Old Mar 25, 2012, 02:41 PM
flashprash65 is offline
Find More Posts by flashprash65
Tampa, Florida
Joined Jun 2006
Best Range DX7 or FUTABA 72mhz FM?
Can someone tell me which radio will have the best range for a powered EPP glider ? I have long range RX's for both.
flashprash65 is offline Find More Posts by flashprash65
Old Mar 25, 2012, 04:47 PM
tkallev is offline
Find More Posts by tkallev
LSF303-AMA Fellow
tkallev's Avatar
USA, IL, Wheeling
Joined Jan 2003
Both radios will keep their link much farther than you can keep the model in sight.
tkallev is offline Find More Posts by tkallev
Old Mar 25, 2012, 09:33 PM
glidermang is online now
Find More Posts by glidermang
flash:
tkallev is absolutely correct.
I got to lab-test some first-class 72mHz transmitter/receivers a few years ago. They worked generally out to almost exactly a nautical mile, which is much, much further than you can see to control a typical RC sailplane.
Yours, Greg
glidermang is online now Find More Posts by glidermang
Old Mar 30, 2012, 05:14 PM
PROACE is offline
Find More Posts by PROACE
Rocky Mountain High and Higher
PROACE's Avatar
Joined Jan 2002
How about 72MHZ compared to 2.4GHZ?? I have both and like both
PROACE is offline Find More Posts by PROACE
Old Mar 30, 2012, 09:50 PM
theghosttanker is offline
Find More Posts by theghosttanker
United States, NY, Lewiston
Joined Apr 2011
same answer....even the ancient AM sets worked farther than you could see....the advantage of 2.4 GHZ isn't range, it's interference rejection.
theghosttanker is offline Find More Posts by theghosttanker
Old Mar 31, 2012, 10:51 AM
kilwein is offline
Find More Posts by kilwein
kilwein's Avatar
Joined Jan 2007
Using calibrated test equipment, 20GHz scope, 26GHz, EMI chamber, both horn and conical antennas along with field tests, my 14MZ fasst (14 & 8 channel RX's) get 8k+ft , my 9ZHPS SYN 72MHz 9 channels, 11K+. Some of this was done with the equipment connected inside the RX to actually see the signal-levels. MY comfort level to see-fly the model is ~2700ft. Either one is good but the 2.4 fasst has freq switching advantage for interference as mentioned above.
kilwein is offline Find More Posts by kilwein
Old Apr 01, 2012, 03:59 AM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
One point to remember is that the receiver is typically the limiting factor. Some are longer range than others. However most makers will not state a range other than to say "parkflyer", "indoor" or "full range". These terms have no numerical standard, but if you want range make sure you are flying a "full range" receiver.
aeajr is offline Find More Posts by aeajr
Old Apr 01, 2012, 10:56 PM
ozmo01 is offline
Find More Posts by ozmo01
ozmo01's Avatar
USA, MO, Ozark
Joined Nov 2006
Hard to add any usefull reply to the good info here. For me personally more range equals new glasses. I crashed a Radian last fall and found it 1.3 miles measured on Google earth.
WE (always ask for help to crash ;-) ) had it breifly at times but could not over come the winds that came up aloft and it got OOS. Likely gave some golfers a bit of excitement though!
ozmo01 is offline Find More Posts by ozmo01
Old Apr 02, 2012, 01:18 AM
PROACE is offline
PROACE's Avatar
Joined Jan 2002
Lol
Old Apr 11, 2012, 07:38 AM
michelcote is offline
Find More Posts by michelcote
Joined Jul 2008
Futaba 72MHz is much much more reliable
You never know when spektrum will let you down.
I know from experience. I have seen and I had lockout at 200ft.
72MHz may glitch but will let you know if sometyhing is wrong
Spektrum, everything goes well until the end.
Frequency hopping is good but 2.4GHz is where all wifi systems operate and is goes much less further that 72Mhz for the same radio power
72MHz is almost exclusively for modelers, so not too much noise from other uses.
Both radio, when working, will fly you further that you can see.
michelcote is offline Find More Posts by michelcote
For Sale Electron 6 FM 72mhz micro receiver dual conversion for Futaba or Hitec shooboy Aircraft - General - Radio Equipment (FS/W) 3 Jan 15, 2012 05:29 AM
Sold $50.00 SHIPPED Futaba 72MHz (channel 54) 6EX TX and R156F full range RX crosby Aircraft - General - Radio Equipment (FS/W) 3 Oct 22, 2011 03:37 PM
Sold Futaba FP-TK-FM 72mhz module for 9Z,9C,etc. pach Aircraft - General - Radio Equipment (FS/W) 1 Oct 09, 2011 10:16 PM
Help! futaba FM MODULE 72mhz DC or SC G-unit Radios 11 May 26, 2008 03:32 AM
Wanted HELP FM 72mhz radio futaba or hitech jstoll Aircraft - General - Radio Equipment (FS/W) 4 Jan 14, 2008 09:25 PM
