Old Mar 25, 2012, 02:26 PM
FlyDave is offline
Find More Posts by FlyDave
Crash proof pilot
FlyDave's Avatar
Svizzera, TI, Bellinzona
Joined Oct 2005
Build Log
Flight Model Sbach 342 (ARF balsa)
Hi all !
I start this thread to show the building of my freshly received Sbach 342 made by Flight Model (www.flight-model.com)
This is a picture of the finished product, found on the producer website.
Description: The finished product (not mine)
Some technical info's :
Name: Sbach 342 55" EP
Numbers: M082
Wing span: 55"/1400mm
Wing area: 38.14sq.dm
Length: 53.4"/1357mm
You can find this model on Hobbyking or others online shops.
I bought mine from a local Swiss supplier.
I'm waiting the electronic parts, so don't expect a finished build so fast
FlyDave is offline Find More Posts by FlyDave
Old Mar 25, 2012, 02:45 PM
FlyDave is offline
Crash proof pilot
FlyDave's Avatar
Joined Oct 2005
Ok, starting !
I begin with the landing gear... the easiest part
The landing gear is made in black painted alluminium, fixed with 3 allen screws on the airframe.
First picture show the parts contained on the bag :
Name: DSCN0090 (Custom).jpg
Description:
The wheel support (sorry for my english translation) is fixed on the LG only partially, first thing to do is to mount the wheel. I've added two washers, because i don't like a direct contact between the wheel and the support axle, the picture show what i mean :
Name: DSCN0091 (Custom).jpg
Description:
Try to fix the wheel stop collar with the screw in the up direction, you may need to adjust it later.
The wheel should spin freely, but without much "play".
Next step... put the wheel cover.
Name: DSCN0092 (Custom).jpg
Description:
To tighten the nut, simply put a small screwdriver on the small hole, on one side of the wheel axle.
It is not necessary to align perfectly the cover now, you can do it later
Name: DSCN0094 (Custom).jpg
Description:
Do the same thing on the other side, and... tadaa.. a completed landing gear
Name: DSCN0095 (Custom).jpg
Description:
p.s. : btw, sorry for my english.. i try to correct my grammar mistakes when i find them eheh.
Old Mar 25, 2012, 03:01 PM
FlyDave is offline
Crash proof pilot
FlyDave's Avatar
Joined Oct 2005
Next step, vertical stab.
First i put the stab on is slot, then i mark the position with low tack adesive.
Another trick is to put the adesive on your jeans a few times, if you don't do that, the risk is that you damage the oracover when you remove it.
Name: DSCN0097 (Custom).jpg
Description:
Do this on each side, then remove the stab and with a small blade cut and remove the oracover, best if a little under the marked position (2mm is enough).
Name: DSCN0099 (Custom).jpg
Description:
Name: DSCN0100 (Custom).jpg
Description:
Attach this part with wood glue, it is perfect for balsa vs balsa.
A note : the part show a little gap when mounted, you can fix it with a sander, or you can leave it as it is, it's up to you.
The important thing is to check that when glued, the vertical stab should be aligned with the airframe, as shown in the last picture.
Name: DSCN0103 (Custom).jpg
Description:
Name: DSCN0104 (Custom).jpg
Description:
Old Mar 25, 2012, 03:39 PM
FlyDave is offline
Crash proof pilot
FlyDave's Avatar
Joined Oct 2005
Next thing i can do while waiting for the remaining parts, is to glue the ailerons on the wing.
First i glue the cyano hinges on the wing. Using thin Zap with the extender tips allow an easy application of the glue exactly on the center slot of the hinge.
Name: DSCN0106 (Custom).jpg
Description:
Name: DSCN0107 (Custom).jpg
Description:
Once done that, you put the aileron, checking to have the same gap (the smallest you can) on the whole lenght, and also be sure that the root of the aileron don't touch the wing, leave enough gap to move freely.
