Old Apr 19, 2012, 05:16 PM
skullhat is offline
Find More Posts by skullhat
Joined Aug 2011
i also am building the epo version in orange.
they stuped to a new low on the instructions for that one....they took the usual photos of the wrong plane, coupled with text that makes no sense, then they shrunk them to thumbnail size, lol.
buddy says it flys well , so this weekend im gonna find out.
skull
skullhat is offline Find More Posts by skullhat
Old Apr 19, 2012, 06:25 PM
gewiens is offline
Find More Posts by gewiens
Look Up!
gewiens's Avatar
Canada, MB, Niverville
Joined Apr 2008
Originally Posted by skullhat View Post
i also went with the power 46 after reading that the 60 doenst fit well, (tried one myself,and it dont)
its still a bit long for a close gap spinner as well. did you loose the x mount on the 46 as well?
im glad to read that yuo are having a good time flying the thing, 'cause with all this extra work, id b po'd if there was no pay out at the end, lol
i just got my ht 225 mg servos and they fit nicley. now all i gotta do is get this motor sorted out so i can assemble the thing
skull
http://www.rcgroups.com/forums/showthread.php?t=1595626
With the power 46my spinner back plate was 15mm from the cowl. I cut out 13 mm if I remember correctly and still used xmount.
gewiens is offline Find More Posts by gewiens
Old Apr 20, 2012, 01:46 PM
skullhat is offline
Joined Aug 2011
gewiens
thanks for the link, i did read that before, but must have forgotten. saved them for reference now,
also gonna go with the dual servos in the rear.
for those looking for that cool aluminum spinner tower hobbies has them in stock. other places said they did, but wound up not having them.
let me also re state what ive read here a few times.........none of the reccomended hardware fits. i had bought the reccomended kit as well, and the motor and servos are too big. just incase a new owner is scanning these posts for ideas, dont buy the kit
skull
Old Apr 21, 2012, 02:11 PM
3d3dman is offline
Find More Posts by 3d3dman
United Kingdom, England, High Wycombe
Joined Feb 2012
Just installed the Sk5055 motor, with no modification it fits perfectly compared to the G60. Anyone looking to install the G60 I wouldnt waste your time
3d3dman is offline Find More Posts by 3d3dman
Old Apr 23, 2012, 11:47 AM
skullhat is offline
Joined Aug 2011
what kind of wattage you pulling with that 5055 ?
funny that hk rec's the g60 on their site, but the intstruction for the plane rec the 5055.
im just gonna go with the the eflite,46 as i never have problems with their stuff, and modding the motor mount wont be that much trouble.
it would be nice if the guys at hk read the instructions for their kits before posting a list of reccomended accesorires though. even better if they assembled and testet them as well
still interested in how she flies withthe 5055, might have to build 2 and try that out as well
skull
Old Apr 29, 2012, 03:30 PM
3d3dman is offline
Joined Feb 2012
I believe the wattage is 1580w....I flew the model last week with the sk5055 motor and it is a absolutely brilliant match compared to the g60..The G60 on 5S 4000mah is rubbish...With the Sk5055 it pulls more like an 90 size IC motor!!! I like the motor so much I have just bought another! Donít waste your time with the G60, too heavy and underpowered for this plane
skull
Old May 01, 2012, 04:21 PM
skullhat is offline
Joined Aug 2011
cool, thantks. thats some serious power for sure. sounds like the ticket for guys who want a bolt in motor.
currently, im using my g60 as a paper wieght....its good at that.
skullhat
Old May 01, 2012, 11:44 PM
gewiens is offline
Look Up!
gewiens's Avatar
Joined Apr 2008
If you want power out of that g60 you need to run it with a 16x10apc on 7s in another plane. Then it'll come to life and amps wil be at about 60. I run a eflite power60 on this config in my Goldberg bipe.
Old Jun 04, 2012, 08:25 PM
skullhat is offline
Joined Aug 2011
anybody got a video yet.......i need motivavtion to finish my plane !!!
skullhat
Old Jun 07, 2012, 12:40 PM
FlyDave is offline
Find More Posts by FlyDave
Crash proof pilot
FlyDave's Avatar
Svizzera, TI, Bellinzona
Joined Oct 2005
Progress
Hi all ! time for an update i think
I was away from the hobby for a little, spending time with my new son and doing a makeup to my workshop.
Just for comparation, this is my shop before :
Name: 20120409_175543 (Small).jpg
Description: before
And this is after :
Name: 20120607_131626 (Small).jpg
Description: after
Name: 20120607_131717 (Small).jpg
Description: detail
Nice improvement uh ?
