Old Mar 26, 2012, 06:58 PM
gefisher is offline
Find More Posts by gefisher
Joined Jun 2008
Need a little help on a JR 9303!
Has anyone ever replaced the gimbal springs inside a JR transmitter? I have a JR 9303 that I have had for a couple years and Saturday I had a aileron tension spring let go! Just a little startling but not bad…… Anyway I would like to change all of them out while I have it apart but it looks a little tricky! Need some advice if you have tackled this before.
Gary
gefisher is offline Find More Posts by gefisher
Old Mar 26, 2012, 09:03 PM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Gary
There's nothing very hard about it but you do need pliers with long, fine nose to get down in there. To install a spring, you just grab it with the very tip of the pliers, hook the other end onto the peg, and slip this end over the end of the scissor lever. The only tricky bit is getting a grip on the spring that doesn't prevent you from slipping it on. It usually takes me a couple of tries.
I've never had a spring break but I have had the gimbal apart for other reasons.
All the JR transmitters work in a similar fashion, by the way.
Daedalus66 is offline Find More Posts by Daedalus66
Discussion I need a little help finding some hardware, for a piston tank. asd9000 Submarines 8 May 01, 2012 09:55 PM
Question Need a little help picking a 2m - 3m floaty thermal glider muchalucha Thermal 37 Apr 28, 2012 02:38 PM
Discussion Little help with flaperons on my UMX Extra joefear7 Micro Ready-to-Fly 2 Mar 11, 2012 08:06 PM
Help! Jr 9303 wont turn on capt soap Radios 15 Nov 03, 2011 02:56 PM
Question HeLp using JR 9303 trainer system Tabasco Radios 5 Oct 12, 2011 03:37 PM