Name: DSCN0108 (Custom).jpg
Description:
An easy way to find the hinges position, and the point where to put the glue, is to bend the aileron and put a lamp behind, you can clearly see the hole as in this picture :
Name: DSCN0109 (Custom).jpg
Description:
After the cyano has dried, move the aileron and check for free movement, then if you see a little white fog on the oracover, remove it with a rag and alcohol.
Old Mar 25, 2012, 04:04 PM
FlyDave is offline
Crash proof pilot
FlyDave's Avatar
Joined Oct 2005
Horns
Glueing the aileron and elevator horns.
Be careful, on the bag there is 2 sizes.
The long horn goes on the ailerons, the smaller on the elevators.
Name: DSCN0110 (Custom).jpg
Description:
The carbon fiber horns surface is shiny, you must sanding it a little with sandpaper, so the glue grab better.
Name: DSCN0111 (Custom).jpg
Description:
The little G10 (fiberglass) plates contained in the kit is glued to the horn with thin cyano.
Caution !! this is my first mistake !
Name: DSCN0112 (Custom).jpg
Description: first mistake !!
I've only late discovered, that on the kit there is only 4 plates, two for the rudder horn, and two for the ELEVATOR horns !!
It was too late when i discovered, but it is not a problem, i've used a 0.30mm fiberglass sheet and cutted two more myself (see later).
Ok, the horn with the glued plate is now glued with 5-min epoxy to the ailerons.
Check that the glue cover the sides of the hole, and the horn, then push it inside.
Remove the excess resin with rag and alcohol before it catalyze.
Name: DSCN0113 (Custom).jpg
Description:
Old Mar 25, 2012, 04:14 PM
FlyDave is offline
Crash proof pilot
FlyDave's Avatar
Joined Oct 2005
Elevator horn
On the elevator now.
As said before, i've made a mistake using the plate that goes on the elevator horn, on the aileron.
So... the first thing is to build another.
I've many fiberglass sheets on my drawers, so i've taken the smallest (0.30mm thick) and cutted two more plates with an xacto knife.
Name: DSCN0121 (Custom).jpg
Description:
Name: DSCN0122 (Custom).jpg
Description:
Do the same thing as the aileron horn. Sand the surface, glue the plate with cyano.
Find the horn hole on the elevator using a lamp behind the oracover (sorry for the bad quality picture)
Name: DSCN0119 (Custom).jpg
Description:
Cut away the oracover, only on the bottom side of the elevator!
At this point, use 5-min epoxy and glue the horn on the hole.
This is the most important place of your aircraft ! Check that you really put the glue on the hole sides, on the horn, and that the whole assembly is well placed.
This part should never break! If you lose the aileron or the rudder you can still save your airplane, if you lose the elevator you lose the airplane and you can injury someone. Concentrate on the elevator assembly, really.
Name: DSCN0123 (Custom).jpg
Description:
Old Mar 25, 2012, 04:16 PM
FlyDave is offline
Crash proof pilot
FlyDave's Avatar
Joined Oct 2005
That's enough for today.
I've checked the tracking nr. of my order, engine and esc should arrive tomorrow, but the servo's aren't shipped until now... have to wait.
Old Mar 29, 2012, 11:38 PM
gewiens is offline
Find More Posts by gewiens
Look Up!
gewiens's Avatar
Canada, MB, Niverville
Joined Apr 2008
Your gonna love this plane. I must have 30 flights on my HK one and it just handles awesome.
gewiens is offline Find More Posts by gewiens
Old Mar 30, 2012, 01:48 AM
FlyDave is offline
Crash proof pilot
FlyDave's Avatar
Joined Oct 2005
I'm sure gewiens, it look very well built
Engine, ESC, batteries and propeller arrived today ! will continue soon this build-log.
Old Apr 01, 2012, 02:33 AM
3d3dman is offline
Find More Posts by 3d3dman
United Kingdom, England, High Wycombe
Joined Feb 2012
flying my sbach in the next 2 hours, cannot wait! FlyDave - I am sure you will know this but please remember to reinforce the elevator- I have after reading all the posts on this model..
