Old Mar 28, 2012, 04:04 PM
photronix is offline
Find More Posts by photronix
Al Ducharme
photronix's Avatar
Orlando, FL
Joined Jan 2005
I have an order going in to them. I'll buy one.
photronix is offline Find More Posts by photronix
Old Mar 28, 2012, 04:09 PM
SebastianJ is offline
Find More Posts by SebastianJ
Droner
SebastianJ's Avatar
Denmark, Capital Region of Denmark, CPH
Joined Mar 2006
Originally Posted by milo12 View Post
Excellent discussion, thanks for the effort.
Are these Flytron esc's legit? They claim Simon firmware.
http://www.flytron.com/multicopter-p...t-pwm-esc.html
Melih is a standup guy, if he says they're SimonK FW then they are.
SebastianJ is offline Find More Posts by SebastianJ
Old Mar 28, 2012, 04:18 PM
Arxangel is online now
Find More Posts by Arxangel
Arxangel's Avatar
Bulgaria, Sofia-grad, Sofia
Joined Feb 2012
Good, I am really looking forward to this review. I am still deciding what ESCs to get for my octo.
Arxangel is online now Find More Posts by Arxangel
Old Mar 28, 2012, 07:00 PM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
why would you use a helicopter esc in a multirotor?
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Mar 28, 2012, 07:54 PM
~>Miha<~ is offline
Find More Posts by ~>Miha<~
~>Miha<~'s Avatar
Joined Dec 2009
At least from a linguistical point of view using a helicopter ESC in a multicopter seems more logical than using an airplane ESC, isn't it?
~>Miha<~ is offline Find More Posts by ~>Miha<~
Old Mar 28, 2012, 09:27 PM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
M,
Semantics are problematic But as I'm sure you know, and to keep the newbs who read this stuff straight, or at least slightly less confused...multicopters are a different animal need linear responsiveness, no throttle curve, high update rates, no governor or smoothing or LVC for the best performance. ESCs designed for specifically for Helis are bad ju-ju for multicopter performance.
Cheers,
Jim
Quadrocopter and Tricopter Info Mega Link Index
jesolins is offline Find More Posts by jesolins
Old Mar 28, 2012, 09:35 PM
Erknie is offline
Find More Posts by Erknie
Australia, QLD, Brisbane
Joined Nov 2011
@photronix
Hi, and think you for the insightful data that you provide. I would really like to see a test of the new Turnigy HeliDrive ESCs that recently became available at HobbyKing (there are also versions with 80A, 100A, and 120A). They appear to be a serious piece of ESC but it will be best if someone, that knows what he is doing, can test it.
Don't bother, they are inappropriate for a multi-copter.
Erknie is offline Find More Posts by Erknie
Old Mar 28, 2012, 09:55 PM
askman is offline
Find More Posts by askman
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
Heli requires good governor mode. Which is contant rpm at various power loading. Multi requirement is totally different.
askman is offline Find More Posts by askman
Old Mar 28, 2012, 10:02 PM
SGsoar is offline
Find More Posts by SGsoar
United States, CA, LA
Joined Aug 2007
my new ESC's...
SGsoar is offline Find More Posts by SGsoar
Old Mar 29, 2012, 02:32 AM
Arxangel's Avatar
Joined Feb 2012
Well I have limited knowledge of electronics, and signals and PMW and whatever else everyone talks about, so I don't see a difference from one ESC to the next. That is why I depend on good and educated people like you advise what will work and what will not.
Old Mar 29, 2012, 10:14 AM
Al Ducharme
photronix's Avatar
Orlando, FL
Joined Jan 2005
More test results
I have just completed two additional tests.
The first is a simple ramp up in throttle slowly to measure the RPM to Pulse Width values.
The second is a fast step up from about 5000 RPM to 6000 RPM.
I do not see any difference in the performance. Maybe a different test pair would yield different results. Suggest two models to test and I will repeat the test.
Old Mar 29, 2012, 10:23 AM
pug398 is offline
Find More Posts by pug398
VA
Joined Nov 2009
May I ask which Turnigy you are using, Atmel or SIL based?
They change things around every so often
pug398 is offline Find More Posts by pug398
Old Mar 29, 2012, 10:36 AM
Al Ducharme
photronix's Avatar
Orlando, FL
Joined Jan 2005
Atmel (Can't reflash SIL as far as I know)
They are Turnigy Plush 25A
Old Mar 29, 2012, 10:46 AM
jesolins is offline
Joined Feb 2007
Al,
Hmmmm....Perhaps a test with higher resolution would show the RPM tracking accuracy a bit better as was done here: http://www.rcgroups.com/forums/showp...5&postcount=21
Also another good test would be looking at the ramp up and accuracy in the hover throttle range that we use for multicopters which is more in the 50% to 75% range of the ESC . A processor controlled test similar to the way Old Man Mike tests motors using a programmed WQF, or as he calls it wobble modulation, would make the tests repeatable: http://www.rcgroups.com/forums/showthread.php?t=1006721
Cheers,
Jim
Old Mar 29, 2012, 11:06 AM
Al Ducharme
photronix's Avatar
Orlando, FL
Joined Jan 2005
Originally Posted by jesolins View Post
Al,
Cheers,
Jim
No I think the resolution is adequate. The measurement is highly repeatable.
The test was in the 50% hover range.
Mini-Review BD5B or BD-5B Comparison of Aeroworks vs Hobby King FRENCHSTAN Electric Plane Talk 4 Jul 01, 2012 04:14 PM
Mini-Review 3 DVRs comparison (FPV-Japan, Foxtech D1, Wireless DVR 5.8GHz) sharonx FPV Talk 8 May 23, 2012 10:31 PM
Discussion X-Air FC1212-P / DJI Wook Kong WK-M Comparison dansparks Multirotor Talk 6 Mar 02, 2012 09:08 PM
Discussion Upgrade ESC instead of engine AND ESC. Dynasti Electric Plane Talk 15 Sep 23, 2011 09:42 AM
Wanted hobbi co. NexSTAR trainer rtf paintballer#1 Aircraft - Fuel - Airplanes (FS/W) 8 Mar 21, 2006 12:44 AM
