Old Mar 26, 2012, 12:26 PM
Pyrolator is offline
Find More Posts by Pyrolator
Joined Mar 2012
Vintage: Futaba Super 7 - 4 servo wing Air brake / Crow!?
I have got two of these radios and as they are perfectly alright I don't see a need to upgrade.
To be precise it's a Field Force Super 7 FP-7UPS (UK?) transmitter.
I have the instruction manual and Don Edberg's "Programming the Futaba Super 7 Radio System" book and still stuck! I've built myself a demo jig just to check the servos and travels.
I'm trying to set up a four servo wing glider for ailerons, flaps and crow. I am trying to follow the descriptions but nothing in there seems to work as described.
The air brake function seems really elusive. Has anybody got it to work and give me a hand?
Can it be really that difficult? Lot's of odd things happening...
Thank you!
M
Pyrolator is offline Find More Posts by Pyrolator
Old Mar 26, 2012, 06:32 PM
jbogdano is offline
Find More Posts by jbogdano
United States, VA, Arlington
Joined Mar 2005
Plug the ailerons into positions 1, 7, and the flaps (both servos) into position 6. Enable differential, and go into the glider menus. You can select Start and Speed mixing to get the camber to do what you want. It took me a while to figure this out from the manual alone, but it can be done. There may also be a way to get aileron -> flap mixing, but I haven't figured that out yet on the 7uaf. Good luck with this great radio.
jbogdano is offline Find More Posts by jbogdano
For Sale Vintage Super Call-Air Cadet Decals redball8 Aircraft - General - Miscellaneous (FS/W) 0 Mar 10, 2012 12:00 PM
Sold Seven 7 Servos 4 Futaba 1 GWS 1 FMA 1 POWER HD Mahu Aircraft - General - Radio Equipment (FS/W) 0 Nov 06, 2011 02:37 PM
Discussion Step-by-Step: Futaba FASST 7C, 4-servo wing, V-Tail, Crow Complete Guide Haole Radios 13 Jan 09, 2011 07:46 AM
Question Flaps set-up 4-servo wing + question Futaba T9CAP Super aeronaut999 Sailplane Talk 7 Feb 24, 2009 02:12 PM
Question Help ! Futaba FF9 Super (9c) / Blade 1.9 crow-brake problem - need stick reversed MoNkEe Radios 11 Oct 24, 2006 07:21 PM