3d3dman is offline Find More Posts by 3d3dman
Old Apr 01, 2012, 08:56 PM
Evan03 is offline
Find More Posts by Evan03
Mtn Home, Idaho
Joined Feb 2010
how did it go, im interested in this model
Evan03 is offline Find More Posts by Evan03
Old Apr 03, 2012, 08:45 AM
FlyDave is offline
Crash proof pilot
FlyDave's Avatar
Joined Oct 2005
Motor mount
Just a little update...
Someone on HK review, said that the G60 motor just "fit perfectly" on this airplane.
Well.. this is totally WRONG
The motor is too big to be used with the original mounts, as you see in the first picture, i have mounted the engine with the aluminium cross, and the propeller shaft is pushed all the way back.
It stick out tooo much to be used with a spinner with backplate.
Name: DSCN0126 (Large).jpg
Description:
So i tried to gain some mm (inches) from the front. Removing the "cross" i gained 2mm, and the motor was mounted directly on the firewall using the center holes already existing, you just need to enlarge the holes a bit to fit the 4mm screw.
Name: DSCN0128 (Large).jpg
Description:
Name: DSCN0129 (Large).jpg
Description:
I have used 4x16mm screws + spring washer + flat washer.
This is a picture of the backside, sorry for the bad quality.
Name: DSCN0130 (Large).jpg
Description:
Another 2mm was gained, shortening the motor shaft with a dremel.
Now it's a little better, but still not enough for a nice "zero gap" fitting with the spinner.
Sorry but i was so angry that i haven't taked other pictures after the modifications.
A better mod is to shortening the nose as gewiens has done, look at his thread.
But actually i want to fly this thing soon, before the rain of May, so i will fly it as it is, and will think about better mods in the future.
Tomorrow i should receive the servo's so i can continue.
Old Apr 03, 2012, 08:50 AM
FlyDave is offline
Crash proof pilot
FlyDave's Avatar
Joined Oct 2005
Sorry but something does'nt work with my images... they don't scale down automatically....
Old Apr 03, 2012, 08:53 AM
gewiens is offline
Look Up!
gewiens's Avatar
Joined Apr 2008
My plane is holding up perfect with my mod. It's stronger than stock with all the extra bracing I put in. Not sure why the made motor box so long.
Old Apr 05, 2012, 11:27 AM
FlyDave is offline
Crash proof pilot
FlyDave's Avatar
Joined Oct 2005
Grrrrrrr.....
Today i received my servo's.
I don't know who is the i*iot who has suggested those item's on HK, but they are totally wrong !!
The servo's are too thick and they don't fit the elevator mounting holes, nor the aileron's holes that are 25mm thick.
Another bunch of money gone to the wc....
I can't find servo's that have the correct size and that fit the thickness, so i think i must modify the holes making some adapters and using smaller servo's.
Now i remember also why i hate those damn ARF's... you have always something to modify to make it fly..
I'm sorry but i can't update this thread until i find a economical solution, i have already spent too much for this thing.
Another lesson learned : NEVER thrust your vendor (especially chinese ones..)
New Product NEW Sbach 342 1400mm Balsa (ARF) HK Jaybee 3D Flying 199 Dec 22, 2014 02:36 PM
Discussion HK Sbach 342 1400mm Balsa gewiens Sport Planes 11 Mar 21, 2012 10:35 PM
Discussion Best Sbach 342 ARF raf37 Giant Scale Airplanes 4 Mar 01, 2012 05:25 PM
Wanted Sbach 342 1400mm Balsa (ARF) shepster Aircraft - Electric - Airplanes (FS/W) 11 Dec 19, 2011 06:59 PM
New Product NEW!!!! Hobbyking 1000mm SBach 342 BALSA ARF Jaybee 3D Flying 7 Jun 04, 2011 01:02 AM
