Old Jun 25, 2012, 01:56 AM
redridinghood is offline
Find More Posts by redridinghood
Joined Dec 2010
4.01 works great on a hexa and a heavy octo. The throttle response is faster than with my reflashed F30a.
One small annoyance is that the way the esc calibrates its throttle makes it really hard to use with the YS-X6.
redridinghood is offline Find More Posts by redridinghood
Old Jun 25, 2012, 01:59 AM
Twister773 is offline
Find More Posts by Twister773
Private Pilot
Twister773's Avatar
United States, CA, San Luis Obispo
Joined Jul 2009
thanks red, on a cinestar 8 wkm running 6s what do you think between the 4 esc i posted about in the last post here http://www.rcgroups.com/forums/showthread.php?t=1676433
Twister773 is offline Find More Posts by Twister773
Old Jun 25, 2012, 02:09 AM
Joined Dec 2010
The three esc are similar in build. With the stock firmware are too slow for good flight performance. If you want to build a cheap multi get some Hobbyking F40, F30, F20 and flash them with simonk's excellent firmware.
Old Jul 15, 2012, 05:58 AM
holco is offline
Find More Posts by holco
holco's Avatar
The Netherlands
Joined Mar 2007
We have bought 9psc Ice 50 esc's with the 4.01 firmware but they lose sinc on 28 and 24 poles motors
Hope Castle wil improve there firmware because this motors are running without any problem on a Mystery 40A ESC with simonK firmware, we bought (for almost €1000,00 !!) the Ice 50 ESC's because we wanted a pro solution, but like this they are useless!!
holco is offline Find More Posts by holco
Old Jul 15, 2012, 07:40 AM
NaterPin is offline
Find More Posts by NaterPin
Joined Dec 2009
Originally Posted by holco View Post
We have bought 9psc Ice 50 esc's with the 4.01 firmware but they lose sinc with the Dualsky XM5010TE-5 (28 poles) motors
Hope Castle wil improve there firmware because this motors are perfect and running without any problem on a Mystery 40A ESC with simonK firmware, we bought (almost 1000,00) the Ice 50 ESC's because we wanted a pro solution
I do not know anything about the cc 50 ice but can ..or have you raised the timing to "HI"
NaterPin is offline Find More Posts by NaterPin
Old Jul 15, 2012, 08:35 AM
holco is offline
holco's Avatar
The Netherlands
Joined Mar 2007
Tried all without any luck
Old Jul 15, 2012, 08:42 PM
alros_100 is online now
Find More Posts by alros_100
Great White North
Joined Jun 2008
That sucks man . You should post this to the castle vender thread here
I have to say that i recently picked up some higher quality chinese ESCs preflashed with simonK firmware and they really seem to run my Quads tighter with higher gains. I think the castles must still be doing some internal filtering that is not present in simonKs firmware. Sorry - no hard data other than higher gains - i am just an end user. But theses are only 20-25amps i believe
Al
alros_100 is online now Find More Posts by alros_100
Old Jul 15, 2012, 11:02 PM
holco is offline
holco's Avatar
The Netherlands
Joined Mar 2007
Thanks for the link, I posted this problem there also.
Al
Old Aug 04, 2013, 10:06 AM
multiflier is offline
Find More Posts by multiflier
Joined Aug 2013
Originally Posted by photronix View Post
I've watched the debate over the "speed" and performance of ESCs here for a while. I also see a great deal of effort being spent re-flashing ESCs to improve factory firmware capabilities. The general consensus has been that how fast the propeller can react to a flight controllers commands is directly related to the performance of a multi-rotor. This is true somewhat, but the blame for poor performance has been placed on the ESC mostly. This is incorrect simply because the ESC, Motor, Propeller combination sub-system that actuates the system needs to be considered as a whole. I do not believe the ESC is the bottleneck but rather the drive sub-system.
So about a year ago I set out to measure the Transfer Function of the ESC, Motor, Propeller subsystem since as a flight controller designer this is what is important to me. In engineering, Transfer Function is one of the most common figures-of-merit which is used to compare and measure a systems performance.
