Old Mar 26, 2012, 05:55 PM
Denominator is offline
Find More Posts by Denominator
Denominator's Avatar
Norway, Hedmark, Hamar
Joined Sep 2009
Sorry for all the? But need help with slow motor/ESC
I'm done building my quadcopter.Updated to KKQuadControllerV4_7_X before I did any intial setup of the ESC and now I can't find any info to how I set the ESC's. 3 of my motors are in sync, but one only turn on when I get past 50-60% on the throttle stick. Do I need to change setup for that ESC or is the motor or ESC broken?
The other motors starts to spinn if I only give it small amount of throttle but not the rear right motor.
Denominator is offline Find More Posts by Denominator
Old Mar 26, 2012, 06:13 PM
teslahed is offline
Find More Posts by teslahed
Joined Jul 2008
Most likely you will need to reflash the firmware of your KK controller to fix the problem. I believe there was a bug in some versions that could cause the 4th motor to lag behind on throttle inputs.
I had the same problem and fixed it by reflashing my board.
Look at this post;
http://www.rcgroups.com/forums/showp...5&postcount=73
for the version of the firmware that works for me.
Edit - there's a whole thread on the problem here;
http://www.rcgroups.com/forums/showthread.php?t=1587021
teslahed is offline Find More Posts by teslahed
Old Mar 26, 2012, 06:24 PM
Joined Sep 2009
That is the version of the firmware that I flashed it to. Strange that it works for you but not for me :/
Old Mar 26, 2012, 07:06 PM
Joined Sep 2009
As I read the threads I noticed someone write that the yaw pot was reverced.
Turned it the other way and followed the setup esc guide and now it works perfectly!
Thank you!
Discussion need help with finding a new motor for AJ slick epoweredrc Atlanta Area RC 10 Mar 23, 2012 07:34 PM
Discussion Still learning but a video from the other day - slow-mo help with 60i? slowjett Aerial Photography 5 Mar 20, 2012 09:51 AM
Discussion Sorry but I need help walshy155 Electric Ducted Fan Jet Talk 55 Oct 25, 2011 11:00 PM
Help! all the parts needed for a new GWS slow stick NP kit ? cyclops2 Foamies (Kits) 1 Sep 08, 2011 02:33 PM
Need help with motor choice for GIANT Slow Stick Turbo442 Power Systems 0 Apr 30, 2004 01:58 PM
