Old Mar 24, 2012, 04:56 PM
joe_crash is offline
Find More Posts by joe_crash
Pelagicide
joe_crash's Avatar
United States, MD, Gaithersburg
Joined Oct 2010
Symetrical airfoils same as plate wings?
I just read something that makes sense, but the more I think of it, wonder if it's actually true or not. I don't recall the source, but I read that a symetrical airfoil in fact generates NO lift - which would be true of plate wings also, if it was flying with an angle of attack of 0 degrees.
I don't know much about aerodynamics - you can probably tell from this ? - but is true that both wings at a zero angle of attack, or neutral, generate no lift, and therefore the angle of attack is what determines the lift of a wing with either style airfoil? (I guess in the case of a depron plane w/ no airfoil at all, it seems more logical.) If this is the case, why bother with a symmetrical airfoil on a wing? Why does my 3D profile Aeroworks plane if flown level, not sink to the ground? With wings with a Clark airfoil, I can understand the theory of it generating an area of negative and positive pressure, resulting in lift - but what about symmetrical airfoils? (And yes, I've read all the threads in this forum the low/high pressure idea being but one theory of what creates lift.)\
Thanks in advance for the explanation - please help my mathematically/physics challenged brain understand this ....looking forward to hearing an explanation!!!
Joe
joe_crash is offline Find More Posts by joe_crash
Old Mar 24, 2012, 05:12 PM
BMatthews is online now
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
Yes, a flat plate is a symetrical airfoil with 0% thickness. Simple as that.
The angle that is needed for level flight is so low for normal cruise speed flying that they LOOK level. But in reality they are not.
NO plane with a flat or symetrical airfoil will fly level with a 0 AoA. The only time they are truly at a 0degree AoA is when they are going straight up or straight down. If you set the model level then they "fall" or transition into a descending glide where the level attitude then generates a positive angle of attack. It's only when such models slow down to near the stall speed that they have a more obvious nose up attitude to their line of flight when flying at a constant height.
Just don't confuse the "harrier" style of flying with the flat foamies with "near stall". Flat plate wings on 3D flat foamies will stall at around 5 to 7 degrees. Once past that angle they are flying in a post stall mode. That doesn't mean the lift goes away. Simply that the top surface has a complete airflow breakdown and is generating high drag which needs to be compensated for by the use of excessive power to remain airborne.
BMatthews is online now Find More Posts by BMatthews
Old Mar 27, 2012, 01:29 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
From a Science Fair at the AV Mall a few years back...
Sparky Paul is offline Find More Posts by Sparky Paul
Old Mar 27, 2012, 03:34 PM
Brandano is offline
Find More Posts by Brandano
Ah, yes, "lies to children" at work again. Hopefully someone will explain Elizabeth that things are not as simple as they seem once she is old enough to understand it. But the vast majority of children will not grow up to be an aerodynamics expert, and will just stick to what they were taught.
Brandano is offline Find More Posts by Brandano
Old Mar 27, 2012, 05:27 PM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
Well to be fair the basic conclusion of the experiment (the shape of an airfoil does makes a difference) was absolutely correct. It just went a teeny bit wrong with the "why" . And I'd guess someone a lot older than Elizabeth told her to put that bit in. Still it is amazing what poor old Bernoulli, who never saw an aeroplane in his life, gets blamed for .
And of course joe_crash is relying on fallible eyesight for his conclusions. If your plane was truly flying with the wing precisely level it would indeed lose height or"sink to the ground". The fact that it doesn't means that it's actually flying with the wing at a slight angle....but it doesn't need to be a lot, one or two degrees is enough to work but is really difficult to spot.
Steve
slipstick is offline Find More Posts by slipstick
Old Mar 28, 2012, 09:26 AM
richard hanson is online now
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
The well intended but incorrect "fact" of airfoils required for producing lift , really bugged me ,as a teenager .
No one bothered to note that these finely developed curves were simply attempts at maximizing EFFICIENCY at some given condition.
Change the conditions> the best shape also changes.
Fast forward to today.
For most powered models in smaller sizes the refinements in shapes is really not important
perfectly flat,squared edgewings work extremely well at very low wing loadings and small sizes
Those who doubt this, should actually build and fly more and cogitate less.
