Old Mar 24, 2012, 04:09 PM
David Forbes is online now
Find More Posts by David Forbes
David Forbes's Avatar
United States, FL, Gainesville
Joined Dec 2005
Wind Dancer power options?
I just scored a partially built Wind Dancer (lucky me). Most of the Wind Dancer threads are several years old, and since technology marches on, I was wondering what would be the hot set up to power this thing with todays world of choices. This is my first real ALES bird (if you don't count the Radian), so I have limited experience with electrics, coming mainly from the DLG end of things.
Dave
David Forbes is online now Find More Posts by David Forbes
Old Mar 24, 2012, 06:42 PM
wsnowfall is offline
Find More Posts by wsnowfall
Cleveland Ohio
Cleveland Ohio
Joined Jan 2006
i am building one now. i have a neu 2500 razor, i am also looking at the hyperion glider slope model, i dont have the number handy at this moment. i am thinking of hs 65 all around or hv sevos from specktrum,. they are light and powerful. expensive and overkill. the critical servos will be the flap. are you going poly or flat wing?
bill
wsnowfall is offline Find More Posts by wsnowfall
Old Mar 24, 2012, 07:04 PM
Joined Dec 2005
I'm doing the full house wing, four DS 285 is what I have in mind. Probably use them on R+E too.
Dave
Old Mar 24, 2012, 07:19 PM
mnowell129 is offline
Find More Posts by mnowell129
I'm not as bad as they say.
Joined Nov 2004
Hey Dave,
Any thoughts about an ALES event at SF?
Was starting to consider an ALES airplane myself.
mickey
mnowell129 is offline Find More Posts by mnowell129
Old Mar 25, 2012, 12:55 AM
Jebera is offline
Find More Posts by Jebera
Jebera's Avatar
United States, NH, Nashua
Joined Oct 2006
Dave,
It's the ultimate ALES F5J setup, have it on my Pike Perfect!
MKS 6100 all around, cheap digis, good power, 9g micros and metal gears.
Motor Skorpion geared http://www.reisenauer.de/artikeldeta...1437&sprache=2
Prop Graupner 17x9
Esc SunRise 60A http://www.reisenauer.de/artikeldetails.php5?aid=1421
Bats 3s TP g6 850mah 65c or 1200mah, depending on the weight...
You can't go wrong.
Soft landings!
André
Jebera is offline Find More Posts by Jebera
Old Mar 25, 2012, 08:21 AM
Kenny Sharp is offline
Find More Posts by Kenny Sharp
turn, turn, turn.
Athol, Massachusetts
Joined Oct 2005
Yeah that is sweet.
I'm only using old F5B power because that's what I have.
Kenny Sharp is offline Find More Posts by Kenny Sharp
Old Mar 25, 2012, 08:28 AM
Jebera is offline
Jebera's Avatar
Joined Oct 2006
Well,
Maybe a birthday present for yourself, well you have been a good guy lately, haven't you? I have!
Old Mar 25, 2012, 12:39 PM
Rolf D. is offline
Find More Posts by Rolf D.
What is Highspeed ?
Rolf D.'s Avatar
Germany, BY, Bergen
Joined Feb 2011
Originally Posted by Jebera View Post
Dave,
Prop Graupner 17x9
You can't go wrong.
Soft landings!
André
The Folding Prop is a Graupner 18x10
17x9 is for doing a snails pace
Rolf D. is offline Find More Posts by Rolf D.
Old Mar 25, 2012, 01:00 PM
turn, turn, turn.
Joined Oct 2005
Well,
That would be a brilliant birthday present!
Old Mar 25, 2012, 03:09 PM
williamson is offline
Find More Posts by williamson
Joined Feb 2006
One of the older Wind Dancer threads talked about good results with a Hacker 2020L motor. I bought one and installed it in my Wind Dancer. It works great. With a 3S battery, it gets to 200 m in a little over 30 sec. using a 9X5 prop. Bench tests with a 10X8 prop indicates that the plane should get to 200m in well under 30 sec.
One problem with the 2020L is that there isn't room to run the leads back from the of the front of the motor. The rotating part of the outrunner is at the rear. What I did was route the leads outside the fuselage and then back in again behind the motor.
williamson is offline Find More Posts by williamson
Old Mar 25, 2012, 03:15 PM
Wazmo is online now
Find More Posts by Wazmo
Duane, LSF IV
Wazmo's Avatar
No. VA
Joined Nov 2004
You can mount a prop adapter on the rotating bell end of the motor (I think mine came with it, or you may be able to purchase separately), and mount the fixed end with the wires to a firewall.
