Old Jun 14, 2012, 01:48 AM
gewiens is offline
Find More Posts by gewiens
Look Up!
gewiens's Avatar
Canada, MB, Niverville
Joined Apr 2008
Well i kept rod in just in case one fails it WILL drive the other elevator and push the dead servo arm. No problems and at probably flight 50 now.
gewiens is offline Find More Posts by gewiens
Old Jun 16, 2012, 06:00 PM
wuest3141 is offline
Find More Posts by wuest3141
Tucson
Joined Nov 2009
Has the Sbach flown yet?
I've noticed that hobbyking seems to think that tiny electric motors will fly planes. So the motor box is often too long. And I don't think that they know that regular servos are about 35g. Some of the servo mounts they have for 50 inch planes are for tiny servos.
wuest3141 is offline Find More Posts by wuest3141
Old Jun 17, 2012, 01:02 AM
Speeder1 is offline
Find More Posts by Speeder1
Joined Jun 2012
Not sure what they were thinking by the looks of it when they made this motor box. I'd sooner have to spacer the motor than have to mod the box.
Speeder1 is offline Find More Posts by Speeder1
Old Jun 17, 2012, 02:08 AM
FlyDave is offline
Find More Posts by FlyDave
Crash proof pilot
FlyDave's Avatar
Svizzera, TI, Bellinzona
Joined Oct 2005
This model was not made by Hobbyking but by Flight Model (www.flight-model.com)
Hobbyking suggested the G60 and i don't understand why, i bought this motor and it doesn't fit under the nose canopy.
Now i have ordered a 5055 size motor, this should fit (i hope !!) as is the motor suggested from the make of this arf.
My airplane as not flown yet, i'm assembling it with low pace, i want a job well done :-)
FlyDave is offline Find More Posts by FlyDave
Old Jun 25, 2012, 12:57 PM
century_series is offline
Find More Posts by century_series
Pro Slacker
century_series's Avatar
Linköping, Sweden
Joined Nov 2003
Tinted canopy
Hi FlyDave
I noticed you have the tainted canopy whereas the Hobbyking version is clear. Where did you buy your plane?
Regards
Patrik
century_series is offline Find More Posts by century_series
Old Jun 26, 2012, 01:13 AM
FlyDave is offline
Crash proof pilot
FlyDave's Avatar
Joined Oct 2005
Originally Posted by century_series View Post
Hi FlyDave
Regards
Patrik
Hi Patrik, it is the one from Hobbyking.
Hobbyking sells many versions, balsa ARF and EPO Arf, this one is the Balsa ARF :
http://www.hobbyking.com/hobbyking/s...dProduct=15123
Old Jun 26, 2012, 02:10 AM
gewiens is offline
Look Up!
gewiens's Avatar
Joined Apr 2008
I can't count how many flights i have on mine now, over a 100 for sure. Still holding up and haven't had to retighten a thing on it. Built better than some name brand birds i have by the looks of it.
Old Jun 26, 2012, 03:49 AM
Pro Slacker
Linköping, Sweden
Joined Nov 2003
Ah, I didn't search good enough. Thanks Dave!
Old Nov 17, 2012, 10:19 AM
Lucair is offline
Find More Posts by Lucair
Joined Nov 2012
I have mounted the turnigy G60 on my Sbach, for mount this motor I have shortended the engine mount of 1,5 cm in order to fit the motor perfectly. The servos are the suggested by HK, it's sufficient to cut a little the hole.
The propeller is a 15/8 and the battery are 6S.
The only thing is the landing gear that is much weak, and another parts of the fuselage with little glue.
Lucair is offline Find More Posts by Lucair
Old Nov 17, 2012, 06:10 PM
gewiens is offline
Look Up!
gewiens's Avatar
Joined Apr 2008
To date I haven't had one problem with my landing gear and I have a ton of flights on this plane. Haven't had to tighten so much as a wheel pant screw. Have had about 30 to 40 since my last post.
Old Dec 12, 2012, 06:38 PM
runnin9s is offline
Find More Posts by runnin9s
Joined Jul 2011
What prop are most people using on this plane, I just got a 5055 560kv motor and a carbon fiber 14x7 prop is this enough prop? and that is on 6s
runnin9s is offline Find More Posts by runnin9s
New Product NEW Sbach 342 1400mm Balsa (ARF) HK Jaybee 3D Flying 199 Dec 22, 2014 02:36 PM
Discussion HK Sbach 342 1400mm Balsa gewiens Sport Planes 11 Mar 21, 2012 10:35 PM
Discussion Best Sbach 342 ARF raf37 Giant Scale Airplanes 4 Mar 01, 2012 05:25 PM
Wanted Sbach 342 1400mm Balsa (ARF) shepster Aircraft - Electric - Airplanes (FS/W) 11 Dec 19, 2011 06:59 PM
New Product NEW!!!! Hobbyking 1000mm SBach 342 BALSA ARF Jaybee 3D Flying 7 Jun 04, 2011 01:02 AM
