Old Mar 26, 2012, 01:34 PM
asd9000 is offline
Find More Posts by asd9000
United States, FL, Tampa
Joined Nov 2009
I need a little help finding some hardware, for a piston tank.
I am looking for some parts to make a micro syringe piston tank using a BBQ injector. But the issue I am having is finding a gear that is threaded on the inside to lift my nylon threaded bar. Could some of you suggest somewhere where I could find some stuff like that? Or at least what its called.
similar to this set up.
Mini RC submarine ballast tank test 2 (0 min 27 sec)
Trying to get my supplies together to convert an academy 1/150 boat. And I figured I could just stick a radio in it and link the control surfaces and dynamically dive it... but whats the fun in not challenging yourself
Thanks ahead of time
asd9000 is offline Find More Posts by asd9000
Old Mar 26, 2012, 06:03 PM
CaptainNemo12 is offline
Find More Posts by CaptainNemo12
RC sub dude
CaptainNemo12's Avatar
Montreal, Quebec, CANADA
Joined Nov 2004
How about using a metal nut that will fit your threaded rod and embedding the nut inside a plastic gear?
CaptainNemo12 is offline Find More Posts by CaptainNemo12
Old Mar 26, 2012, 07:14 PM
jeno is offline
Find More Posts by jeno
United States, ME, Bar Harbor
Joined Sep 2005
Stock Drive Products www.sdp-si.com has a vast array of gears ect. that should help.
Also try calling Precision Scale Model Engineering( the web site does not show the catalog)
jeno is offline Find More Posts by jeno
Old Mar 27, 2012, 01:39 AM
asd9000 is offline
Joined Nov 2009
That's what I plan on doing if I cannot find anything else. And does metal on nylon offer better results? Just curious that statement made me wonder :P
Thanks for the help so far!
Old Mar 27, 2012, 06:53 PM
Sub culture is offline
Find More Posts by Sub culture
Man from Atlantis
Sub culture's Avatar
London
Joined Nov 2003
Looks to me like he has just drilled and tapped the main gear with a thread. Usually piston tanks use a metal spindle and spigot. For a small tank like this, you can get away with plastic.
Sub culture is offline Find More Posts by Sub culture
Old Mar 28, 2012, 05:24 AM
derk is offline
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
best bet is to drill and tap, otherwise its a huge pain to get the nut centered on the gear properly.
derk is offline Find More Posts by derk
Old Apr 03, 2012, 07:49 AM
Rmay is offline
Find More Posts by Rmay
Rmay's Avatar
Louisiana
Joined Sep 2006
This may be a crazy idea, but how about scavenging parts from a screw type deodorant? I took one apart the other day and it looks like the parts are similar to what you’re looking for. That is if you looking for a DIY solution.
Rmay is offline Find More Posts by Rmay
Old Apr 04, 2012, 11:33 PM
asd9000 is offline
Joined Nov 2009
hmm I ll look at one I like the idea! thx for the suggestion. I built a prototype but its belt drive... aka rubberband. and I need gears now. I just bored out and tapped a gear. Used a bearing to hold it in place and a brass screw.
Old May 01, 2012, 09:55 PM
jshander is offline
Find More Posts by jshander
Waukesha, WI
Joined Dec 2006
another source for threaded plastic rod
Parmesan cheese with built in grater also has a nice mechanism.
jshander is offline Find More Posts by jshander
Wanted *NEED HELP* Finding Projects For Gifted Senior Builders stevster Aircraft - Electric - Airplanes (FS/W) 16 May 10, 2012 01:50 PM
Wanted *NEED HELP* Finding Projects For Gifted Senior Builders stevster Boats (FS/W) 17 Apr 01, 2012 08:51 AM
Wanted *NEED HELP* Finding Projects For Gifted Senior Builders stevster Aircraft - Fuel - Airplanes (FS/W) 15 Mar 17, 2012 12:11 PM
Help! *NEED HELP* Finding Projects For Gifted Senior Builders stevster Trader Talk 7 Mar 16, 2012 03:59 AM
Discussion need help finding some plans for a build elijah4 The Builders Workshop 3 Dec 11, 2011 03:04 PM
