Old Oct 17, 2012, 11:23 PM
Tito59 is offline
Find More Posts by Tito59
Tito59's Avatar
United States, CT, Brookfield
Joined Jul 2012
Thanks JAY. Yeah unfortunately I'm a perfectionist and its driving me crazy looking at that less than perfect transition. I love the sleek lines of his model and it does seem ashamed to finish it knowing it will look a bit odd.
Frankg, any suggestions?
Description:
Description:
Description:
Tito59 is offline Find More Posts by Tito59
Old Oct 18, 2012, 08:22 AM
frankg is offline
Find More Posts by frankg
Joined Dec 2004
TITO59- If it were me I would take apart the frame work to remove the frame #F5. If you can not wait for the new laser cut frame #F5, which is being mailed out at the end of this week, to reach you , you can down load the PDF file drawing which is posted in this thread , and recut the over sized frame #F5. You will notice that the chine notches and the sides of the frame are too wide at the chine. The rest of the frame is correct.
frankg is offline Find More Posts by frankg
Old Oct 18, 2012, 09:35 AM
Tito59 is offline
Tito59's Avatar
Joined Jul 2012
Thanks Frank, I'll wait for the part and give it a try. I will probably cut the existing part out in sections to minimize any damage to the sheers, battens and keel, then shoe horn the new rib in place. Not sure if that's even possible, I'll let you know how it goes. Hope all is well and hope your feeling better.
Again thanks for your support and quick response. Its a pleasure dealing with you.
Old Oct 19, 2012, 06:41 AM
JayJay76 is offline
Find More Posts by JayJay76
JayJay76's Avatar
United States, IL, Chgo
Hi Tito, I thought you had already put the sub planking on, you should be able to swap it out without too much damage. But wshores has already put the balsa plaking on, I doubt he will be able to correct the shape at this point without stripping most of the planking off..
JayJay76 is offline Find More Posts by JayJay76
Old Oct 19, 2012, 10:37 AM
pjesus is offline
Find More Posts by pjesus
pjesus's Avatar
Parede, Portugal
Joined Nov 2006
frankg, a stupid question if I'm allowed...
When applying the resin and the urethane varnish do you brush it or airbrush it?
[edited]
Oops.. sorry, should've searched better...
Originally Posted by frankg View Post
GRAVEMAN - YEP! All the epoxy coats and finish coats of the polyurethane was done with throw away brushes.
pjesus is offline Find More Posts by pjesus
Old Oct 19, 2012, 10:47 AM
Aerominded is offline
Find More Posts by Aerominded
Monterey Bay California
Joined Feb 2004
Do not spray catalyzed materials like resin unless you have the proper breathing equipment, etc. - dust masks and hardware store respirators don't count! Resin in lungs = bad stuff.
Care must be taken when spraying anything, of course.
Aerominded is offline Find More Posts by Aerominded
Old Oct 19, 2012, 10:55 AM
pjesus is offline
pjesus's Avatar
Parede, Portugal
Joined Nov 2006
I do understand the risks Aero but thanks for the heads up anyway
(I do use a mask with filters when spraying or heavy sanding)
Old Oct 19, 2012, 11:46 AM
Tito59 is offline
Tito59's Avatar
Joined Jul 2012
JayJay, No the sub planking is not on yet. I was about to start and something inside said no, wait and ask a few more questions. I spoke via phone with Frankg and he was as usual very helpful. When I receive the new rib I'm sure with a little finesse I can cut out F5 and wiggle the new one in place. Dremel tool, xacto should do it.
Old Oct 19, 2012, 12:18 PM
Joined Feb 2004
Fair enough! it should always be suggested though since people with less experience may read these threads in the future.
Old Oct 19, 2012, 06:36 PM
Tito59 is offline
Tito59's Avatar
Joined Jul 2012
Franks, is the PDF drawing of the new F5 full scale?
Old Oct 19, 2012, 06:39 PM
frankg is offline
Joined Dec 2004
Yes it is full scale and the PDF file is set up to print on 8 1/2" x 11" paper from your printer.
Old Oct 19, 2012, 08:57 PM
Tito59 is offline
Tito59's Avatar
Joined Jul 2012
The reason I ask is I removed the old F5 as we talked about today and then printed and cut out the scale rib to see how it would fit and think about how to install the new one when it arrives, the entire rib is undersized all the way to the sheer. The old rib measures aproximately 8 9/16" lg at the foot. The drawing measures only 8 1/8" at the foot? The distance on the opposite side at the sheer is identical.
Old Oct 19, 2012, 09:53 PM
frankg is offline
Joined Dec 2004
TITO59- The file when I printed out measures 8- 9/16 across the base line- shear out side dimension. I will be shipping out the new frame next week PRIORITY MAIL. Wait for the frame.
Old Oct 20, 2012, 01:19 AM
JayJay76 is offline
JayJay76's Avatar
SO TRUE. the first time I used catalyzed clearcoat I only used a particulate mask; it seemed to be going okay, sort of a long session with the pistol cleanup, but then I had the idea to run to the supermarket around the corner for a couple of beers. I wandered for a bit trying to recall what else I was supposed to pick up, then I spent while looking at the wall o beer before picking out a couple nice brightly labeled bottles and proceeded to the checkout. Everything seemed pretty normal till I paid the lady and realized I'd left my ability to speak German in the paint booth. After a few moments of searching for words, I chose "danke, Schoenes wochenende, tschuess. ." But it came out more like "daaaga, shoonywookanoony, choooo. .." she looked at me like I had a bowl of goldfish on my head. I realized all at once that I still had my paper tuxedo on and a dustmask ring around my mouth masking out a nice inverted goatee of red shop rag lint , and apparently, in the process of pulling it off my head, my hair sticky with paint was arranged like I'd rollen down a hill and into a pack of wild boar. I avoided that shop for a few days. I dunno what's in that stuff but it will turn you into a doorstop if you aren't careful.
Old Oct 20, 2012, 07:43 AM
Tito59 is offline
Tito59's Avatar
Joined Jul 2012
Frankg, No problem, wshores sent me a message and suggested I check my print properties. Thought I printed it at 100% but there was a scalable setting that was incorrect. I reprinted it and all is well.
Thanks wshores!
Cool Atosis - 1907 Gold Cup Racer Chinewalker Dock Talk 12 Apr 27, 2014 07:53 AM
Sold 75" Gold Wing Edge Racer - LPU hjcolman Aircraft - Electric - Airplanes (FS/W) 2 Mar 15, 2012 10:16 PM
For Sale HP Gold Cup 40 with muffler davedwards Aircraft - Fuel - Engines and Accessories (FS/W) 2 Feb 01, 2012 07:55 PM
Sold NIB Hirtenberger 40 F-RC Gold Cup joemetal Aircraft - Fuel - Engines and Accessories (FS/W) 3 Jan 26, 2012 03:02 PM
Sold Hirtenberger 61 F-RC Gold Cup joemetal Aircraft - Fuel - Engines and Accessories (FS/W) 3 Jan 24, 2012 03:43 PM
