Old Mar 24, 2012, 06:05 PM
Thud_Driver is online now
Find More Posts by Thud_Driver
Thud_Driver's Avatar
Joined May 2004
Cellpro Multi4 won't charge
The Cellpro Multi4 that I've used for the last couple years has failed.
When trying to charge A123's or Lipo's, I get a "No Pack" error. When charging Nicad/Nimh I get a Safety Code 93.
Things I've tried.
- Multiple packs of all kinds
- continuity check of the adapter board
- direct connection to the charger port
- reflash of v1.67 firmware
- Charge Management program reads data from the charger and interacts ok, but cannot get the charger to start a charge.
Have not tried to do a Restore to Factory Settings.
Anything I can do or does it need to be sent in or tossed??
Thud_Driver is online now Find More Posts by Thud_Driver
Old Mar 27, 2012, 12:25 PM
Howard Matos is offline
Find More Posts by Howard Matos
AR-15 BRD!
Howard Matos's Avatar
Frederick, MD
Joined May 2002
Things I've tried.
Hi,
You will need to send the charger in for service. The error 93 indicates a calibration check sum is bad. Please contact me at howard@fmadirect.com and I will give you return instructions. Thanks.
Howard Matos is offline Find More Posts by Howard Matos
Wanted FMA Charger, CellPro or Multi4 Louierc Aircraft - Electric - Batteries & Chargers (FS/W) 1 Mar 29, 2012 10:06 PM
Help! Can Cellpro multi4 charge my 500 mah LIFe ? KevinSharbonda FMA Direct 3 Feb 16, 2012 12:35 PM
Question 1S parallel charging (vs Serial Charging) with Cellpro Multi4 demiluk Batteries and Chargers 30 Feb 08, 2012 06:55 PM
Discussion How to charge NiMh with Cellpro Multi4? demiluk Batteries and Chargers 3 Oct 28, 2011 03:56 PM
Discussion Help - Settings for NiMh batteries charging on Cellpro Multi4 demiluk Batteries and Chargers 0 Oct 28, 2011 03:55 PM