I still need to build a pegboard, then it's finished.
Ok but now... back to the Sbach ! I have some pictures to show.
FlyDave is offline Find More Posts by FlyDave
Old Jun 07, 2012, 12:43 PM
FlyDave is offline
Crash proof pilot
FlyDave's Avatar
Joined Oct 2005
Those Power HD servo's are just.... PERFECT for this airplane.
Mounted the servo's for the ailerons, and connected the ailerons with the arms included in the kit :
Name: DSCN0142 (Small).jpg
Description:
Then i have mounted the rudder servo. Here i wanted to use one of the "wrong" servo's of my first order, too long for the tail but fit nice on it's place :
Name: DSCN0134 (Small).jpg
Description:
Old Jun 07, 2012, 01:02 PM
FlyDave is offline
Crash proof pilot
FlyDave's Avatar
Joined Oct 2005
Pull Pull Rudder
Now... the time has come... for the scariest part, for me
Installing the pull-pull rudder.
First thing i had to do is finding the hole where the wire should exit from the fuselage, it is under the hole where you glue the stab :
Name: DSCN0133 (Small).jpg
Description:
Then, i glued with epoxy the fiberglass horn on the rudder.
If you look with a light, you can see that there is 2 holes for the horn, i have choosed to use the most high, for better alignment with the exit hole.
Name: DSCN0135 (Small).jpg
Description:
The manual ask for only 2 hinges on the upper side that support the rudder on the fuselage, i don't feel confident with that, so i've glued another hinge
Name: DSCN0137 (Small).jpg
Description:
Ok now... on the wire. I have never used a pull-pull, i'm learning as i'm building, so please tell me if i've made something wrong.
This is how i have connected the wire :
Name: DSCN0136 (Small).jpg
Description:
And here you see the rudder glued to the fuselage (with cyano), and the wire connected to the horn
Name: DSCN0143 (Small).jpg
Description:
In the last pic for today, i tried to show the inside of the fuselage with the wire going to the rudder. I have a doubt if the wires should go straight or crossing, my personal preference is to cross the wires. Plenty of space here inside, i have just to be careful with the elevator servo cables to not interfere with the steel wire.
Name: DSCN0140 (Small).jpg
Description:
Old Jun 13, 2012, 03:42 PM
FlyDave is offline
Crash proof pilot
FlyDave's Avatar
Joined Oct 2005
Ok... unfortunately i lost some pictures, i show what i've saved.
The first try at the pull-pull system was a disaster, as expected
2nd try was better, but this time i haven't used the steel wire, but a Dacron wire (fishing wire).
I have mounted the 2 elevator servo's, the tailwheel and the horizontal stab.
Now... i have a doubt, i hope someone can help me :
- as i use 2 servo's for the elevator, is correct that the two elevator should be independent each other, or i still need to connect them with the metal join ?
David
Old Jun 13, 2012, 05:53 PM
3d3dman is offline
Joined Feb 2012
Quick Update - I have now flown my Sbach over 30 flights now - this is a brilliant model. Knife Edge, rolling circuits, Prop hanging, harriers - it can do it all. Some manoeuvres can be difficult at first but after a little practice she handles well. The elevator seems to be holding up well although I am running 2 servos and carbon struts even after pushing the model very hard.
The only BIG issue I have had is the catch on the canopy is not securing it down enough. Even after putting duct tape on the back of the canopy this evening it still managed to come off - this is the 3rd time this has happened. It seems that air is rushing through the gap between the canopy and the fuselage. The other issue is the undercarriage, the metal is weak and after a few harder landings it is starting to bend Ė carbon upgrade would be recommended
Old Jun 13, 2012, 06:03 PM
3d3dman is offline
Joined Feb 2012
Hi Dave,
2 servos on the elevator and remove the metal rod
David
New Product NEW Sbach 342 1400mm Balsa (ARF) HK Jaybee 3D Flying 199 Dec 22, 2014 03:36 PM
Discussion HK Sbach 342 1400mm Balsa gewiens Sport Planes 11 Mar 21, 2012 11:35 PM
Discussion Best Sbach 342 ARF raf37 Giant Scale Airplanes 4 Mar 01, 2012 06:25 PM
Wanted Sbach 342 1400mm Balsa (ARF) shepster Aircraft - Electric - Airplanes (FS/W) 11 Dec 19, 2011 07:59 PM
New Product NEW!!!! Hobbyking 1000mm SBach 342 BALSA ARF Jaybee 3D Flying 7 Jun 04, 2011 02:02 AM
