while you are doing all of this, MAKE SURE TO HAVE FUN!
Sold NIB Dynam Sbach 342 Receiver ready warbirdguyn951 Aircraft - Electric - Airplanes (FS/W) 19 Mar 10, 2012 07:01 PM
Discussion Hobby King MX2 vs. SBACH 342 (1400mm) cheynespub 3D Foamies 15 Mar 06, 2012 10:01 PM
Discussion Best Sbach 342 ARF raf37 Giant Scale Airplanes 4 Mar 01, 2012 05:25 PM
Alert - SOLD - Eflite UMX Sbach 342 + 2 batteries + charger + spare prop - $100 Billbor Atlanta Area RC 5 Feb 26, 2012 12:18 AM
Discussion HobbyKing - Sbach 342 73" boiko 3D Flying 1 Feb 23, 2012 12:41 AM
