Old Mar 26, 2012, 12:26 AM
firehawkzach is offline
Find More Posts by firehawkzach
firehawkzach's Avatar
United States, TX, Fort Worth
Joined Jan 2011
I need some suggestions
So my flying field has been relocated farther away and I find myself not being able to fly more due to my schedule. I am thinking I want to buy a smaller edf with no landing gear to fly in my backyard. Keep in mind I have an acre and a huge field behind me. I want something I can land in front of me. I'm not looking for anything that has a lengthy build process since I already have my hands full with my 90mm F-18. I want something cheap and fast. The reason I am asking for suggestions is because my transmitter is the Aurora 9 therefore I can't just go buy a stryker or any BNF's give me options that you guys like!! Thanks in advance.
firehawkzach is offline Find More Posts by firehawkzach
Old Mar 26, 2012, 07:49 AM
SHK V1 is offline
Find More Posts by SHK V1
United Kingdom
Joined Feb 2007
Have a look at the FMS 64mm Rafale. Take the gear off and you can hand launch it just fine. it flies nicely on a 3s 2200. Great performance, not vertical but really good fun and nicely aerobatic and good for proper jet style fly bys. Also, because its a delta, it can slow down to a crawl for landing. Mine is my "Take anywhere model". I will fly it in most small spaces because it will out climb most trees, and then you can wind it down in tight turns and level out at low level to put it down again in just a small space.
Pete
SHK V1 is offline Find More Posts by SHK V1
Old Mar 26, 2012, 09:26 AM
kelberts is offline
Find More Posts by kelberts
Effumall
kelberts's Avatar
Joined Nov 2005
Any of the J Power (Sky Angel) 50mm jets
kelberts is offline Find More Posts by kelberts
Old Mar 26, 2012, 09:35 AM
4stripes is offline
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
Phase 3 F-16. Cheap, fast, and fun. Will hand launch easily. Stock setup only needs 2 9g servos to complete and will do 75-80mph without any mods (looks pretty fast for its size).
I run mine on a 2200mah 3S battery and it has good vertical (but not quite 1 to 1 thrust).
4stripes is offline Find More Posts by 4stripes
Old Mar 26, 2012, 10:12 AM
Joined Jan 2011
I appreciate your response. Where can I find that rafale?
Old Mar 26, 2012, 10:58 AM
stekeye is offline
Find More Posts by stekeye
Tomball, TX
Joined Nov 2009
Try HobbyPartz
http://www.edfplanes.com/464ran3daera.html
I can vouch for this plane as well. My first EDF and loads of fun. Nothing overpowered but just a good, fun jet to fly. I recommend the gray camo version if you can find it. Makes it very easy to see. I miss this jet!
Stekeye
stekeye is offline Find More Posts by stekeye
Old Mar 26, 2012, 06:55 PM
Joined Jan 2011
Anyone else have any suggestions? I'm eyeballing the fms f-16 and the j-power L-39.
Old Mar 27, 2012, 12:41 AM
clinth01 is offline
Find More Posts by clinth01
Vertical Arrival Specialist
clinth01's Avatar
Townsville, Australia
Joined Sep 2009
If you've not got your heart set on scale, try the HK Jetiger. Enough grunt to have fun on 3S, and easy to upgrade to 4S later if you like changing your underwear often
clinth01 is offline Find More Posts by clinth01
Discussion need motor help and suggestions Hypnotic Large Electric Helis 2 Mar 16, 2012 06:18 AM
Question Looking for some performance suggestions for my Y-6 jcaywood Multirotor Talk 6 Mar 14, 2012 12:27 PM
Discussion need to build drive shafts 4mm each end..what do you suggest? kitscratchfevr Dock Talk 13 Mar 02, 2012 08:47 PM
Discussion 1/4 Scale Airplane motor suggestions needed John Boren Power Systems 3 Feb 29, 2012 04:38 PM
Discussion Need some 3rd plane suggestions Wookster Fuel Plane Talk 16 Oct 11, 2011 05:12 PM
