Old Apr 07, 2012, 01:02 PM
ismith2uk is offline
Find More Posts by ismith2uk
Peterborough
Joined Feb 2009
Twin Blade RPG
Hi Guys,
At the meeting last week, I continued in my attepmts to fly an RPG with two blades rather than the std three. I did have some success, and completed several circuits, which is a big improvements on previous attempts.
I was pleased, but it didn't feel "right", especially when landing/flaring, when it just didn't have enough lift. I discussed this with the RPG Guru (Rich), and decided to remove the blade negative shims, to hopefully gain more lift at the expense of potential "spin up" problems.
I tried flying today without the shims today, and I now have the sweetest flying two blade RPG I could imagine. She flys quite a bit slower than my 3 blade, but just as well, and can now flare without any problem. As for spin up, well today was a very light wind, prob less than 10mph. I pulled the head back and just waited. The blades slowly span up with no intervention from me whatsover. It did take a while, but if they spin up in that wind, then there isn't an issue.
So I am dead chuffed, it has taken me over a year, and I think 4 sets (pairs) of blades, but finally I have a good 2 blade setup. The blades have a pine leading edge (from b&q) 8mm x 30mm, the size of the blades is 67mm x 690mm (2 5/8in x 27in). They are quite heavy with the pine, and come in at about 120gm covered. The shape is approx what the plan(rpg) show, but obviously scaled up, I didn't round the bottom of the leading edge by much. Hopefully there won't be any accidents between now and Winterton!.
Sorry, I didn't take my camera with me.
Cheers
Ian
ismith2uk is offline Find More Posts by ismith2uk
Old Apr 07, 2012, 01:56 PM
SafeLandings is offline
Find More Posts by SafeLandings
It was a GLITCH! Honestly!
SafeLandings's Avatar
Stourport on Severn ,Worcestershire, United Kingdom
Joined Dec 2007
Ian,
Congratulations, I knew you would get there in the end. You have been 100% dedicated to get 2 blades to work, looking forward to seeing it fly in the flesh
Bought myself a set of new scales today as my old ones were giving me odd readings.
As I was trying it out I went and dragged the crashed prototype RPG (crashed because of too much negative on its first outing after a total repair and re cover). My only remaining blade that I have left from all that experimenting weighs 73 grammes and that is with a tip weight, this blade flew really well hence why I have kept it.
One day I must rebuild 'good old faithful' its really not that bad.
Rich
SafeLandings is offline Find More Posts by SafeLandings
Old Apr 08, 2012, 03:03 AM
Ricardo1500 is offline
Find More Posts by Ricardo1500
Ricardo1500's Avatar
Wolverhampton, England
Joined Jun 2010
Ian
Well done on sorting those blades, its good to get there in the end.
As I mentioned to you at the meet up, I had thought that two of the Gemini blades ought to fly the RPG well, they are 760 x 70, so I'm going to knock up a fibreglass plate and give them a go!!
Will keep you posted
Cheers
Rich
Ricardo1500 is offline Find More Posts by Ricardo1500
Old Apr 13, 2012, 08:10 AM
Si_B is offline
Find More Posts by Si_B
Si_B's Avatar
United Kingdom, England, East Grinstead
Joined Nov 2007
Which Turnigy motor were people running their RPG's on. I saw a few at the meet, but forgot to write the numbers down. Going to order a few bits from HK, and get the motor for my rpg at the same time.
Cheers,
Simon
Si_B is offline Find More Posts by Si_B
Old Apr 13, 2012, 03:12 PM
Joined Jun 2010
Hi Simon
I use a Turnigy 3548....the one I had was 900kv, I think this is the one
http://www.hobbyking.com/hobbyking/s...dProduct=16231
I run mine on an APC 13.5x6 and its fine on either 3 or 4s but 4s suits mine better for weight up front
Cheers
Rich
Old Apr 13, 2012, 06:22 PM
Si_B is offline
Si_B's Avatar
Joined Nov 2007
I've got the same thing but a 1000 kv, might do the job.
Cheers,
Simon
Old Apr 17, 2012, 09:42 AM
BigTradioman is online now
Find More Posts by BigTradioman
BigTradioman's Avatar
United Kingdom, Harpenden
Joined Oct 2009
I was running an Emax 2826/6 on 4s but it was running hot and pulling 60 plus amps on a 13 x8. After the meet I tried a 12 x6 and a 3s but in the end switched to an Emax GT2826/06 860kv on 4s with a APC 13 x 6.5 e prop. Its the GT that makes the difference.
http://www.giantcod.co.uk/epower-gt2...-p-406127.html
Huge difference in performance and is only pulling 45 amps at full throttle giving longer flights and more power. I am now building a second RPG from the a CNC kit and using the original plan NOT the Traplet modded plan. The only mods I will make are to go for an Alloy main cart and a steerable nose wheel. Any ideas for an off the shelf nose wheel are very welcome.
BigTradioman is online now Find More Posts by BigTradioman
Discussion PA Addiction, Addiction X, or ??? MattLarson29 3D Flying 6 Mar 15, 2012 09:25 AM
Discussion UK Gyronuts August Meetup Ricardo1500 Auto Gyros 29 Aug 11, 2011 06:08 PM
Idea Autogyro meetup ismith2uk Auto Gyros 19 Apr 18, 2011 01:03 PM
Discussion Wales o7 uk meetup details needed Badllarma Aerial Photography 53 Feb 29, 2008 01:49 AM
Discussion Any News About RCX, March 31st & April 1st LBMiller5 Electric Flight Events 7 Mar 25, 2007 11:36 PM
