Joined Oct 2011
I've bent the keel rod to generate the necessary dehidral.
I've also changed the left & right rod to 2 x lightweight carbon rod (5mm), leading till the tip. LED setup and testing as shown in the video. Will go for RC LED Vector kite spin once weather is fine. Stay tune! http://vimeo.com/40502870 |
Lanternfly, need some data:
-what's the exact wingspan of Your Delta? -what's the exact flightweight including all extraloads (LED-chain, LiPo)? My experience is: The smaller the deltas, vectorized with GEN.I , have been (smallest 55"), the more problematic is the large distance between prop-position and CoG. The negative effect is: Although You steer elevators full up when starting, at full throttle, the small Deltas get grounded - the motor power pulls it downwards. A nearly vetrical throw into the air could help then, when You start with full throttle. As a result of this, I experimented with more dehidral by moving the tension bar fastening upwards in the GEN. I triangle. At least, for the smaller Deltas (-Deltaboxes), I made smaller triangle frames, so the Motor came around 5" deeper. The best performers with the GEN. I unit have been my 10' - 12' deltas. They have so low air-resistance, that they could be flown with the GEN. I unit and it's motor by half throttle - have a look to indoor-/outdoor videos on my website: www.crazyplanes.de/deltaxl.wmv www.crazyplanes.de/deltaxl2.wmv www.crazyplanes.de/deltagkite1.wmv www.crazyplanes.de/deltaxxl5.wmv www.crazyplanes.de/deltaxxl4.wmv www.crazyplanes.de/vertigo.wmv Fact is: The placement of Your LED - chains u n d e r the kite's skin has a negative aerodynamical effect. ... Would be not so bad If You could put them on topside, where they are not disturbing aerodynamics so much as they do on the reverse side. flattermann |
Joined Oct 2011
flattermann,
Thanks for your advise. The wingspan is around 3m. I have managed to remove all the LEDs attachment. I did some adjustments, here's the video of my DIY RC Delta vector kite flown at Buangkok Field.... https://vimeo.com/40945381 Will attempt to fly it with LEDs loaded the next time... |
Joined Oct 2011
Night Flying DIY RC LED Delta Vector Kite
Night flying control of the flight is not easy with LEDs attachment, it has extra load on the sails which make the kite very unstable at time... but managed to pull the kite up the sky...LED lighting very sweee under the night sky...nice...
Here's the video...sorry for the grainy video...cheers! https://vimeo.com/41191047 |
| Thread Tools | |
| Discussion Delta rc kite. | ROLO1963 | RC Kites | 3 | Dec 09, 2011 10:57 AM |
| Discussion 320cm MANTA Vector-Kite flown at Neuenrade Kite Festival 2011 | flattermann | RC Kites | 5 | Oct 25, 2011 06:53 PM |
| Discussion Premeir RC Eagle Thrust vector kite | ApachePilot | RC Kites | 53 | May 15, 2011 07:58 PM |
| Discussion 12 foot Delta Kite RC-Conversion | flattermann | The Builders Workshop | 4 | May 15, 2011 02:03 AM |
| Discussion Anyone convert a kite type plane to RC? | trooper8 | Parkflyers | 1 | Aug 12, 2009 09:42 PM |