Wazmo is online now Find More Posts by Wazmo
Old Mar 26, 2012, 07:31 PM
rev.iain is online now
Find More Posts by rev.iain
Mesa AZ, it's a dry heat!
USA, AZ, Mesa
Winddancers
I have built and flown several of these, with both S400 and outrunner motors. The Hacker is the best choice, with 2S and a 12X7 Aeronaut prop. you may exceed the recommended current, but for the short time the motor runs in ALES or LMR events, it is not a problem. I have run the motor with a 13" prop on 2 cells at higher elevations (5000' +) without problems.
Iain
rev.iain is online now Find More Posts by rev.iain
Old Mar 26, 2012, 08:08 PM
Jebera is offline
Jebera's Avatar
Joined Oct 2006
Other options
You have other options: (got from Hyperflight UK).
Hacker A20-6XL geared 4.4:1, 3S 1.3Ah LiPo, 16x9 Aeronaut prop (1900 fpm, 46A)
HET 2W-25 geared 6.7:1, 3S 1.5Ah LiPo, 20x13 RF prop (2300 fpm, 50A)
HET 2W-25 geared 6.7:1, 3S 1.3Ah LiPo, 18.5x14 Aeronaut prop (1920 fpm, 41A)
HET 2W-25 geared 6.7:1, 4S 1.5Ah LiPo, 18.5x14 Aeronaut prop (3400 fpm, 69A)
HET 2W-25 geared 6.7:1, 4S 1.3Ah LiPo, 18x11 Aeronaut prop (2800 fpm, 52A)
HET 2W-25 geared 6.7:1, 4S 1Ah LiPo, 17x11 Aeronaut prop (2370 fpm, 42A)
Hyperion Gs3020-08 direct drive, 3S 1.5Ah LiPo, 13x7 Aeronaut prop (2250 fpm, 70A)
Hyperion Gs3020-08 direct drive, 3S 1.5Ah LiPo, 12x8 Aeronaut prop (1880 fpm, 61A)
Mega 16/25/2 geared 4.4:1, 3S 1.5Ah LiPo, 16x10 Aeronaut prop (2100 fpm, 57A)
Mega 16/25/3 geared 4.4:1, 3S 1.5Ah LiPo, 20x13 RF prop on +7 spinner (2150 fpm, 49A)
Mega 16/25/2 geared 6.7:1, 3S 1.5Ah LiPo, 20x13 RF prop (2400 fpm, 56A)
I think also you can use a Hacker A20-8xl 4.4/1 with a 23x12 prop, very efficient and low cost, but not high-end...
Cheers!
André
Old Mar 29, 2012, 06:43 PM
fhpe77 is offline
Find More Posts by fhpe77
Model Flight Addict
fhpe77's Avatar
Erial, NJ
Joined Jul 2009
I'm running a Scorpion SII 2215-1127 V2 with great success. On 3-cell with an Aeronaut 9x5 it pulls around 18A and 207W. This Wind Dancer will hit 200M in 22 seconds, but note that this plane is on the lighter side at around 23oz.
fhpe77 is offline Find More Posts by fhpe77
Old Mar 29, 2012, 07:04 PM
Vito is offline
Find More Posts by Vito
USA, PA, New Hope
Joined Nov 2001
I ran my WD with a geared S400 for quite a while but wanted more oomph and less gear noise. Someone suggested a direct drive Mega 1625-6 inrunner. This avoids the interference problem with wires of an outrunner. I ran this on a 2 cell LIPO for quite a while. In preparation for ALES, I bought a 1000mAH 3 cell. It balances okay and screams. I always have a lot a charge left when I land.
Vito
Vito is offline Find More Posts by Vito
Found Wind Dancer Kit Twinkletoze Aircraft - Sailplanes (FS/W) 3 Mar 04, 2012 05:30 PM
Sold Wind Dancer $135.00 fruitguy Aircraft - Sailplanes (FS/W) 3 Feb 29, 2012 08:37 AM
Sold $200.00 Polecat Wind Dancer II w/motor & esc magee8578 Aircraft - Sailplanes (FS/W) 7 Nov 27, 2011 07:00 PM
Discussion Wind Dancer / Allegro E lite power system williamson Electric Sailplanes 4 Jul 30, 2009 11:07 AM
