Old Mar 26, 2012, 06:04 PM
gauiguy200 is offline
Find More Posts by gauiguy200
Alabama
Joined Jul 2010
Need a Charger for my AirField Sky Trainer Upgraded Version Airplane.
Any suggestions on which charger I should get? Not sure what the connectors are on the battery pack....I'm guessing bullet, but not sure.
gauiguy200 is offline Find More Posts by gauiguy200
Old Mar 26, 2012, 06:28 PM
freechip is offline
Find More Posts by freechip
freechip's Avatar
Joined Aug 2008
You normaly don't buy a charge for a plane but rather a charger for all your batts.
Knowing what kind of batts you have and what king of charging you are looking for would reduce the list of possible candidates.
Charge in house only, charge at the field only or Both?
When it comes to chargers then most important numbers to look at are the WATT output specs, knowing that number will also help you to find a good value of Watt per $$$ so you make a wise purchase.
freechip is offline Find More Posts by freechip
Discussion AirField Sky Trainer Upgraded Version ESC Question gauiguy200 Electric Plane Talk 3 Mar 27, 2012 06:59 PM
Discussion AirField RC 55" Sky Trainer Upgraded Version Question gauiguy200 Electric Plane Talk 2 Mar 25, 2012 03:49 PM
Discussion Airfield sky trainer help!!!!!!!!!!!!!!!!!!!! BIG MARINE Scale Kit/Scratch Built 1 Mar 04, 2012 11:04 AM
Discussion Need suggestions on reattaching nut to fuselage on Dynam Sky trainer older version. iquench01 Beginner Training Area (Aircraft-Electric) 2 Oct 10, 2011 02:29 PM
