Old Mar 25, 2012, 07:24 PM
KFC is offline
KFC
Find More Posts by KFC
KFC
Blue Foam Master!!!
KFC's Avatar
United States, KY, Hanson
Joined May 2007
Question
Prop advice
So about a month ago I bought a Spartan as a noob FE boat. I have since beefed up the cooling system and am pretty satisfied so far with the performancse. My problem at this point is that a buddy of mine also got one and when we get together next month at an undisclosed R/C event, I need to have the faster boat. Can anyone offer me some advice on a substitute prop that might give me the edge, even if it shortens the runtime. Should I go with a 3 bladed prop or a 2 bladed prop? Beryllium copper or plastic? Basically how do you go about selecting props for boats. (I know how to do this for airplanes, but I get the impression that boats are a whole different kind of animal). What I really want to walk away with here is an understanding of how to select a prop for a given power system, so explanations of the reasons behind any suggestions would be greatly appreciated.
KFC is offline Find More Posts by KFC
Old Mar 25, 2012, 07:32 PM
scorpion1 is offline
Find More Posts by scorpion1
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
If you are running the new castle system i would give an s220 a try.
http://www.offshoreelectrics.com/pro...i-prather-s220
scorpion1 is offline Find More Posts by scorpion1
Old Mar 25, 2012, 09:03 PM
Kcal is offline
Find More Posts by Kcal
Joined Jul 2008
Beryllium same as the Prather prop, as that SS one is out of stock balancing is the same as for aircraft and sharpening is the best you can with what you have (keep kids away from the dust or wet sand), once you cut yourself as you install or remove it its perfect.
Kcal is offline Find More Posts by Kcal
Old Mar 25, 2012, 09:17 PM
KFC is offline
KFC
KFC
Blue Foam Master!!!
KFC's Avatar
Joined May 2007
The electronics are all Castle and I bored out the water pickup and installed large bore tubing through the whole thing to help keep it cool.
Is there a formula or something that you guys use to pick the props, or is it just experience?
Old Mar 25, 2012, 10:33 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
There are loose parameters for recommendations, but i mainly shoot from the gut now.
Think about all the different variables in choosing a prop.
Hull length
Hull width
Hull type
Motor KV
Motor size
# of cells
Total rpms
Old Mar 26, 2012, 08:49 AM
KFC is offline
KFC
KFC
Blue Foam Master!!!
KFC's Avatar
Joined May 2007
Will I get more stability (less rocking at speed) with a 3 bladed prop? Would I need to go to a smaller diameter?
Old Mar 26, 2012, 12:14 PM
wparsons is online now
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Rocking back and forth gently comes from the hull riding higher out of the water, which just comes with speed. If its rolling to one side harder, or the transom is jumping around then it might be better with a smaller diameter prop. A higher pitch, or 3 blade will likely help that a bit.
wparsons is online now Find More Posts by wparsons
Old Mar 27, 2012, 08:37 AM
highflyerbill is offline
Find More Posts by highflyerbill
Gordonsville,Virginia
Joined Nov 2009
Some good advice and a good prop chart . www.offshoreelectrics.com/propeller-chart.php
Just remember to start out small and work your way up .
highflyerbill is offline Find More Posts by highflyerbill
Question Various prop advice please Markx Racing Boats - Internal Combustion 13 Mar 16, 2012 05:38 AM
Discussion need advice. prop for large scale electric warbird. Matt Gunn Power Systems 7 Mar 12, 2012 02:56 PM
Discussion Y6 prop advice Dolby Hoverfly Technologies 3 Nov 12, 2011 05:01 AM
Discussion prop advice: calm day vs. windy day props? protocol Power Systems 6 Oct 22, 2011 10:13 PM
Discussion Props advice please on there sizes NEAGRON Beginner Training Area (Aircraft-Electric) 11 Sep 27, 2011 01:38 AM
