Old Mar 24, 2012, 07:32 PM
Pyrofan is offline
Find More Posts by Pyrofan
Pyrofan's Avatar
United States, GA, Perry
Joined Jul 2011
Help!
Grayson Hobby Sukhoi CG question
Ok so I have the grayson hobby sukhoi http://www.graysonhobby.com/catalog/...hoi-p-535.html and am having CG issues. It weighs 11oz and the motor I'm using ( http://www.headsuprc.com/servlet/the...ushless/Detail ) can produce 14 oz of thrust with a 8x4.3. So here is my question(s) 1) how much weight can I add and still hover the plane 2) The CG is 2.5in back. Mine is like 3in back with a 1 1/2oz counter weight. Is that ok. For 3D flight should It be tall heavy or nose heavy. Thanks!
Pyrofan is offline Find More Posts by Pyrofan
Old Mar 24, 2012, 08:01 PM
furballll is offline
Find More Posts by furballll
lost in the addiction of flyin
furballll's Avatar
Canada, BC, Kelowna
Joined Dec 2009
a neutral cg is what most want for the best performance. instead of adding weight though might i suggest putting spacers on your motor mount and moving it further out, and also have you put everything you can to the front?
furballll is offline Find More Posts by furballll
Old Mar 24, 2012, 08:34 PM
Pyrofan is offline
Pyrofan's Avatar
Joined Jul 2011
Yea, except the 2 servos that run the elevator and rudder
Old Mar 25, 2012, 08:10 AM
Pyrofan is offline
Pyrofan's Avatar
Joined Jul 2011
should i weight it
Old Mar 25, 2012, 12:05 PM
Pyrofan is offline
Pyrofan's Avatar
Joined Jul 2011
What size lipo should I use
Old Mar 25, 2012, 06:34 PM
furballll's Avatar
Canada, BC, Kelowna
Joined Dec 2009
i guess i assumed to much, i thought you had all that figured out already. forget weighing it for now, what type of flying do you want to do with it? indoor or outdoor? use on calm days or windy days? what motor do you have on it? speed control?
personally from what i see on their website the set up i would run is.
park 400 on 3s500mah running a 15amp speed controller all 9 gram servoes (for outside use)
park 380 on 3s300mah running 12 amp sc and 5g servo on the ail and 9 on the rudder and elevator.
Old Mar 25, 2012, 06:42 PM
Pyrofan is offline
Pyrofan's Avatar
Joined Jul 2011
Ok, so I took it outside and flew it a bit. I was running 1300kv motor, 8x4.3 prop, 40amp esc( it balanced it and was all I had), and a 500mah 3s lipo. It flew alright, I didnt have much room so it was hard, but tomorrow I'll fly at our field and see how it really handles. It seemed a little un-stable, by that I mean it was tipping side to side. My fingers dont shake so I dont know what was going on.
Discussion SFG on Grayson Hobby 3D sukhoi? windwalker 3D Foamies 2 Apr 10, 2012 05:07 PM
Discussion Grayson Hobby 3D EPP Sukhoi vs Leadfeather EPP Yak 55/54 C5Cheeks Foamies (Kits) 1 Apr 10, 2012 05:06 PM
Discussion SFGs on Grayson Hobby EPP Sukhoi? windwalker Foamies (Scratchbuilt) 1 Jan 27, 2012 04:38 AM
Question Grayson Hobby Sukhoi Question Jus Wanna Fly 3D Foamies 9 Nov 29, 2010 08:23 AM
Discussion Grayson sukhoi question flyer_dad Foamies (Kits) 3 Feb 20, 2010 02:56 PM
