Mar 25, 2012, 07:23 PM
Joined Dec 2004
5. Now take the keel doubler (KDL) from laser sheet S2 and place it on the flat waxed paper surface, Take the assembled keel and stem post assembly and place it position next to the keel doubler. Using 12 minute epoxy glue, carefully coat the keel doubler, taking care not to put any glue on the inside of the dotted laser lines for the rudder stuffing box, propeller stuffing box, and the motor mount cut out of the keel. Once glued place the balsa keel assembly on to the keel doubler aliening the frame slots perfectly. Weight can be place on the balsa keel to assure a good bond of the glued surfaces.
