Old Nov 14, 2012, 03:06 PM
frankg is online now
Find More Posts by frankg
Joined Dec 2004
The bottom and chine line look good. At this point I would say your OK!. When running the model the hull is out of the water from the stem post to half way back at even half throttle. The planning surface is the last third of the hull or less the more throttle you give her.
frankg is online now Find More Posts by frankg
Old Nov 14, 2012, 07:54 PM
Tito59 is offline
Find More Posts by Tito59
Tito59's Avatar
United States, CT, Brookfield
Joined Jul 2012
Frankg First off I hope all is well and the recovery is going well. I received the new F5 and was able to get it in position by cutting off the foot. After regluing the battens and chine all looks good. The lines are as they should be and the flow very nicely. Again, I hope all is well and you are back in business better than ever. Hope you're health is on the mend as well. Thanks again for your outstanding service.
Regards Paul
Tito59 is offline Find More Posts by Tito59
Old Nov 21, 2012, 04:53 PM
bub9797 is offline
Find More Posts by bub9797
bub9797's Avatar
Archbald, PA
Joined Mar 2006
Hi all...2 questions on this build:
I'm guessing that the balsa blocks we glue onto the rearward frames face toward the stern?
As you can see in the pic, the bottoms of the front frames don't protrude over the keel, but the rearmost do when they're all the way seated on the keel, should they be pushed down to meet the building board? Can Rich or anyone else advise me here?
Rob
PS. Rich thanks for the super quick delivery of this kit! Excellent service as usual.
bub9797 is offline Find More Posts by bub9797
Old Nov 21, 2012, 07:28 PM
Joined Dec 2004
ROB- all the frames feet are glued down to the building board. The keel will be trued with the frames later in the build. SEE POST #22 of the build of MISS SEVERN here in the build post.
http://www.rcgroups.com/forums/showt...1621071&pp=100
Old Nov 21, 2012, 07:36 PM
Joined Dec 2004
ROB- All the balsa blocking for gluing the side panels in will be facing aft on the frames.
Old Dec 10, 2012, 07:19 PM
Tito59 is offline
Tito59's Avatar
Joined Jul 2012
Miss Severn Motor Mount
Hi Rich,
Two questions; I'm ready to glue the motor mount in place and noticed two things :
1. The motor mount provided does not lay flat on the angle keel and there is no notch in the rear side of the block as pictured in the instructions. Should there be a notch cut in the rear of the mount?
2. Also the motor mount does not sit flat on the angled keel as the rear corners interfere with the hull. Would the corners be cut off the allow it to sit against the keel for the proper motor angle thru to the shaft?
Pictures attached. Thanks for the guidance.
Paul
Old Dec 10, 2012, 07:21 PM
Tito59 is offline
Tito59's Avatar
Joined Jul 2012
Second photo
Rich,
Here is the photos from the instructions.
Paul
Old Dec 10, 2012, 07:30 PM
Joined Dec 2004
PAUL- Yes we cut the motor mount board out to get it a little farther back for the base of the motor mount. Also we sanded the back corners of the motor mount board so that the board sat down on the angled keel notch. The idea was to line up the motor and universal as straight as possible to the prop shaft and stuffing box.
Old Dec 11, 2012, 10:55 AM
wshores is offline
Find More Posts by wshores
United States, NY, Lockport
Joined Mar 2012
Mounting the Motor help (This is how I did it)
Hope this may help in the motor mounting.
Here are some pictures of the motor mount that I reworked to fit my build using the brushless motor. I used T nuts to hold the motor bracket in place, of the wood screws so I can easily take out the motor assembly for rework if needed. But the front 2 screws of the motor are hard to get out after installing the motor. I used a long screw driver to reach the front screws to start them, then a angled screw driver to torque them down.
Bill Shores
wshores is offline Find More Posts by wshores
Old Dec 11, 2012, 01:53 PM
pops880 is offline
Find More Posts by pops880
pops880's Avatar
United States, TX, Converse
Joined Mar 2012
Originally Posted by wshores View Post
Frankg:
Received Frame 5 in the mail today (11/13/12)
(NOTE: The new frame is not the same as the posted PDF file of the changed F5 frame)
I know itís been a really a hard time for you, your family and the factory these past few weeks. I have been following on the RCGroups every day.
I have been working on the Miss Seven build since I have gone past being able to replace the new F5 frame. I have reworked the sides to take out the hour-glass shape but it does not have the same lines as the boat in the pictures of the build (referring to step # 62 picture) see my attached pictures of my rework
I hope this will all work out.
Nice lines, great job
pops880 is offline Find More Posts by pops880
Old Dec 11, 2012, 06:38 PM
Tito59 is offline
Tito59's Avatar
Joined Jul 2012
Frankg, wshores
Thanks guys, I figured there was a bit of rework required. Sounds like I need to wait Until I get the power package and then align the shaft, strut, motor and mount simultaneously to get it all aligned properly.
Paul
Old Jan 15, 2013, 08:28 PM
Tito59 is offline
Tito59's Avatar
Joined Jul 2012
100 hrs into the build!
Really enjoying putting this together !
Rich, you did a great job.
Paul
Old Jan 15, 2013, 08:32 PM
Tito59 is offline
Tito59's Avatar
Joined Jul 2012
Photo 2
Old Jan 15, 2013, 08:37 PM
Aerominded is offline
Find More Posts by Aerominded
Monterey Bay California
Joined Feb 2004
Wow, that looks fantastic, Tito!
Now I feel bad for not buying one! (I thought I heard somewhere that the first run of these is sold out -- Just a rumor though -- Check with frankg, of course)
Aerominded is offline Find More Posts by Aerominded
Old Jan 15, 2013, 10:24 PM
californiakid is offline
Find More Posts by californiakid
mahoganyfan
californiakid's Avatar
United States, NJ, Atlantic City
Joined Nov 2010
Beautiful
Nice work TITO59,keep it up,I am following your build.Thanks for posting pictures.
californiakid is offline Find More Posts by californiakid
Cool Atosis - 1907 Gold Cup Racer Chinewalker Dock Talk 12 Apr 27, 2014 07:53 AM
Sold 75" Gold Wing Edge Racer - LPU hjcolman Aircraft - Electric - Airplanes (FS/W) 2 Mar 15, 2012 10:16 PM
For Sale HP Gold Cup 40 with muffler davedwards Aircraft - Fuel - Engines and Accessories (FS/W) 2 Feb 01, 2012 07:55 PM
Sold NIB Hirtenberger 40 F-RC Gold Cup joemetal Aircraft - Fuel - Engines and Accessories (FS/W) 3 Jan 26, 2012 03:02 PM
Sold Hirtenberger 61 F-RC Gold Cup joemetal Aircraft - Fuel - Engines and Accessories (FS/W) 3 Jan 24, 2012 03:43 PM
