Old Oct 22, 2003, 06:00 PM
Paul McIntosh
Paul McIntosh
Guest
n/a Posts
Re: why wont my thundertiger gp42 rev at full throttle for long before cutting out
Because it probalby isn't tuned properly. A little more explaination of how
you are adjusting it would help.
Paul McIntosh
Desert Sky Model Aviation
http://fly.mcintoshcentral.com
"scaff" <lee.wilson10@btinternet.com> wrote in message
news:ewAlb.156$wO.69@newsfep1-gui.server.ntli.net...
Old Oct 23, 2003, 06:00 PM
Harry Kolomyjec
Harry Kolomyjec
Guest
n/a Posts
Sounds like it could be the same problem as the GMS 47. Try backing out the
idle screw (make it richer). Set up the high end before the idle.
Then after each idle adjustment, reset the high end again.
Paul McIntosh
Paul McIntosh
Guest
n/a Posts
The Thunder Tiger GP series engines use air bleed carbs so the reverse is
true. Basically, you set the high speed for proper running then adjust the
airbleed in for richer and out for leaner. If the engine will not run at
more than half throttle, there is something restricting fuel flow since the
main needle does all of the fuel meterings and the air bleed only
compensates for the richer mixture at low throttle openings.
Paul McIntosh
"Harry Kolomyjec" <harryk01@comcast.net> wrote in message
news:1q-dnWwrrJpneQqiRVn-hg@comcast.com...
the
Help! Why my HET-RC - Typhoon EDF 2W has micro failiures/at full throttle marcoblum10 Electric Ducted Fan Jet Talk 8 Sep 13, 2006 06:00 PM
Question Why does my BM2408-1 surge at full throttle? glydr Australia 10 Jun 15, 2006 08:49 PM
