Old May 26, 2012, 02:47 PM
Shawnner is offline
Find More Posts by Shawnner
Joined Mar 2012
Okay - thanks! That makes a lot of sense. I'm really excited, cannot wait to see some solid rooster tails again.
Shawnner is offline Find More Posts by Shawnner
Old May 26, 2012, 02:55 PM
KFC is offline
KFC
Find More Posts by KFC
KFC
Blue Foam Master!!!
KFC's Avatar
United States, KY, Hanson
Joined May 2007
Originally Posted by Shawnner View Post
I like that thinking. I can run lipo without all the cut off settings set up by the new esc systems? Sorry for such noob questions.- I've read all the "read this first" type posts on lipo and still feel overwhelmed.
I would NEVER run a LiPo in a boat without the cutoff set. The reality is that very bad things happen when you get these packs below 3v per cell.
KFC is offline Find More Posts by KFC
Old May 27, 2012, 12:18 PM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
^^ Cutoffs are only good if you're pushing packs hard... I can FULLY empty the pack in my stadium truck (5400mah back into a 5000mah pack) before it hits the LVC (which is set to 3.7v/cell on my ESC). Even the LVC in my Motley Crew doesn`t come in early enough to not over discharge the packs (I consider taking more than 80% out of them over discharging).
I much prefer to time my runs and go by feel than to rely on the LVC.
wparsons is offline Find More Posts by wparsons
Old May 27, 2012, 03:45 PM
Shawnner is offline
Joined Mar 2012
Since my boat is already set up for older 540 sized motors, like my Astroflight 05 cobalt it seems I'll need to stick with that 3650 or similar leopard motor.
The specs on the old Astroflight box state 400 Watts @ 24,000 rpm for the power and up to 8 cells (NiMh). We ran 8 cells back in the day but also had a few 9 cell packs. It measures 60mm x about 35mm (plus those exterior magnets) so I have plenty of clearance for the 3650.
That SeaKing 180 does look rather large and I think the water cooling routing is what will mess me up the most. My old Tekin marine ESC measures 85mm long x 30mm wide x 20 mm high. I also never ran the water cooling since it never really heated up that much and also nestles into the back of my hull with the radio, each in a single balloon. Man, water cooling this boat is admittedly gonna be a difficult task. But it looks like I will need a SeaKing or Turnigy 120 - they look to be the exact same unit with different labels - an assumption on my part and probably wrong.
Old May 27, 2012, 08:10 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
I'd be surprised to see those motors make 400 watts on nimh packs, but they're definitely stronger than most car/truck motors.
400 watts on 8 cells would be about 45a constant, which is a lot of current for nimh packs to deliver.
A seaking/turnigy 120 (they are the same minus the sticker) will be the easiest bet for water cooling since the lines run front to back along the ESC.
Old May 28, 2012, 12:17 PM
Shawnner is offline
Joined Mar 2012
Ok cool. I agree on the Turnigy, it looks like the right answer in terms of dimensions and specs along with a great price. Appreciate the help, big time!
Old May 30, 2012, 07:23 PM
Diegoboy is offline
Find More Posts by Diegoboy
Luke propwalker
Diegoboy's Avatar
United States, VA, Virginia Beach
Joined May 2007
You can either move the boat with voltage (4s) or with amps (2s) I'm going with 3s in mine. Shawn, you have a PM on OSE!
Diegoboy is offline Find More Posts by Diegoboy
Old Mar 01, 2013, 09:26 PM
Shawnner is offline
Joined Mar 2012
Hydrofoils Inc. 60G Test, February 2013 (1 min 4 sec)
Hydrofoil - Hydrofoils Inc. RC Hydrofoil Promo (3 min 34 sec)
Couple YouTube clips you may like.
Old Mar 04, 2013, 12:56 AM
Amp Abuser is online now
Find More Posts by Amp Abuser
Amp Abuser's Avatar
Joined Dec 2007
Here ya go. I had a subscription to boat n ship and still have this mag due to the hydrofoil, great inspiration.
Amp Abuser is online now Find More Posts by Amp Abuser
Old Mar 04, 2013, 07:40 AM
Shawnner is offline
Joined Mar 2012
Oh yeah, thanks for that! That boat was a beast, of couse that pic is just a photoshop. But you can see it running in the beginning of the 2nd YouTube - the older movie. He still has it but does not run it. It's truly nice to hear the hydrofoils inspired folks back then and you are still interested today!
