Old Oct 22, 2003, 06:15 PM
davidleitch is offline
Find More Posts by davidleitch
Tragic case
davidleitch's Avatar
Sydney Australia
Joined Feb 2002
Bigger gliders, bigger $ and big choices
Help me decide.
I am trying to work out if a fully molded 3 metre e glider will fly much differerently (better) to my 100 inch organic.
How will the performance of an E graphite or Stratos differ to the organic?
Secondly: Which big E glider should I choose? I want a thermalling hotliner.
Fast climbs, wide speed range, ability to do fast runs but also tight low speed circles, easy to land and easy to transport.
The obvious choices seem to be the Stratos and the Graphite, or possibly a Stork. The only disadvantage of the Stratos I can see is the one piece V tail which will be a nuisance for transport. The graphite appears to be limited to 12 cells.
How long is the fuselage on the graphite or stratos?
The reason for asking is that Xmas is approaching and the stars are in alignment.
All advice and comments are appreciated. It probably costs the best part of $2000 to get something like this in the air, so I hope to avoid doing it twice.
thanks
dave
davidleitch is offline Find More Posts by davidleitch
Old Oct 22, 2003, 06:44 PM
Doc Data is offline
Find More Posts by Doc Data
United States, FL, Starke
Joined Apr 2002
Dave,
I own the TD version of the Stratos and both E and TD versions of the Graphite (actually I have 2 fuzes for the same wing, both fuzes are cross-tails). I fly strictly TD with them so I could not tell you about their hotliner abilities, if any.
The cross tail E-Graphite fuze is about 53.5" long including a spinner. I feel it flies substantially better than the Organic which, of course, is saying something! My Stratos is a cross tail TD also so my fuze length won't help According to the ShredAir site, the fuze is 57+".
Why do you feel the Graphite is limited to 12 cells? I have a Kontronik 500-27+6.7:1, a 12 cell pack of CP1700SCR's (zapped) and an 18.5x12 prop. It climbs straight up! Although I haven't tried it, if you built a pack with 1 row on top of 2 rows, it looks like you could fit at least 21 cells (3 rows of 7).
I think both planes fly very similarly although I am still dialing in my Graphites. The Graphite is also more than $200 less.
Dave
Doc Data is offline Find More Posts by Doc Data
Old Oct 22, 2003, 07:01 PM
Tragic case
Sydney Australia
Joined Feb 2002
Dave
Thank you for your thoughts, I was hoping you'd chime in.
Someone (Paul Ferradas?) mentioned that there might be a CG issue with more than 12x2400 cells. Probably 12 cells is what I would start with anyhow, as I have a 10 cell motor that could be pushed to 12.
regards
Dave
Old Oct 22, 2003, 07:35 PM
Doc Data is offline
Joined Apr 2002
That's probably true. I'm sure I could get a few more cells in and still get it balanced but I'm extremely pleased with the performance I'm getting. In the cross tail version you put the elevator and rudder servos in the tail fin.
http://www.azflight.com/daw/graphite...pics/index.htm
Which one are you considering if you got with the Graphite? Xtail or Vtail?
Dave
Old Oct 22, 2003, 08:01 PM
Tragic case
Sydney Australia
Joined Feb 2002
Xtail. I am assuming the stab/elevator can be removed for transport? A 54" fuselage may fit in the back of my hatchback. Its nice to keep the plane in the car so as to fly before work.
Price is a (big) factor, especially in $A=$US0.7, but I've always been partial to the look of the Stratos.
Old Oct 22, 2003, 08:06 PM
Tragic case
Sydney Australia
Joined Feb 2002
Relooking at Dave Wenzlick's photos, I can see a lot of areas for an all thumbs person like myself to stuff up the servo installation in the Graphite tail.
Old Oct 22, 2003, 08:07 PM
Doc Data is offline
Joined Apr 2002
I store my fuze with the nose cone off. This allows me to charge the battery and, in your case, would make the necessary space much shorter. The nose cone contains the motor and battery.
Here's the electric...
http://www.mustangone.com/MyRCHanger/GraphiteE1.jpg
http://www.mustangone.com/MyRCHanger/GraphiteE2.jpg
Dave
Old Oct 23, 2003, 02:04 AM
Tragic case
Sydney Australia
Joined Feb 2002
Dave
Your graphite is tres cool, and the flying field looks pleasant as well.
I do think I want a glider that is the electric eqiuvalent of F3B, that is its competitive at distance and speed tasks as well as thermal duration.
I guess that means pushing up the wing loading a bit.
The organic is strong enough for those tasks but I have a low wing loading and then energy retention is accordingly low. The narrow fuselage in the organic is not well suited to upping the battery count.
Old Oct 23, 2003, 02:58 AM
Vic Peh is offline
Find More Posts by Vic Peh
Singapore
Joined Jul 2003
David,
Sounds that you're looking for the perfect glider...
The X-Models X-Calibur seems to be a good contender too.
Vic Peh is offline Find More Posts by Vic Peh
Old Oct 23, 2003, 06:48 AM
Doc Data is offline
Joined Apr 2002
Dave,
It sounds like you really want the Stratos Sle. If you can bear the extra cost, its the plane you're looking for. It can take lots of batteries, strong and looks great.
I don't see how you can go wrong (as long as it will fit in your car).
Dave
Old Oct 23, 2003, 09:33 AM
rorywquin is offline
Find More Posts by rorywquin
Turbines suck ;-)
United Kingdom, Hillam
Joined Mar 2000
http://www.mustangone.com/MySailPlanes/GraphiteE1.jpg
http://www.mustangone.com/MySailPlanes/GraphiteE2.jpg
Dave
I would like one of thioe stands but, here in the UK the materials would cost about 40-00!
rorywquin is offline Find More Posts by rorywquin
Old Oct 24, 2003, 10:06 AM
Doc Data is offline
Joined Apr 2002
PCV pipe is that expensive? It only cost me a few dollars.
Here are the plans for it...
http://www.mustangone.com/MySailPlanes/stand.html
Dave
Old Oct 24, 2003, 10:18 AM
JDubman is offline
Find More Posts by JDubman
Joined Dec 2002
Ellipse 4 all the way!
JDubman is offline Find More Posts by JDubman
Old Oct 24, 2003, 04:27 PM
Tim Green is online now
Find More Posts by Tim Green
Launch the drones ...
Ashtabula, OH USA
Joined May 1999
I fly my eGraphite (V-tail) with 14 CP 1700 cells. This is a flat pack, of two columns of 7 cells each, soldered end to end. I could go to 16 cells (there's room), but it already climbs vertically with the 14. Note that I don't feel the need to go to 2400 cells, because I get 3+ climbs to spec height as it is.
Tim Green is online now Find More Posts by Tim Green
Old Oct 24, 2003, 04:49 PM
JDubman is offline
Joined Dec 2002
sounds like you want a E4!
Little creeping invasion of privacy issues... big brother is getting bigger fprintf Life, The Universe, and Politics 24 Jan 30, 2005 06:44 PM
Small prop, big cowl --> bigger prop, bigger spinner? LedKitty Electric Plane Talk 5 Oct 15, 2003 03:43 PM