My second law of aerodynamics :
if the loadings are low enough - the shape does not matter ,
If they are too high - it still does not matter.
richard hanson is online now Find More Posts by richard hanson
Old Mar 28, 2012, 11:33 AM
Yak 52 is offline
Find More Posts by Yak 52
Yak 52's Avatar
UK
Joined Jan 2009
There's actually nothing wrong with that project except the implied reference to the 'equal transit time' fallacy in the Why part. It just happens to be a study of lift at zero angle of attack, not a complete study of the subject but not 'wrong' as such. The pink and yellow sections are symetrical hence no lift and the cambered foil does rely on pressure differential created by curved surfaces (well camber) to produce lift at zero alpha.
Yak 52 is offline Find More Posts by Yak 52
Old Mar 28, 2012, 11:41 AM
Yak 52 is offline
Yak 52's Avatar
UK
Joined Jan 2009
Joe
Joe. The symmetrical airfoil also creates a difference in pressure between the two surfaces but it requires some angle of attack above zero for this to occur. This happens with any symetrical airfoil or flate plate. Whereas an airfoil with camber will make a small amount of lift at zero angle of attack.
The reason to put a streamlined airfoil on a symmetrical wing is that it will have better drag characteristics and also stall 'later' (at a higher angle of attack) than the flat plate.
Old Mar 28, 2012, 11:54 AM
Joined Oct 2007
Originally Posted by Yak 52 View Post
Joe.
That sums it up
Add "the fatter the shape the less critical to AOA.
One of my favorites W T F is the diagram of a Clark Y shape with the" zero" AOA listed as parallel with the flat lower surface.
Old Mar 28, 2012, 12:05 PM
DPATE is online now
Find More Posts by DPATE
Grad student in aeronautics
United States, GA, Atlanta
Joined Oct 2010
Originally Posted by richard hanson View Post
That sums it up
I've actually seen in an old book where they defined the chord to be along the flat bottom instead of connecting the tip of the LE to the TE.
DPATE is online now Find More Posts by DPATE
Old Mar 28, 2012, 12:21 PM
Brandano is offline
I have seen some pretty odd wing sections used on full size acrobatic planes. Generally symmetric, because you want the same behavior when upright as when inverted. Fairly thick, because top speed is not essential but keeping the speed down in a dive is, and you can always add a bigger engine. And with the maximum thickness quite forward, at least near the tips. This probably delays the stall to a greater angle of attack, but an acrobatic plane HAS to stall at a reliable AOA, so generally there are stall strips, sharp leading edge protrusions, on the inboard portion of the wing.
Old Mar 28, 2012, 12:25 PM
Yak 52 is offline
Yak 52's Avatar
UK
Joined Jan 2009
That sums it up
Add "the fatter the shape the less critical to AOA...
And for the full story it should be noted that this is only holds ture true at 'normal' (higher) Reynolds numbers. Around the Critical Re region (ie small models) the extra thickness of a streamlined section can be a problem (causing seperation at low alphas) and the flat plate starts to look attractive again.
Old Mar 28, 2012, 01:05 PM
Joined Oct 2007
very true --
The Yaks and Extras use the "ice cream cone" setup - and NO sharp leding edge strips which make for a very efficient wing and one which when stalls does it very crisply
The little bitty flat foils with low loadings have a usable range of 0 to 90 degree (well almost)
Old Mar 28, 2012, 01:23 PM
Ascended Master
Palmdale, CA
Joined Oct 2000
That's the "raised entry"... I noted that with this Sukhoi 26 airfoil...
Old Mar 28, 2012, 01:42 PM
Joined Oct 2007
Back when-- we called that a Phillips Entry ( named by Mrs. Phillips) but in the case of the YAK or an EXTRA, the AOA for level flight has the airfoil at only a slight deviation from "0".
The shape has exellent attachment over the top but lets go instantly when a high AOA is induced Perfect for the purpose
Also the full scale aerobats are made as light as possible (sometimes resulting in a wing departing ) and power to weight is maxed
All different stuff than a Cessna 150----
Build Log GP Sabre Symetrical Wing Build Thread Kevin Greene Micro EDF Jets and Power Systems 10 Mar 02, 2012 06:08 PM
Discussion Obama Defends Roe v. Wade As Way for ‘Our Daughters’ to Have Same Chance As Sons to ‘ MtnGoat Life, The Universe, and Politics 0 Jan 23, 2012 12:58 PM
Discussion My new PBF with full symetrical airfoil Bike Medic Foamies (Scratchbuilt) 5 Jan 02, 2012 05:17 PM
Discussion Does a thicker wing act the same as a thinner/larger wing? niner555 Modeling Science 6 Sep 21, 2007 01:56 PM
Discussion is fully symmetrical airfoil same as profile? subarus Electric Plane Talk 20 May 04, 2007 05:23 PM