Old Mar 06, 2013, 07:57 PM
BACKEMFNRG is offline
Find More Posts by BACKEMFNRG
BACKEMFNRG's Avatar
Canada, ON, Acton
Joined Oct 2003
I used to own one of these and sold it quite some time ago. I only ran it on 6-7 cells and a Graupner 500 motor.
If you have any questions regarding foil sharpening shape maybe I can help.
Yes, the 500 motor fits in there but a T180 esc will not and is far too heavy for this sized boat... Well at least to achieve the correct balance for it to ride properly.
From memory the gent from Hydrofoils Inc in FL told me that the boat should ride tail high with the nose slightly downward.
The foils need to be razor sharp. The horizontal foils need to create lift and the rudders vertical portion should be sharpened on both sides again razor sharp.
For some reason I had a hard time mounting the rudder as per instructions and phone calls.
I settled on adding a hardwood block to extend the rudder out so as to avoid contact with the Propeller.
I only ran it twice and got frustrated with it. Kinda wish I kept it but, got a few decent bucks for it anyway.
Since you have the 3650 size motor give it a whirl. If I had it still I'd gut it and put a 2860-5050kv Tacon in it and a T120, maybe just a T90 because it's lighter. A nice detongued x432 and it would ride on the prop and blade tips. Batteries I would use 2S Nano or Dinogy 3400Mah -4000mah max. This gives you flexibility to move components around for proper ride attitude.
Some days I can't remember what I had for lunch but, these things are still fresh.... crazy.
As for exact CG, I can't say but, tail up, nose down he said.
BACKEMFNRG is offline Find More Posts by BACKEMFNRG
Old Mar 06, 2013, 08:25 PM
Kcal is offline
Find More Posts by Kcal
Joined Jul 2008
"tail up, nose down"
So many things work out well that way, you’d think they’d simply teach it in school.
Kcal is offline Find More Posts by Kcal
Old Mar 06, 2013, 08:55 PM
Th3UmBrA is offline
Find More Posts by Th3UmBrA
AMA# 980507
Th3UmBrA's Avatar
United States, FL, Loxahatchee
Joined Feb 2011
FYI...Shawner is the son of the fella that made these hydros . So he has intimate knowledge of these 'foils.
Th3UmBrA is offline Find More Posts by Th3UmBrA
Old Mar 07, 2013, 06:02 PM
Shawnner is offline
Joined Mar 2012
Thanks man! Yeah Th3UmBrA is correct but I do appreciate any input. I'm especially interested in hearing about our old hydrofoils and completely new to brushless.
We made so many of those boats I remember that wooden block well. I had a piece of bent aluminum dowel that I used. The trick was to slide that block down on its back, glue side up, and flip it up at the last moment.
Old May 21, 2013, 01:26 PM
Shawnner is offline
Joined Mar 2012
Well it's been nearly a year since I officially started my rebuild and I've made a lot of progress. Figure it's time I shared the latest video for my "one year anniversary". This was taken in April, I'd strapped an iPhone to my radio. Hope you don't mind the shakiness.
The biggest challenge has been fitting everything into the small hull, especially introducing water cooling but I've managed to make it work. Next on my list are a stronger collet/coupler and a faster/stronger servo. Both are suffering a bit from the nearly double power. This run is primarily half throttle throughout. When I finally start to get on it at the end the flex cable spins right out of the current collet. Hope you all get a kick out of seeing a unique brushless FE Hydrofoil boat run even for just a few minutes!!
Hydrofoil - RC Hydrofoil - Remote Control Hydrofoil - Hydrofoils Inc. Zytiron (3 min 15 sec)
For Sale PHM hydrofoil project SilentHunter Boats (FS/W) 19 Sep 04, 2013 12:35 PM
Sold **SOLD** BlueSkyRC Spider Hex BNF inc CopterControl FC Borneoben Aircraft - Electric - Multirotor (FS/W) 6 Mar 14, 2012 08:20 AM
Discussion Looking for Boeing Hydrofoil Pegasus Plans hookpilot Scale Boats 5 Nov 18, 2011 10:45 PM
Discussion For all of the Hydrofoil folks, check out this build thread. Kcal Scale Boats 0 Nov 12, 2011 12:26 PM
Question Baldwin and Bell HD-4 Hydrofoil raydon_12 Scale Boats 12 Nov 11, 2011 05:59 PM
