Old Mar 25, 2012, 11:38 AM
rmartin00 is offline
Find More Posts by rmartin00
Joined Feb 2012
Question
LEOPARD 2845 KV2960 4 Poles Brushless motor
I have been looking for a Brushless replacement motor for a 20t Traxxas stinger in the Traxxas Blast. I found this Leopard 2845 KV2960 Motor with a 1/8 inch shaft listed on ebay. It seems to be about what I am looking for but I can't find the motor in the Leopard Catalog. Every 4 pole motor in the catalog shows a 4mm shaft. Anyone know if Leopard makes a 2845 with a 1/8 shaft? Just wanted to make sure it wasn't a counterfit. Any help appreciated.
rmartin00 is offline Find More Posts by rmartin00
Old Mar 25, 2012, 01:02 PM
scorpion1 is offline
Find More Posts by scorpion1
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
If this is it its a real Leopard
http://www.offshoreelectrics.com/pro...o-2845&cat=148
scorpion1 is offline Find More Posts by scorpion1
Old Mar 25, 2012, 03:19 PM
Joined Feb 2012
All the 2845 motors at Offshore and Leopard Factory site show a 4mm shaft
I checked the Offshore Electric and the Leopard factory site. They show a 2845 with 2960KV rating but with 4mm shaft. There are two listed on ebay with 1/8inch shaft.
Here are the links
http://www.ebay.com/itm/300556023665...84.m1423.l2649
http://www.ebay.com/itm/110828332599...84.m1423.l2649
Old Mar 25, 2012, 03:48 PM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Just buy quickly eyeballing it, the ones on ebay look like a 4mm shaft.
Another thing to consider is that you'll have to modify or make a new motor mount to use a 28mm motor with the blast.
wparsons is offline Find More Posts by wparsons
Old Mar 25, 2012, 04:07 PM
Joined Feb 2012
I really don't want a four mm shaft
If I buy a motor with a 4mm shaft I'll have to enlarge the 1/8 inch Univeral Joint to accept the 4mm motor shaft.
As far as mounting the 28mm motor in the blast, I can remove the drive and electronic tray from the blast. The entire drive train comes out by disconnecting the drive shaft at the transom and removing four screws. I can then drill two holes 19mm on center at a right angle to the existing 25mm holes to mount the 28mm motor.
Old Mar 25, 2012, 07:21 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Here's the page straight from Leopard Hobby..................If it is a 4mm dia shaft, that's quite odd...................I think its gonna be 1/8", guess we'll see.
http://www.leopardhobby.com/product/...ionID=01020204
Old Mar 25, 2012, 08:16 PM
Joined Feb 2012
Leopard 2 pole has a 1/8 inch shaft
The only motor I saw on the Leopard factory site with a 1/8 inch shaft is a 2 pole motor. They have a 2848 2 pole with a 3.175mm shaft.
Old Mar 25, 2012, 08:17 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
^^ The specs from leopard state they're all 4mm shafts... I would bet on it being 4mm. Most of the higher power 28mm motors are coming with 4mm shafts now, all the 4 pole turnigy ones are too. Makes them useless in cars/trucks since you can't get pinion gears for them at all. You can get lots of EDF's to mount to them though, it seems like that's the popular coupler size for the fans.
Old Mar 28, 2012, 03:05 PM
Joined Feb 2012
reply from adds on ebay
I emailed the vendors listing the motors on ebay. I ask them to confirm the 2845 Leopard Motors they were offering had a 3.175mm shaft. One responded and thanked me for pointing out the listing was in error. He said the motor had a 4mm shaft.
Discussion what is the difference between a 2 pole and 4 pole brushless motor ? mortonj69 Dock Talk 7 Oct 19, 2014 10:42 AM
New Product 4 Pole Brushless motor with sensor! yang1346888 Product Announcements 0 Mar 05, 2012 08:46 AM
Help! New castle mamba max and 4 pole brushless problem Alliance12364 Castle Creations 0 Mar 05, 2012 06:25 AM
Found 4 pole brushless motor raw111 Cars - Cars and Parts (FS/W) 2 Mar 02, 2012 09:03 PM
Discussion Neu 1110 1y and Leopard 2845 4700 kv jpracing1997 High Performance 4 Jan 08, 2012 07:52 PM