What is Transfer Function? Simple.. it is a measurement of a systems response to a known input. I've seen tests where the motor is hit with a step change in throttle. This is a great measurement. Transfer Function is then the derivative of the time measurement which is then Fourier Transformed to yield the Transfer Function (actually this is the magnitude of the previous). The easiest and best way to measure Transfer Function is to drive a system with a sinusoidal input and measure the time varying sinusoidal output. The modulation depth is then measured using the amplitude of the output waveform.
So my test stand optically measures the RPM (as my output value) of a common RC brushless motor (BL-2217/9) 16 times per revolution. I used a APC 10x3.8 propeller. A microprocessor drives several different ESC models with a sinusoidal signal at 200Hz. This may be confusing...the signal is the throttle input to the ESC which varies in time sinusoidally. I chose to use an average throttle value at 50% (hover in most multi-rotors) and vary the throttle 25% above and below this point. Using a larger or smaller value doesn't actually change the result much.
The resulting Transfer Function is a curve showing Relative Attenuation vs. Input sinusoidal frequency. To compare performance of the ESCs you can pick a frequency, say 30Hz and observe the attenuation seen for each ESC. A lower value means that the sub-system was unable to output a sine wave as large in amplitude as another ESC with a higher value.
The results are attached. Let me point out a few things.
1. Turnigy had the best overall response with an almost identical curve for the re-flashed Simonk Turnigy. Does this mean the re-flash is a waste of time? You decide...I am just presenting the data.
2. The Castle Creations Multi-Rotor firmware is cutting off at too low a frequency. They are working on this now and I fully expect them to be able to match the Turnigy curve. I'll post new results when I get them.
3. The Maytec 400Hz performs as well as the Turnigy but I wouldn't use it. At around 65Hz it begins to exhibit aliasing. This is when higher input frequencies are folded around a sampling frequency and result in a lower frequency being output. At 65Hz you will see about 20Hz oscillation which is BAD for a multirotor.
4. Smaller Props and faster motors will provide better performance. However, it will simply raise up the curves maybe 5%. Their relative shapes will remain the same.
5. The older Castle Creations firmware (data not shown) exhibits extreme aliasing after 50Hz. This is why the older firmware did not work on multi-rotors. The flight controllers where sending out commands with changes above 50Hz which resulted in very low frequency changes in RPM. Not what your basic flight controller expects and as a result FAIL.
6. Faster I2C communication is not needed based on this test because the actually ability to alter a motor/propellers speed is around 30Hz.
7. If your contention is that your multi-rotor performs better with one ESC over another it may be the flight controller or another part of the system.
8. RCTimer is the lowest performer assuming CC updates their firmware.
Additional Test
I have just completed two additional tests.
The first is a simple ramp up in throttle slowly to measure the RPM to Pulse Width values.
The second is a fast step up from about 5000 RPM to 6000 RPM.
I do not see any difference in the performance. Maybe a different test pair would yield different results. Suggest two models to test and I will repeat the test.
Added Transfer Function test for new Castle Creations firmware 4.01.
Hi i am very interested in this test as i have been searching for a decent transfer function to fit esc32.
Would you say the transfer function of the motor+esc+propeller combo is like a first or a second order transfer function.
I am referring to the transfer function from commanded thrust to Achieved thrust because i use a thrust rig to determine the thrust vs rpm curve.
multiflier is offline Find More Posts by multiflier
Mini-Review BD5B or BD-5B Comparison of Aeroworks vs Hobby King FRENCHSTAN Electric Plane Talk 4 Jul 01, 2012 04:14 PM
Mini-Review 3 DVRs comparison (FPV-Japan, Foxtech D1, Wireless DVR 5.8GHz) sharonx FPV Talk 8 May 23, 2012 10:31 PM
Discussion X-Air FC1212-P / DJI Wook Kong WK-M Comparison dansparks Multirotor Talk 6 Mar 02, 2012 09:08 PM
Discussion Upgrade ESC instead of engine AND ESC. Dynasti Electric Plane Talk 15 Sep 23, 2011 09:42 AM
Wanted hobbi co. NexSTAR trainer rtf paintballer#1 Aircraft - Fuel - Airplanes (FS/W) 8 Mar 21, 2006 12:44 AM
