Joined Dec 2010
How do you explain the stability and response increase going from a stock plush to a re flashed one?
I would say for your test to be accurate you would need to start out with atleast a 400hz ESC. then test stock 400hz to flashed 400hz. I think what Als test proves is if you start with a good (fast)ESC then flashing it wont make much of a diff. Not the same as flashing an underperforming slow ESC to see if there us a difference. |
Joined Aug 2011
this is indeed very interesting. On one hand you measure that there is no difference between a normal turnigy and a reflashed trunigy (i assume both use the atmel chips), but people show videos where the response can be clearly seem to be better when using reflashed ESC's.
Also, I thought that the ESC's were setup to smooth input throttle response rather than provide direct changes - is what you have done proving that this is not actually the case? ice. |
What about this, seems to prove it really does make a big difference.
Joined Aug 2007
i wish i could flash my turnigy... but they are silab ![]() i think the numbers we are looking at on paper doesn't necessarily directly translate to flight performance.. |
Solihull, England
Joined Jun 2004
Transfer function is the measure of small signal response where nothing should saturate or limit. These tests used quite large signal changes (25%) which may have taken them outside the small signal region. We often operate ESC's on 'copters outside of the small signal response and move into the large signal area when the input signal slews at a high rate. This can give a completely different and non-linear response.
Some ESC's have digital input filters to limit the rate of change of input demand which when removed does improve response. I would suggest further testing to evaluate ESC performance over different speed change ranges and under step change and other high slew rate inputs. Peter |
I've measured it using all different values and ranges. Transfer function is not defined as you suggest. |
| Thread Tools | |
| Mini-Review BD5B or BD-5B Comparison of Aeroworks vs Hobby King | FRENCHSTAN | Electric Plane Talk | 4 | Jul 01, 2012 04:14 PM |
| Mini-Review 3 DVRs comparison (FPV-Japan, Foxtech D1, Wireless DVR 5.8GHz) | sharonx | Video Piloting (FPV/RPV) | 8 | May 23, 2012 10:31 PM |
| Discussion X-Air FC1212-P / DJI Wook Kong WK-M Comparison | dansparks | Multirotor Talk | 6 | Mar 02, 2012 09:08 PM |
| Discussion Upgrade ESC instead of engine AND ESC. | Dynasti | Electric Plane Talk | 15 | Sep 23, 2011 09:42 AM |
| Wanted hobbi co. NexSTAR trainer rtf | paintballer#1 | Aircraft - Fuel - Airplanes (FS/W) | 8 | Mar 21, 2006 12:44 AM |
