Espritmodel.com Heli Air
Old Mar 24, 2012, 03:05 PM
Canada, BC, Kamloops
Joined Sep 2011
Motor just became hard to turn with no throttle?
I just noticed my Stinson motor as soon as I cut throttle it stops right away. Also noticed it's hard to turn by hand. Other than that it runs fine. Doesn't get hot or have an odor when throttle is applied and seems to preform fine. Will it eventually seize? Anything I can do?
CnadianFF is offline Find More Posts by CnadianFF
Old Mar 24, 2012, 03:09 PM
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
It might be the ESC brake. It shorts out the windings to stop the motor.
Disconnect it from the ESC if you want to be sure.
Most ESCs can also be programmed to turn the brake on or off. Which ESC is it?
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Mar 24, 2012, 03:10 PM
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
The 'Brake' is probably set on the ESC program.
It's normally used for folding props to ensure they stop windmilling and fold properly. When the brake is set, it's a bit like having a short across the motor, it's noticeable even with no battery connected.
Check the ESC's manual for how to turn off the brake.
eflightray is offline Find More Posts by eflightray
Old Mar 24, 2012, 03:52 PM
Joined Sep 2011
That's exactly what it was. Thanks alot guys
Old Mar 24, 2012, 10:38 PM
Joined May 2005
Even without folding props, braking the prop is often recommended if you want to stop the motor completely. A free-wheeling prop induces more drag than a braked prop, at least for props 9 or 10" in diameter or larger. That fact can improve your landings even. If you keep your motor turning (keep a touch of throttle on) you can bring some planes in a bit steeper and cleaner.
caseih is offline Find More Posts by caseih
Question No throttle control with Orange Rx 610 receiver DCAirlines1 Power Systems 19 May 01, 2012 10:01 AM
Discussion No throttle hold with orange receivers? garrettt04s Electric Heli Talk 6 Feb 03, 2012 09:21 AM
Question No throttle control with A9 as student NefariousRC Hitec/Multiplex USA 3 Sep 21, 2011 06:22 PM
Question motor becomes hard to turn with new ESC. PatternFlyer Power Systems 10 Jul 04, 2011 06:38 AM
Discussion Dropped my MCX transmitter -- no visible damage but it just beeps when I turn it on tooconceited Micro RTF 7 Dec 03, 2008 09:16 PM
